Well, lets say that the plane didn't make to a calm day.
This week the new servos arrived so I decided to rebuild the jet and fix some issues. I really hope this v2.0 will be better. We will know tomorrow after I try to fly it.
I am adding some pictures now, and will add the video later, if the plane flies.
This is an Orange 6ch DSM2 Rx. I've removed the housing. It will be held within the wing to eliminate any air resistance that it could create otherwise.
The new servos are much more powerful and accurate than the original ones. The EDF unit is mounted further back than in the previous version and there is less space at the front and the back of the unit.
The ESC is also within the wing in order to avoid addition wind resistance.
This is how I will be mounting the batteries, so I wouldn't have to tape them down on every flight. The velcro strap goes under the carbon rod and wraps around the battery.
The nose turned out good and solid, I hope it will be able to handle some nose first crashes (but I hope there will be none). The 15mm fiber tape is a good size for 6mm depron since it goes from side to side without being too much and adding to the weight.
The ESC is now fixed in place with some fiber tape, a small opening is left for cooling.
On the other side, the Rx is also fixed with fiber tape. The new servos had really short wires, so I had to make an extension for the right servo.
The battery mounted with velcro, which has been cut to size.
I expected it would be heavier than the previous version, but was really surprised when it turned out that it weights only 100 grams (6 grams less than the previous one). The difference comes from the battery - the Zippy 2s 500mah is 3 grams lighter than the Turnigy 2s 500mah. Also, the Rx without the housing weights about 3 grams less than my Graupner Rx (the one in the previous version) with the housing. There is also considerably less tape on hinges and edges.
