Old Dec 13, 2012, 08:29 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Originally Posted by RW9UAO View Post
at now, i think, dsmX frequency hopping question is finish.
Code:
#include <stdio.h>
  DSMX channels list for Frequency Shift Hopping
  math by Alexandr Alexandrov
  code by Sergey Gimaev
  some function (like RadioSetFrequency) from Cypress old assember lib for CYRF transivers
  they used in OrangeRX DSM2 6 channel and AR6110 clone receiver
int main(void){
unsigned int manufacturerID = 0x92C65809;//inverted 0x6D39A7F6;
//manufacturer ID - this is what we see in the first 4 bytes of BIND package
unsigned int calc;
unsigned int channel;
int c = 0, k, part1 = 8, part2 = 7, part3 = 8, flag = 0;
unsigned char channel_list[23];
    for(k = 0; k < 23; k++){
        channel_list[k] = 0xFF;//init channel list
    calc = manufacturerID;//init randomize function
    do{
        calc *= 0x0019660D;//randomize function
        calc += 0x3C6EF35F;//from wiki, liniux, gcc, etc
        channel = calc >> 8;
        channel = channel % 0x49;
/*1.If the 4-byte ManID - even ("0" in the low-bit), then the channel
should be the same even (or odd for odd 4th byte ManID).
If he's not - continue (calc generate in the next number.)*/
//i need to compare last bit in manufacturerID and last bit in channel for both even/odd
        if((unsigned char)(channel & 1) == (unsigned char)(manufacturerID & 1)){
/*2. If the channel coincides with any of the already obtained earlier numbers
channels in the array, то continue */
                if(channel_list[k] == (channel + 3)){flag = 1; k = 0xFF;}
                else    flag = 0;
            if(flag == 0){
                flag = 1;
/*3. Check to which subband channel is ( 0..24, 25..48 или 49..72 ).
At the beginning of the work - to get 3 counters (for each sub-band) and set them in 8, 7 and 8
(7 - a counter for subband 25 .. 48). In which sub-band channel - check to see if 0
already in the appropriate counter. If 0 - continue*/
                if(channel < 25){
                    if(part1){
                        part1--;
                        flag = 0;
                }else{
                    if(channel < 49){
                        if(part2){
                            part2--;
                            flag = 0;
                    }else {
                        if(part3){
                            part3--;
                            flag = 0;
                if(flag == 0){
/*Procedure returns, then we add to that 4 (as opposed to 2 for DSM2),
and this will RadioSetFrequency, which takes another one and write to the transceiver.*/
//i don`t use Cypress lib, write my self to CYRF. coz i need +3
                    channel_list[c] = channel + 3;//поэтому +3
                    printf ("0x%.2x ", channel + 3);
                    c++;
    }while(c < 23);
    return 7;
sorry, coments in code in russian
Don't be offended, save little time for them that understand it
SadSack is offline Find More Posts by SadSack
Old Dec 13, 2012, 08:39 AM
RW9UAO is offline
Find More Posts by RW9UAO
RW9UAO's Avatar
Russian Federation, Kemerovskaya oblast, Kemerovo
Joined Dec 2012
some check. i wrote channel scanner, bind my dsmX receiver and scan.
first i calc channels on PC program:
0x0f 0x13 0x09 0x4b 0x29 0x23 0x3b 0x2d 0x25 0x33 0x3d 0x17 0x31 0x35 0x07 0x43 0x19 0x37 0x21 0x03 0x45 0x41 0x05
and scan (i broken my AR8000 and can not connect SPI grabber to him)
bind my rx to DX8:
Code:
CYRF
bind
Bind RX ok 0x92C6580A
21 7A [92C6-580A-92C6-580A-04E4-0108-B200-0687]
tx bind
normal
scan:
Code:
0F 7B [A7F5-A6AA-0156-3C00-FFFF-FFFF-FFFF-FFFF]
17 7B [A7F5-A6AA-0156-3C00-FFFF-FFFF-FFFF-FFFF]
21 7A [A7F5-0B2A-2C00-13EE-1C02-3400-FFFF-FFFF]
29 7A [A7F5-A6AA-0156-3C00-FFFF-FFFF-FFFF-FFFF]
31 7B [A7F5-0B2A-2C00-13EE-1C02-3400-FFFF-FFFF]
33 7B [A7F5-0B2B-2C00-13EE-1C02-3400-FFFF-FFFF]
35 7A [A7F5-A6AA-0156-3C00-FFFF-FFFF-FFFF-FFFF]
37 7B [A7F5-A6AA-0156-3C00-FFFF-FFFF-FFFF-FFFF]
3D 7B [A7F5-0B2A-2C00-13EE-1C02-3400-FFFF-FFFF]
45 7A [A7F5-A6AA-0156-3C00-FFFF-FFFF-FFFF-FFFF]
03 7B [A7F5-A6AA-0156-3C00-FFFF-FFFF-FFFF-FFFF]
05 7B [A7F5-0B2A-2C00-13EE-1C03-3400-FFFF-FFFF]
0F 7A [A7F5-0B2A-2C00-13EE-1C02-3400-FFFF-FFFF]
17 7A [A7F5-0B2A-2C00-13EE-1C02-3400-FFFF-FFFF]
21 7B [A7F5-0B2A-2C00-13EE-1C02-3400-FFFF-FFFF]
29 7B [A7F5-A6AA-0156-3C00-FFFF-FFFF-FFFF-FFFF]
31 7A [A7F5-A6AA-0156-3C00-FFFF-FFFF-FFFF-FFFF]
33 7A [A7F5-A6AA-0156-3C00-FFFF-FFFF-FFFF-FFFF]
channel num, rx_irq_status(at now i ignore CRC_SEED and have a CRC error bit) and packet body.
