Old Nov 14, 2012, 08:04 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Originally Posted by richard hanson View Post
I have to call you on that -
Past experiences with 72/50/53 mhz show voltage drop is far less of an issue.
None of those will require resetting even if voltages drop below servo operating voltage levels . Servos will slow and operation can become unflyable -but the rx do not stop trying to process.
I used to fly stuff weighing over 40 pounds and I did a lot of checking on battery requirements to keep the huge control surfaces operating.
When 2.4 hit the scene -the power requirements was one of my first questions .
The myth
I know of no myth but factually ALL the 2.4 radios will stop processing info at voltage levels where servos become inoperable . You may see a few tenths volt differences between brands but all of the rx stop and must reset at some point around 3 volts.
When I made similar experiments on a Fasst RX, I found out that my servos stopped around 3V, but the RX at 2.7V. This means, that the servos cannot draw the voltage below 3V, and thus cannot produce brownouts.
And even if they did, a Fasst RX has always been recovering within one second.
Not so the Spektrum RXes. They suffered from brownouts already at 3.2-3.5V, they synchronized the servo signals making voltage drops much more severe, and in the beginning, they took multiple seconds to respond after power-up or reboot.
This combined lead to the myth that ALL 2.4 systems are in danger of a brownout.
For some strange reason, Fasst, Jeti, FrSky etc. users never had any such problems.
This is because these RXes have a low reboot voltage, they don't synchronize the servo signals, and they reconnect in an instant after reboot.
My buddys and me flew Fasst and Jeti all the time since 2007, did not change anything in our power systems, and we had zero problems.
If our batterys can power our servos, they are also enough to power our recievers.
Some time ago I wrote this:
http://www.rcgroups.com/forums/showt...0#post10855830
Especially interesting is the posting below mine.
A longer explanation:
http://www.rcgroups.com/forums/showt...=4#post7753366
Julez is offline Find More Posts by Julez
Old Nov 14, 2012, 10:06 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Julez,
I always suspected Futaba knew something about R/C design that others didn't. it's so simple now, this is why you don't hear reports about Futaba brown-outs.
Well done for spotting that one.
A.
AndyOne is offline Find More Posts by AndyOne
Old Nov 14, 2012, 10:14 AM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
So, has Horizon/Spektrum fixed this horrendous issue or not yet?
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Nov 14, 2012, 11:18 AM
MattyB is offline
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Maybe, maybe not. I suspect it's more that being the first (or nearly the first) spread spectrum 2.4 solution meant Spektrum fell victim to the gotchas that always occur when a new technology is introduced to the consumer market. In this case the issues were exascerbated by most people not understanding the physics around 2.4 or the increased power requirements of the RXs, meaning many crashes were blamed on "radio failure" when in fact they were user errors. Either way it meant the likes of Futaba could design improved systems based Spektrums learnings. Just my 2 cents.
I'm not an expert on Spektrum (I use FrSky myself), but I believe they have addressed some of these issues with speedier reboots and lower reboot voltages in their newer receivers, plus of course the full hopping DSMX is a more robust RF solution than DSM2. However if you have one of these older receivers then I guess all the caveats above around brownouts still apply...
MattyB is offline Find More Posts by MattyB
Old Nov 14, 2012, 11:26 AM
Dadstoysbg is offline
Find More Posts by Dadstoysbg
Bowling Green,Ky
Joined Sep 2004
With DSM2 when you turned on the trannie it scanned for two open channels and locked on. When you turned on the plane the receiver scanned looking for the transmitter and then it locked on. If you had a "brown out" the old receivers had to rescan to find the transmitter. that's what took up the time.
When Spektrum realized this was a issue the first fix was to have the receiver go to the channels it had been using. This was a rewrite of the software in the receiver and any Spektrum user could send their receivers in for the up grade. This improved the reboot time greatly. All the new receivers have this in their programing.
The new X is even faster because it hops and we as users have learned that we need to take care of our power needs better as in all the systems.
I'm still using the first receivers that came out with the modules. Never had them upgraded and have never had a issue. The reason being I use battery's that will handle my needs.
Some day I will upgrade my radio to X when I have to replace the receivers. Dennis
Dadstoysbg is offline Find More Posts by Dadstoysbg
Old Nov 14, 2012, 11:44 AM
pach is offline
Find More Posts by pach
United States, FL, Miami
Joined Aug 2009
No, they havent found a way to power receivers and servos without dc voltage.
As previously stated, other manufacturers sort of got away with inadequete power setups because the servos would stop operating before the receiver.
While better, you still have a situtation where you are losing some control of your model.
