Old Nov 03, 2012, 03:36 PM
Dadstoysbg is offline
Find More Posts by Dadstoysbg
Bowling Green,Ky
Joined Sep 2004
I know that Eneloops can't take a hard draw. They will crash. Dennis
Dadstoysbg is offline Find More Posts by Dadstoysbg
Old Nov 03, 2012, 04:14 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
These cells are the multi colors versions with ID # HR-3UTGA min 1900ma I also use earlier white cells .
Read their published specs - they are 1 C type cells .
They are excellent batteries - for their intended use.
They simply will not tolerate much load .
If your model has tiny servos which are correctly setup - you may never have a problem.
but
My own criteria is a pack which partially depleted ,will never drop over one volt on a two amp load.
My A123 1100 ma packs on that test, drop .3 volt.
richard hanson is offline Find More Posts by richard hanson
Old Nov 04, 2012, 05:07 AM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
So if I switch to Spektrum DSMX I won't have any problems whatsoever?? Seems a bold claim....
Simple thing is that most issues are unrelated to signal and most people don't have the understanding or the honesty to properly post analyse a crash....
However as remote as TX and RX failure modes on any given system they do happen...however back to the OP ..... problems that can happen is a broad band of noise being dumped noise that could swamp your signals...as mentioned earlier.....however this can happen to all signals operating within such an area.
DSMX - FHSS - FASST....etc all good systems and each perform adequately for all situations for the most part....the choice should be on what you feel is best suited and what you have faith in due to experience yourself or people/friends you may have that you can share and value their experiences....problem with using a forum is you need to take a lot of it with a pinch of salt...too many people with an axe to grind....or simply offer non factual information or incorrect information due to the fact they have nothing better to do...
Space Bat is offline Find More Posts by Space Bat
Old Nov 04, 2012, 08:17 AM
Joined Oct 2007
Originally Posted by Space Bat View Post
So if I switch to ( your choice here )I won't have any problems whatsoever?? Seems a bold claim....
T'would be nice tho---
Old Nov 04, 2012, 09:35 AM
crvnation is offline
Find More Posts by crvnation
Joined Sep 2012
Sure! Until the next jam-tastic threat comes along. And, it will...eventually...
crvnation is offline Find More Posts by crvnation
Reply With Quote  (Disabled)
Old Nov 04, 2012, 09:49 AM
Joined Oct 2007
Back to real world - 99% of 2.4 problems have no relationship with jammed signals .
This red herring of interferrence is simply a pipe dream raised by those who really can't get power/ antenna setups correct.
Old Nov 04, 2012, 11:36 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Originally Posted by AndyKunz View Post
If only it were that simple! There are areas off to each side that are affected too. It looks more like a bell curve.
A channel isn't a single frequency, it's a continuous band of frequencies between two points. Instead of 1280 think 1260 to 1300 (for the 40MHz he mentioned). Then you double both of them - 2520 and 2600. Then you add on the crap to each side, and it's suddenly very easy to see how they overlap a little.
If you could look at a spectrum analyzer you would see a bell curve that is highest in the 2520-2600 range but still extends outwards some.
Andy
Yeah I kinda knew that I guess. That's what I get for looking at Wikipedia
It lists the center frequency and band width, so I just did some simple math... but yeah you're right, a transmitter sitting on 1280 could be 'using' 1260 to 1300 for frequency modulation.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 04, 2012, 11:38 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Originally Posted by richard hanson View Post
No surprise to me -
A a 4.8 v 750 ma pack -even fully charged is typically far smaller than all but the most tiny servos can use.
I got into a little discussion with a guy on using th 2000ma ENELOOPS as rx packs - he said -they sell em as rx packs and they work.
In testing them using Horizon ampmeter set on 2 amps - -each pack of four I tested (I have a bunch of latest ENELOOP) dropped instantly from 5.5 v to 3.8 aprox-that is a 1.7 volt drop!
As long as users persist in using cells with little ability to resist voltage depression- the problem with "rx failure" will just keep on going.
I don't expect the problem to go away-
I beg to differ.
For several years, I fly my 3.2m F3B plane with a 4.8V eneloop pack. All digital servos, and the ones in the wings are amazingly cheap chinese ones.
Last eastern, the plane lay in the snow for 2 hours, then I took it for a long flight and some DS, and even when I came in for landing and pulled the butterly brake, I had not the slightest problem. I fly Jeti and have the telemetry set to 4.2V warning or so.
In my experience, Eneloops work well while being frozen in my biggest plane with power-hungry servos.
Julez is offline Find More Posts by Julez
Old Nov 04, 2012, 01:13 PM
Joined Oct 2007
Originally Posted by Julez View Post
I beg to differ.
OK- but that does not alter my test results
As you know test results and theories may not appear same as actual practice results - I tested a bunchof my batteries - all the same and even using different meters same results They ARE 1 c batteries -- read the mfgrs specs . Thats where I got the info.
Old Nov 04, 2012, 02:43 PM
Joined Sep 2012
Yeah, Wiki's a real, ahem, "reliable" source for your "footnoting". But, not unexpected. Not at all. Typical, really...
Old Nov 04, 2012, 02:46 PM
Joined Sep 2012
Exactly. Sanyo Eneloops work just fine. Their new XX batteries are even better for high current drain applications. Don't get as many charge cycles out of them as the older versions, though.
Old Nov 04, 2012, 03:15 PM
Joined Oct 2007
Objectively - the xx are still, 25 Mohm and the highest current rating I can find is at.1000ma .
They are 1C cells ,period -if you feel that is enough for your application -fine by me.
I like far more overhad under load - a 1100ma A123 pack is far better in maintaining voltage under load .
In that the prime reason for 2.4 failure is power failure - I Be preparred to run into problems if your servos really draw power .
Old Nov 04, 2012, 03:43 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Sorry jasmine. The guy has no shame and poor moral character. Looks as if he may be trolling you now. Gives me a break for a few days at least.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Nov 04, 2012, 05:40 PM
Rocket Programmer
Joined Jul 2007
All I see is a blank space. Ignoring someone is the best policy. I only see his posts when somebody quotes them.
Old Nov 04, 2012, 06:54 PM
Joined Sep 2012
You click on "view post" and you know it. We all do.
Question Throttle linkage frequency with 2.4 GHz? Abrams Beginner Training Area (Fuel) 3 Jul 29, 2012 10:15 PM
Sold Tru Turn 2-3/4" 2-Blade Spinner Combo With Saito 50-91 4-Stroke Double Jam Prop Nut Skywalker14 Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 10, 2012 09:14 PM
Help! Frequency selection help please, 5.8 or 900mhz. Need to decide which one to get jasper7821 FPV Talk 12 Mar 15, 2012 04:59 PM
Question Any idea when and if the HF 2.4 module for MPX Evo will be available in US tiju000 Hitec/Multiplex USA 3 Sep 24, 2009 08:07 PM
Question Are the Multiplex 2.4 transmitters/receivers going to be sold in US/Canada? Xnaron Hitec/Multiplex USA 2 Feb 12, 2009 09:42 PM
