I hate getting jammed
http://youtu.be/FcArnepkhv0?t=13s |
Scott |
I can't do that on my fingers - so I will accept that stepping on someones frequency and killing it is jus a pipe dream-
I still adamantly believe thta 99%of the failures attributed to rx lockout are simply screw ups on the part of the user. I spent a few years doing Beta testing on new gas engines for an importer - very informative . Those that "got it" never had a moments trouble -those who had a better idea on how to setup engines were constantly burning em up. or shaking things to pieces or wrecking ignitions - on n on. This radio stuff is the same thing all over again - in Spades. |
![]() I use a 50mW 5.8g system myself, and it works just fine. Until I fly behind a tree or something I have a friend who uses 1280 or 5.8 depending on what he's doing, and the filters definitely help.Andy |
Bowling Green,Ky
Joined Sep 2004
I'm going to tell a story about someone that was blasting Spektrum on the internet.He said that his receiver lost bind. Horizon sent him another one. It wouldn't bind either. horizon told him to send in the radio to have it checked and he was mad.
I'm a dealer and sell all the brands and I think I have a good working knowledge of how all the systems work. I sent him a PM to call me so I could help. I went thru the binding process step by step and sure enough no bind. The following is our conversation to find what the problem was. ME what battery are you using? HIM A 4.8 750ma. Me when was the last time you flew? HIM two weeks ago and everything worked. ME How many flights? HIM 5 flights ME Can you check the voltage? HIM how do you do that? ME When did you charge the battery last? HIM Do I have too? ME Charge the battery over night and try the bind again in the morning and call me. The next day he calls to tell me after the charge everything was working again. Told me no one had told him about charging the batteries. He never went back to his thread and told people why the radio lost bind. No more posts. Just another example of how Spektrum "looses bind" without the truth being told. Dennis |
No surprise to me -
A a 4.8 v 750 ma pack -even fully charged is typically far smaller than all but the most tiny servos can use. I got into a little discussion with a guy on using th 2000ma ENELOOPS as rx packs - he said -they sell em as rx packs and they work. In testing them using Horizon ampmeter set on 2 amps - -each pack of four I tested (I have a bunch of latest ENELOOP) dropped instantly from 5.5 v to 3.8 aprox-that is a 1.7 volt drop! As long as users persist in using cells with little ability to resist voltage depression- the problem with "rx failure" will just keep on going. I don't expect the problem to go away- |
Two times 1280 is 2560. Doesn't the 2.4GHz band go from 2350 to 2550? |
but to tell you the truth I have flown many times with my 1280 video running and no lowpass filter, while other folks fly Spektrum all around me and no issues detected. This is coming from that rare instance within the wider FPV comunity, not my personal experience. Of courseI have heeded the warning and keep the lowpass filter on there nowadays. |
A channel isn't a single frequency, it's a continuous band of frequencies between two points. Instead of 1280 think 1260 to 1300 (for the 40MHz he mentioned). Then you double both of them - 2520 and 2600. Then you add on the crap to each side, and it's suddenly very easy to see how they overlap a little. If you could look at a spectrum analyzer you would see a bell curve that is highest in the 2520-2600 range but still extends outwards some. Andy |
| Thread Tools | |
| Question Throttle linkage frequency with 2.4 GHz? | Abrams | Beginner Training Area (Fuel) | 3 | Jul 29, 2012 10:15 PM |
| Sold Tru Turn 2-3/4" 2-Blade Spinner Combo With Saito 50-91 4-Stroke Double Jam Prop Nut | Skywalker14 | Aircraft - Fuel - Engines and Accessories (FS/W) | 4 | Apr 10, 2012 09:14 PM |
| Help! Frequency selection help please, 5.8 or 900mhz. Need to decide which one to get | jasper7821 | Video Piloting (FPV/RPV) | 12 | Mar 15, 2012 04:59 PM |
| Question Any idea when and if the HF 2.4 module for MPX Evo will be available in US | tiju000 | Hitec/Multiplex USA | 3 | Sep 24, 2009 08:07 PM |
| Question Are the Multiplex 2.4 transmitters/receivers going to be sold in US/Canada? | Xnaron | Hitec/Multiplex USA | 2 | Feb 12, 2009 09:42 PM |