And to jasmine2501 disbelief, I've never personally experienced a brownout, just lockouts or lack of signal. I have experienced blackouts though, when the ESC fries in mid-air and everything goes down in a blaze of glory.
pach is offline Find More Posts by pach
Old Nov 14, 2012, 12:02 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Do you have the telemetry record to show that you lost the signal? I believe in loss of signal, I just haven't ever seen it confirmed with measurements. I'm sure it happens, it's a physical law, but I think it is pretty rare when compared to the amount of brown-outs.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 14, 2012, 12:03 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
I don't agree - - In actual pactice a battery which is depleted ( o ralmost depleted ) goes thu the under 4 to under 3 volts - in a fairly short time period - Failure of either rx or servo being of little importance as things have stopped responding.
The reasoning of "you had no failures " means little as honestly I have flown 2.4 Spektrum from initial issueing of early DSM DX6 tx and rx- never a failure in the air.
amongst the many Spektrum users here - the experience has been the same .
Most of the early on users I know, flew small electrics and were aware of how bad batteries could be.-(capacity only, no tbeing an indicator of how they responded under loads .) They simply made sure they used enough battery POWER.
The Horror issues are simply BS.
richard hanson is offline Find More Posts by richard hanson
Old Nov 14, 2012, 12:35 PM
Bowling Green,Ky
Joined Sep 2004
As I said in my last post. My receivers are the ones that came with module before they even had radios.
I did take the time to try and understand the system and when i flew the first time everybody at my club thought I was crazy (some still think I am) They to a man said they'd never change. Well guess what, don't see a card on the board anymore.
The first year Spekrum sold the module and receiver I took a chance and took 8 to our jet meet. Sold them within a half hour. the guys put them in their jets did a range check and took off. Not one failure.
I can still remember all the griping when we had to upgrade our radios to narrow band. And yes some blamed crashes on the radio. Dennis
Old Nov 14, 2012, 01:00 PM
pach is offline
Joined Aug 2009
You really dont need that when you are flying level with 2 micro servos and absolutely no load and control is only lost in certain orientations of the plane.
Or when signal failsafe hits and suddenly the plane is doing the loops set for failsafe.
Old Nov 14, 2012, 01:38 PM
Joined Oct 2007
I do believe in signal loss- seen it - also have seen WHY signal loss occurred.
The last times involved the most expensive Futaba systems on the market.
The problem?
antenna orientation and correcting this issue, fixed the problem
Why would good flyers flying good equipment have this issue?
Does it happen on low cost stuf
- saw it last month - when the plane was flown behind the pilot - in a line which blocked the tx (held against the chest).
If the plane failsafes in certain positions - is that a receiver Problem?
Or simply incorrect antenna placement (or using short range setup in long range app.) issue. Also - I have setup tests which show certian battery failures can and will result in servos driving or staying full over .
The condition occurs when power drops below threshold- servos stop - power moves back above threshold , again powering the servos - etc., etc,
If you have never tested for this it is hard to accept - but it will and can happen.
Old Nov 14, 2012, 01:43 PM
Joined Sep 2012
And? I saw a video of 1st place winner at iHobby, Patrick H., fly an entire routine with his Blade 130 X...with the TX behind his back. Obviously, it was Spektrum. He didn't seem to have any problems.
Old Nov 14, 2012, 01:49 PM
Joined Oct 2007
That was not a tiny Bind n Fly which has minimal antenna.
You can block the signal in many cases by placing a body between tx and the model - this test is easily done using a system which has telemetry that shows losses
Old Nov 14, 2012, 02:06 PM
Joined Sep 2012
Whatever... I just said *he* didn't see to have any problems flying an entire routine with his body in between his TX and, yes, that tiny BNF heli with an extremely minimal antenna. If anything, that would be a much worse scenario than with bigger stuff that has longer antennae, satellites, etc.
Old Nov 14, 2012, 02:12 PM
Rocket Programmer
Joined Jul 2007
Yeah sure, there's nothing other than signal lost to explain that.
Question Throttle linkage frequency with 2.4 GHz? Abrams Beginner Training Area (Fuel) 3 Jul 29, 2012 10:15 PM
Sold Tru Turn 2-3/4" 2-Blade Spinner Combo With Saito 50-91 4-Stroke Double Jam Prop Nut Skywalker14 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 10, 2012 09:14 PM
Help! Frequency selection help please, 5.8 or 900mhz. Need to decide which one to get jasper7821 FPV Talk 12 Mar 15, 2012 04:59 PM
Question Any idea when and if the HF 2.4 module for MPX Evo will be available in US tiju000 Hitec/Multiplex USA 3 Sep 24, 2009 08:07 PM
Question Are the Multiplex 2.4 transmitters/receivers going to be sold in US/Canada? Xnaron Hitec/Multiplex USA 2 Feb 12, 2009 09:42 PM