RW9UAO is offline Find More Posts by RW9UAO
Old Dec 13, 2012, 09:10 AM
PhracturedBlue is offline
Find More Posts by PhracturedBlue
Joined Jan 2012
You guys are truly incredible. That code seems to work well on everything I've thrown at it.
PhracturedBlue is offline Find More Posts by PhracturedBlue
Old Dec 13, 2012, 01:01 PM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
Does it mean, that deviation will support DSMX soon?
FDR_ is offline Find More Posts by FDR_
Old Dec 13, 2012, 08:32 PM
Joined Jan 2012
This has nothing to do with Deviation (though I'll likely implement it). I already had sufficient knowldege to implement a DSM-X transmitter. This is sufficient to implement a receiver though.
Old Dec 13, 2012, 08:47 PM
Joined Jan 2012
FYI, here is the pseudo-code representing the function of the posted code:
Code:
foreach idx in (0 .. 22):
  ok = 0
  while(ok is 0):
     id_tmp = id_tmp * 0x0019660D + 0x3C6EF35F   ## Randomization
     next_ch = ((id_tmp >> 8) MODULO 49) + 3      ## Use least-significant byte and must be larger than 3
     if (next_ch is odd and ID is even OR next_ch is even and ID is odd)
       AND none of the values in the 'ch' array are equal to next_ch:
         if 3 <= tmp < 28 and the number of channels in ch that are between 3 and 28 is < 8
           OR 28 <= tmp < 52 and the number of channels in ch that are between 28 and 52 is < 7
           OR 53 <= tmp and the number of channels in ch that are greater than 53 is < 8:
               ok = 1
  ch[idx] = next_ch
Old Dec 13, 2012, 09:03 PM
RW9UAO is offline
RW9UAO's Avatar
Joined Dec 2012
it`s Polishinel`s secret
mistake. next_ch calculating, checking and put in to list. 3 added before write to CYRF. you moved borders, you cheked code?
Old Dec 13, 2012, 09:14 PM
RW9UAO is offline
RW9UAO's Avatar
Joined Dec 2012
at now i have worked code for:
dsm2/dsmX 10/11 bit 11/22 ms receiver/transmitter and all telemetry, like GPS, S-sensor, current, powerbox, etc...
i have one question: why Orange not release cheap dsm2 telemetry and cheap dsmX rx/tx (not for last bugged odd job with 10 fixed IDs)? HorizonHobby promised to kill oranges?
Old Dec 13, 2012, 09:58 PM
Joined Jan 2012
Pretty sue it is right. I moved all bounds checks by 3.
Edit: I guess I missed one, but should be ok now
Old Dec 13, 2012, 10:25 PM
tignmeg is offline
Find More Posts by tignmeg
Registered Adict
tignmeg's Avatar
Australia, WA, Drummond Cove
Joined Jun 2012
Orange have a DSMX receiver. Not for sale yet though.
https://www.facebook.com/photo.php?f...type=3&theater
tignmeg is offline Find More Posts by tignmeg
Old Dec 13, 2012, 10:26 PM
RW9UAO is offline
RW9UAO's Avatar
Joined Dec 2012
it`s old picture. where in shop?
Old Dec 13, 2012, 10:30 PM
tignmeg is offline
Registered Adict
tignmeg's Avatar
Joined Jun 2012
You are correct it is not in the shop yet
Old Dec 14, 2012, 01:49 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Now that it seems like the DSMX hopping scheme has been cracked, receivers should follow.
And perhaps they will be able to do a proper job on their tx module
pmackenzie is online now Find More Posts by pmackenzie
Old Dec 14, 2012, 01:53 AM
RW9UAO is offline
RW9UAO's Avatar
Joined Dec 2012
where our medals?
Old Dec 14, 2012, 01:58 AM
SadSack is offline
Joined Aug 2008
Order-of-Glory
Sold DSMX DX-8 and (2) DSMX Sats for Sale laughingstill Aircraft - General - Radio Equipment (FS/W) 3 Jan 20, 2012 11:24 AM
Wanted JR9503 DSMX or JR 11X DSMX and AR9200/AR9210 Receiver w/sats patrick21x Aircraft - General - Radio Equipment (FS/W) 0 Nov 17, 2011 10:22 PM
Discussion WALKERA 2.4 TX hack -can YOU hack it? aaronstomfoolery Radios 2 Oct 29, 2011 04:44 AM
Sold NNIB AR6210 DSMX w/sat + AR600 DSMX GeetarJoe Aircraft - General - Radio Equipment (FS/W) 0 Oct 19, 2011 01:50 AM
