Old Nov 12, 2012, 10:30 AM
Joined Sep 2012
Spring type battery holders are not a good solution with rechargeable batteries. Corrosion can easily set in on the spring/battery terminal interface (dissimilar metals). At least with disposable batteries, the spring contacts are scraped clean occasionally when the batteries are replaced and, obviously, the new batteries have clean contact ends. Not so with rechargeable batteries that live their entire lives in a battery holder because they never have to be removed until they ultimately fail. Solder your rechargeable cells directly...
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Nov 12, 2012, 11:25 AM
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
2.4 rx's have lots of blind spots due to antenna orientation, more or less depending on your rx set up. Ive found these blind spots several times and the same one a couple of times. now i run dual sats in everything and dont have the problem anymore.
stoneenforcer is offline Find More Posts by stoneenforcer
Old Nov 12, 2012, 12:06 PM
richard hanson's Avatar
Joined Oct 2007
Originally Posted by MattyB View Post
Interesting - I did some more research found your original thread on Eneloop RX packs. I guess you have have changed your tune on the validity of your original testing setup after all...
Not really
Theyare still 1 C cells and unless you are using very low power consumption servos - they can easily fade on you
My original tests on high drain servos were a typical load for a large IMAC model The A123 (the real thing) are still ,easily the best choice.
for higher loads
richard hanson is offline Find More Posts by richard hanson
Old Nov 12, 2012, 12:22 PM
USA, CA, Chico
Joined Feb 2011
Interesting topic here!! I've had exactly 3 loss of contact issues with my Spektrum receivers in last 3 yrs,, one resulted in loss of a plane,,, all 3 in incidents were with DSM2 receivers operating near a large microwave repeating tower. So far have not had ANY issues with DSMX10,, I suspect my 3 incidents were related to interference from microwave tower and lack of robustness of DSM2 :-(. Just my theory
Airman74 is offline Find More Posts by Airman74
Old Nov 12, 2012, 12:40 PM
Rocket Programmer
jasmine2501's Avatar
United States, CO, Golden
Joined Jul 2007
The problem was still probably a brown-out. In many years of running this stuff, I've never seen a case where I was SURE that interference was the cause, but I've seen hundreds of cases of brown-out problems.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 12, 2012, 06:34 PM
grumpy42's Avatar
Canada
Joined Aug 2004
Hmmm.... Let me get this straight. DSM2 (which has brown-out detection) was being used in an environment with a significant source of 2.4Ghz interference, but somehow it is still likely that brown-outs were responsible for the incidents.
grumpy42 is offline Find More Posts by grumpy42
Old Nov 12, 2012, 07:05 PM
Joined Sep 2012
Jasmine will make a claim like that, but he very often does not back it up with any fact at all. Mostly because he cannot and he knows it. Getting to be quite common, really...
Old Nov 12, 2012, 07:27 PM
Joined Oct 2007
and when it comes to common - I see an expert here .
As all have noted - it helps to have some factual info when attempting to make a rebuttal
I see nothing here which makes J2601's comment implausable
Old Nov 12, 2012, 07:55 PM
Rocket Programmer
Joined Jul 2007
YES. I'm saying flying near a microwave tower doesn't change the chance of having a brown out and it's worth checking because it's the most common cause of failures with 2.4Ghz systems. That is, don't assume you don't have a brown out problem simply because you think you've identified a likely cause, when you have no hard evidence for that cause other than coincidence.
Old Nov 12, 2012, 08:01 PM
Joined Sep 2012
Even though it's been demonstrated that you won't/can't, it would be wonderful if you backed that up with fact, please...for once... Preferably via directly "footnoting" Spektrum design.
Old Nov 12, 2012, 09:58 PM
Joined Oct 2007
Here Stanley -you take this hammer -----and when I nod my head --
Old Nov 12, 2012, 10:12 PM
grumpy42's Avatar
Canada
Joined Aug 2004
But it does increase the change of a lockout - especially with DSM2...
It is easy enough to check considering that DSM2 has brownout detection.
There is no reason to assume that it was a brownout - especially when you have no evidence of that. There were factors involved that make it at least reasonable to consider that a lockout was a likely cause.
Old Nov 13, 2012, 08:14 AM
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Brownout has now become the standard excuse for any system failure in 2.4GHz.
That is strange, as it is just a myth that 2.4GHz systems in general are more prone to brownouts than MHZ systems.
A myth, put forward in order to put those few systems in a better light that really have a problem with low voltages.
Julez is offline Find More Posts by Julez
Old Nov 13, 2012, 08:31 AM
Joined Oct 2007
I have to call you on that -
Past experiences with 72/50/53 mhz show voltage drop is far less of an issue.
None of those will require resetting even if voltages drop below servo operating voltage levels . Servos will slow and operation can become unflyable -but the rx do not stop trying to process.
I used to fly stuff weighing over 40 pounds and I did a lot of checking on battery requirements to keep the huge control surfaces operating.
When 2.4 hit the scene -the power requirements was one of my first questions .
The myth
I know of no myth but factually ALL the 2.4 radios will stop processing info at voltage levels where servos become inoperable . You may see a few tenths volt differences between brands but all of the rx stop and must reset at some point around 3 volts.
Old Nov 13, 2012, 08:54 AM
TRB
United States, TX, Richardson
Joined Oct 2005
I posted this in another thread and just thought it would be interesting to put here. I was having glitch problems on a 72MHz radio due to a weak BEC so I tried scoping the radio voltage rails while moving the control surfaces. The BEC was terrible, but I also found that 2 standard Futaba servos will still suck 4AA Nimh batteries down nearly 1/2 a volt even with no servo binding.
I personally do a lot of robotics and know how big of a deal a good power supply can be for digital circuits, and what kind of funky problems can manifest. I personally did not know how much current RC servos can draw under load. All those years I flew big planes on 4AA Nicad packs, and never thought about it. I'm not sure I consider even a dedicated 4AA pack good enough anymore. I think if I flew big planes I would run a 2xA123 or 5x1/2A cells or something maybe with a good linear 5V regulator.
Daravon is offline Find More Posts by Daravon
Question Throttle linkage frequency with 2.4 GHz? Abrams Beginner Training Area (Fuel) 3 Jul 29, 2012 10:15 PM
Sold Tru Turn 2-3/4" 2-Blade Spinner Combo With Saito 50-91 4-Stroke Double Jam Prop Nut Skywalker14 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 10, 2012 09:14 PM
Help! Frequency selection help please, 5.8 or 900mhz. Need to decide which one to get jasper7821 Video Piloting (FPV/RPV) 12 Mar 15, 2012 04:59 PM
Question Any idea when and if the HF 2.4 module for MPX Evo will be available in US tiju000 Hitec/Multiplex USA 3 Sep 24, 2009 08:07 PM
Question Are the Multiplex 2.4 transmitters/receivers going to be sold in US/Canada? Xnaron Hitec/Multiplex USA 2 Feb 12, 2009 09:42 PM
