Old Nov 13, 2012, 08:58 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
When we first started developing the telemetry system for the DX8, I was horrified at how close my models were flying to the edge and I had no idea. They all got updates immediately to make sure the power supplied to the radio and servos was adequate.
Looks like you just came to the same realization!
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 13, 2012, 09:03 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Std aa cells are typically 1 C capability or less .
I redid my cell testing rig yesterday to reduce line losses to minimums and found two (2) amp tests still show at least on volt drop on ENELOOPS (very good AA cells). I actually made two test rigs which wil accept any AA cells - same results - the spring clips work well -no detectabel losses and the new wiring goes directly from spring clips - - beating the cells with a small mallet and turning em to make certain springs were in good contact, - produced no difference in voltage reading UNDER LOAD- - Original voltage losses were in the wiring and connections.
richard hanson is online now Find More Posts by richard hanson
Old Nov 13, 2012, 09:11 AM
Joined Oct 2007
Andy
Wanna borrow an amp/volt meter ?
I gave away my big old meters with a 3x5 inch faces but I have some little stuf left --
Old Nov 13, 2012, 09:43 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Only if they come with a 40-sized Tipo in the box
Which will be two of my building projects again this winter, hopefully. I'm busy cleaning off a workbench that has 5-6 models on it in various states of disrepair or incomplete construction.
Andy
Site Sponsor
Old Nov 13, 2012, 09:50 AM
LatinP is offline
Find More Posts by LatinP
LatinP's Avatar
United States, NY, New York
Joined Oct 2012
Andy is the telemetry in the DX8 the same in the DX7S? I'm in the market for a new radio but the 8 is a bit outside my price point at the moment.
Thanks!
LatinP is offline Find More Posts by LatinP
Old Nov 13, 2012, 09:51 AM
Joined Oct 2007
I will look around - I just cleaned the bench- (used a rake)
Old Nov 13, 2012, 10:27 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Thanks!
I think the DX7s does not support PowerBox, but otherwise they are identical.
Andy
Site Sponsor
Old Nov 13, 2012, 10:51 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Andy
On the edge because of signal strength or voltage supply? And when the voltage goes down, doesn't it hurt the signal strength also?
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 13, 2012, 11:22 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Voltage on the servo bus is what bothered me.
Voltage is regulated internally to both tx and rx for their functions. Digital radio just STOPS when the voltage gets too low. Check the datasheets.
Andy
Site Sponsor
Old Nov 13, 2012, 12:30 PM
MattyB is online now
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
Originally Posted by richard hanson View Post
Not really
Theyare still 1 C cells and unless you are using very low power consumption servos - they can easily fade on you
My original tests on high drain servos were a typical load for a large IMAC model The A123 (the real thing) are still ,easily the best choice.
for higher loads
My point was not that you'd changed your tune on Eneloops (I agree with your assessment they are only good for 1C loadings), but plenty of people criticised the wiring loom and spring battery holder first test - you vigorously defended them at the time, but now it turns out the wiring was a significant contributing factor to the result.
MattyB is online now Find More Posts by MattyB
Old Nov 13, 2012, 01:01 PM
Joined Oct 2007
Yes -BUT it was the wiring n connnector not the spring connectors!
That fooled me -
Old Nov 13, 2012, 05:00 PM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
My grandmother used to say "such things they have now"
Read this about "time-domain transmit beamforming"
http://www.sciencedaily.com/releases...le+Feedfetcher
Piper J3 is offline Find More Posts by Piper J3
Old Nov 13, 2012, 05:07 PM
Rocket Programmer
Joined Jul 2007
Interesting article... but it sounds like a "solution" that doesn't solve the problem. From what I understand it's only full-duplex in the same sense that a time-sharing mainframe is "multi-user"
But I'm sure I misunderstand it, right?
Old Nov 13, 2012, 06:02 PM
crvnation
A moderator felt this post violated the following rule: Redacted Content.
Old Nov 13, 2012, 09:05 PM
didge is offline
Find More Posts by didge
Foam, foam on the range....
didge's Avatar
Adelaide, Australia
Joined Feb 2009
There must be something radically wrong with your technique, if you are measuring a one volt drop at two amps drawn from an Eneloop - there are results similar to those in the link below all over the flashlight enthusiast forums, which show a very much lower voltage drop.
http://www.candlepowerforums.com/vb/...Sanyo-Eneloops
Attached is another graph taken at various rates.
Cheers
didge is offline Find More Posts by didge
Question Throttle linkage frequency with 2.4 GHz? Abrams Beginner Training Area (Fuel) 3 Jul 29, 2012 10:15 PM
Sold Tru Turn 2-3/4" 2-Blade Spinner Combo With Saito 50-91 4-Stroke Double Jam Prop Nut Skywalker14 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 10, 2012 09:14 PM
Help! Frequency selection help please, 5.8 or 900mhz. Need to decide which one to get jasper7821 FPV Talk 12 Mar 15, 2012 04:59 PM
Question Any idea when and if the HF 2.4 module for MPX Evo will be available in US tiju000 Hitec/Multiplex USA 3 Sep 24, 2009 08:07 PM
Question Are the Multiplex 2.4 transmitters/receivers going to be sold in US/Canada? Xnaron Hitec/Multiplex USA 2 Feb 12, 2009 09:42 PM
