http://www.mrrcsound.com |
United States, FL, Miami
Joined Aug 2009
I personally tested a AAA 750mah Eneloop with a battery analyzer and at 1amp discharge it dropped to 1.25v for the cell after a few minutes, which is a higher C-rating discharge than your test. Is it the perfect battery for a receiver pack ? No not compared to a higher discharge/lighter life or lipo. |
The wires on these and on HD receivers andservos are rated for constant 3 amps max. The criteria was to have a pack which stayed well into the 4 volt range under load- this allowed a one volt drop- The ENELOOPS as I noted fell into the high 3 volt range - The ENELOOP discharge chart is not for the same results . There was nothing faulty in the packs . I have at leat 6 of these sets - which I charge on the ENELOOP charger as wel as my ASTRO 12 charger the cells are all in excellent shape. ENELOOP shows the internal resistance to bequite high in these cells - so the results really did not surprise me My DX8 * txs both use these cells and they work very well - weeks between charges. My Canon camera, same - as well as all my tv remotes etc.. |
When load testing batterys, always use the four-terminal-sensing.
http://en.wikipedia.org/wiki/Four-terminal_sensing If this is not done appropriately, the high resistance of the wires, connectors, contacts etc. may fool one into believing that it is the battery which has a high internal resistance. |
Yes -
Iwas trying to do the tests in a manner where others could easily replicate the results The surprise was that both spring holder s had almost identical high resistance in wiring. I still was not satisfied that the ENELOOPS had low enough internal resistance for my use-as rx batts |
These are not meant to be used at 2A, more likely around 200mA in Tx use For a Proper Test make a soldered Rx pack up using suitable wiring for the load you intend applying |
I am glad I retried the test - I will be making a better cell testing setup for the ENELOOPS .
I knew that the crimped connections (std servo leads ) had high resistance but did not expect the total small wire and ends resistance to be as bad as it prooved to be . Easy to see how some guys blamed rx for failure when power delivery was real issue I have a box of extensions made by various mfgrs and in various sizes . Some of these are just junk. To add to the problem- There are now lightweight extensions available - which could easily be adapted as battery power leads . |
United States, TX, Richardson
Joined Oct 2005
Eneloops are very good cells with very good high-current characteristics. Not as good as dedicated high-current, high-capacity cells, but the overall performance considering the low-self-discharge makes Eneloops some of the best Nimh cells out there. I'm powering my Slow stick on 8 Eneloops.
I'm not easily deterred so in the past I have modified AA battery holders with strips of copper between the cells and the springs. It cuts down on the melting but still isn't as good as soldering or spot-welding. |
| Thread Tools | |
| Question Throttle linkage frequency with 2.4 GHz? | Abrams | Beginner Training Area (Fuel) | 3 | Jul 29, 2012 10:15 PM |
| Sold Tru Turn 2-3/4" 2-Blade Spinner Combo With Saito 50-91 4-Stroke Double Jam Prop Nut | Skywalker14 | Aircraft - Fuel - Engines and Accessories (FS/W) | 4 | Apr 10, 2012 09:14 PM |
| Help! Frequency selection help please, 5.8 or 900mhz. Need to decide which one to get | jasper7821 | Video Piloting (FPV/RPV) | 12 | Mar 15, 2012 04:59 PM |
| Question Any idea when and if the HF 2.4 module for MPX Evo will be available in US | tiju000 | Hitec/Multiplex USA | 3 | Sep 24, 2009 08:07 PM |
| Question Are the Multiplex 2.4 transmitters/receivers going to be sold in US/Canada? | Xnaron | Hitec/Multiplex USA | 2 | Feb 12, 2009 09:42 PM |
