Old Nov 14, 2012, 04:30 PM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Originally Posted by crvnation View Post
Whatever... I just said *he* didn't see to have any problems flying an entire routine with his body in between his TX and, yes, that tiny BNF heli with an extremely minimal antenna. If anything, that would be a much worse scenario than with bigger stuff that has longer antennae, satellites, etc.
That is a six channel rx I recall - The model I referred to was a tiny electric jet with the integrated rx/esc AS3X
richard hanson is online now Find More Posts by richard hanson
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
What exactly is the topic again?
aerocal is offline Find More Posts by aerocal
Old Nov 14, 2012, 04:32 PM
Joined Oct 2007
Sorry, I was enjoying another cocktail-- at least I have an excuse -
Old Nov 14, 2012, 04:33 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
Originally Posted by jasmine2501 View Post
Interesting article... but it sounds like a "solution" that doesn't solve the problem. From what I understand it's only full-duplex in the same sense that a time-sharing mainframe is "multi-user"
But I'm sure I misunderstand it, right?
It's a technique to double the amount of usable spectrum when TX and RX of signals are both required- your transmitter and receiver would both be in use at the same time and on the same frequency, without your TX interfering with your RX.
So, not that useful unless maybe you are putting your TX and FPV on the same frequency.
CNY_Dave is offline Find More Posts by CNY_Dave
Old Nov 14, 2012, 04:34 PM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
Guess what? The 130 X is a tiny electric heli with the integrated all-on-one-board RX/ESC/AS3X, too. What was your point again? Have you even SEEN a 130 X in person?
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Nov 14, 2012, 04:38 PM
pach is offline
Find More Posts by pach
United States, FL, Miami
Joined Aug 2009
lalalalalalalalalalala, i refuse to acknowledge the most obvious conclusions lalalalalala
Not sure how you can have power AND pre-set servo positions with a brownout.
I used to intentionally lose signal on AR6100's by flying as high up as possible and pointing the antenna at the plane, its not *that* hard.
Not to mention just use a low power tx on any model past XXX feet, there are dozens of stories of people having Blade CX2's drop from the sky with LP5DSM's, I really dont understand how you think 2.4ghz is so infalible, with the right TX/RX setup ? Sure, but many setups, especially low budget ones just dont cut it. Not all 2.4ghz setups have optimal antenna placement.
pach is offline Find More Posts by pach
Old Nov 14, 2012, 04:51 PM
Joined Sep 2012
Typical response from him, but I see he edited it out on the last page.
Old Nov 14, 2012, 04:59 PM
Joined Oct 2007
A couple - those are small 6 channel rx
Point - being - If you care -
You can block a 2.4 radio with your body.
Fly some more and you will eventually see it happen.
Old Nov 14, 2012, 05:00 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I really don't understand why you're arguing with me when I'm agreeing with you. But, if you're trying to be annoying, you are successful.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 14, 2012, 05:02 PM
Joined Oct 2007
Possibly still at that " needing attention " phase of life
Joined Sep 2012
The number of channels has no bearing on the issue.
Old Nov 14, 2012, 05:04 PM
Joined Oct 2007
No it doesn't - just identifying it .
Do you actually have and use 2.4 equipment or are you just a groupie?
Old Nov 14, 2012, 05:14 PM
Joined Sep 2012
Yup. Run the gamut from junky, stock Spektrum TXs to my DX7, DX8 and "questionable" DX18. Only fly with the DX8 right now as it's been a reliable workhorse, unlike the DX18. You?
Old Nov 14, 2012, 05:32 PM
pach is offline
Joined Aug 2009
Yeah sure, you were...
My mistake was assuming you were being sarcastic by starting a sentence with Yeah sure, ... I'm sorry for misunderstanding and over-reacting.
Old Nov 14, 2012, 05:50 PM
Rocket Programmer
Joined Jul 2007
Sorry I didn't mean it that way. It really is the only explanation. It has happened to me once, but I couldn't confirm that it wasn't a brown-out followed by failure to re-connect, and I failed to check the blinker, so I'll never know.
My whole point that started this is still valid though - don't eliminate likely possible problems because of the existence of other less likely possible problems. Get some data, do some tests - that's the only way to regain confidence in the system after a failure.
Question Throttle linkage frequency with 2.4 GHz? Abrams Beginner Training Area (Fuel) 3 Jul 29, 2012 11:15 PM
Sold Tru Turn 2-3/4" 2-Blade Spinner Combo With Saito 50-91 4-Stroke Double Jam Prop Nut Skywalker14 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 10, 2012 10:14 PM
Help! Frequency selection help please, 5.8 or 900mhz. Need to decide which one to get jasper7821 FPV Talk 12 Mar 15, 2012 05:59 PM
Question Any idea when and if the HF 2.4 module for MPX Evo will be available in US tiju000 Hitec/Multiplex USA 3 Sep 24, 2009 09:07 PM
Question Are the Multiplex 2.4 transmitters/receivers going to be sold in US/Canada? Xnaron Hitec/Multiplex USA 2 Feb 12, 2009 10:42 PM
