Old Nov 27, 2012, 04:57 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Could the difficulty in finding the DSMX jumping sequence be what caused Orange to issue a DSMX capable TX module that needed the ability to change its GUID.
A.
AndyOne is offline Find More Posts by AndyOne
Old Nov 27, 2012, 07:35 AM
PhracturedBlue is offline
Find More Posts by PhracturedBlue
Joined Jan 2012
A.
I don't know anything about the Tx module, but it is very likely the same issue (and why they don't sell an Rx). Can you point me at the GUID change procedure? How many different options do you have?
PhracturedBlue is offline Find More Posts by PhracturedBlue
Old Nov 27, 2012, 08:33 AM
vlad_vy is offline
Find More Posts by vlad_vy
Joined Dec 2011
It's unknown. Press the Change ID button a few seconds, then you hear a beep, means this module's ID changed, release the button.
http://www.hobbyking.com/hobbyking/s...2X39217X54.pdf
vlad_vy is offline Find More Posts by vlad_vy
Old Nov 27, 2012, 05:53 PM
printk is offline
Find More Posts by printk
Joined Jul 2009
I guess what happen to Orange TX module is that, they have a limited pool of preset
GUID and matching jumping sequence. You press the key it will rotate to the next one.
I am curious to find out how many different GUID are there in the Orange TX module.
It is a bit tricky to ready back the TX GUID though. Currently I use the receiver to trace
the SPI. I don't know there is other ways to show the GUID of TX without taping the
SPI.
I have an idea to capture other TX's GUID in deviation firmware. We just need to
make the devo TX module listen to the bind packet and display the GUID on the LCD
screen.
printk is offline Find More Posts by printk
Old Nov 27, 2012, 06:31 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Yet another reason not to buy one!
I wonder if they even bothered to make sure their GUIDs are unique from real Spektrum ones, or could I get shot down by someone with an Orange module
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Nov 27, 2012, 09:03 PM
hammer22 is offline
Find More Posts by hammer22
United States, NH, Exeter
Joined Oct 2010
I was going to say what printk did about the Orange module probably having a set of pre-programmed known good GUIDs and corresponding hopping patterns to select from when you press the ID change button. I too wonder how many they decided to code into the module. I'd definitely be worried about one Orange module user shooting another Orange module user down!
printk, you've done some really nice work so far in analyzing the DSMX hopping patterns and I was sorry to hear that your Walkera TX module is semi-toasted. I have a bunch of brand new Walkera modules and I would be happy to give one to you. PM me with your address and I'll mail it to you.
hammer22 is offline Find More Posts by hammer22
Old Dec 01, 2012, 03:35 AM
printk is offline
Joined Jul 2009
Hammer22, thanks for the offer of the walkera TX. I have 2 TX module just
for experimenting. So I am fine with the TX module. Plus that one I open is
actually in the working order for experiment, just not install into the Devo TX.
I call that a feature without the amplify. I really appreciate the offer though.
It seems hammer22 and I are often think alike :-)
I haven't able to make much new progress on the DSMX though. I want to
come up with a theory to explain why the channel are more likely to jump to
its own zone then then other zone. I come up with a few theory like own zone
has one less channel to chose from (can't jump to the same channel).
But it does not match the number I found.
Also the chance of the channel stay within the middle zone is slightly higher
than channel stay within the high or low zone. I don't have a theory can match
that number either.
I attach the first 64k jumping sequence I capture with my MCPX receiver.
Open the zipfile there is one binary file and one python file.
Just run the following command should give you a full list of
the guid. I store the guid in binary to save some space.
Code:
python read-guid.py guid-00000000-1.bin
I hope some one else can come up with some new idea why
why the DSMX slight favour to stay within the same zone.
Old Dec 04, 2012, 12:48 PM
Kambalunga is offline
Find More Posts by Kambalunga
Kambalunga's Avatar
Deutschland, Hessen, LA
Joined Jan 2009
DSMX use not only different sets of channels. DSMX use different hopp time and alternating spreading codes.
http://www.flyelectric.ukgateway.net/24scanner.htm
Kambalunga is offline Find More Posts by Kambalunga
Old Dec 04, 2012, 01:44 PM
printk is offline
Joined Jul 2009
I have upload receiver side spi trace of the cyrf chip. That should show the usage of channel very well. It is repeating every 22ms. The receiver can send back telemetry data, that happen every other channel which might explain the different timing you saw on the air.
Old Dec 05, 2012, 02:34 AM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
Hi. That page is mine. I know more now than I did when I put that up. I don't think the different hop timing is correct. I will fix the page. DSMX does use different spreading codes but that has already been explained.
Regards, David.
David T is offline Find More Posts by David T
Old Dec 06, 2012, 06:20 AM
pmackenzie's Avatar
Joined Dec 2002
Quick questions- Does the model match number combine with the GUID produce a new hopping sequence?
If not, does the mismatch in the model number prevent the receiver from locking on to a transmitter with the same GUID but a different model number?
Some of the info on this thread and the DSM2 protocol suggests that the GUID is offset by the model match number.
Trying to figure out how bad the Orange DSMX implementation really is
Pat MacKenzie
Old Dec 06, 2012, 09:20 AM
printk is offline
Joined Jul 2009
My understanding is, model match number will produce a new GUID.
However, this new GUID is still 32 bit, so it might smash into some
other GUID. At least in theory that is possible, unless there is some
thing clever in the GUID selection to avoid that. e.g. Cypress can
leave some room between each GUID so make sure each GUID
offset some range will not become another valid GUID.
Of course, the new GUID will have a different hopping sequence.
Old Dec 06, 2012, 11:36 AM
hammer22 is offline
Joined Oct 2010
Its important to note that the real GUID of the radio is, as printk says, a 32 bit value which the receiver learns at bind time. 16 of those bits are the actual GUID that is transmitted as the first 2 bytes of every data packet sent. It is those 2 bytes that are modified with the model match number. The other 16 bits become a pair of CRC seed values used to build the checksum of each data packet. This also aids in making sure the receiver only receives packets from the correct transmitter because it will reject the packet if the CRCs do not match. The CRC seed values do not change with the model match number.
So a Spektrum radio with 50 model memories actually had 50 different GUIDs; one for each model memory slot.
The way Spektrum handles the model match number is to take the base radio GUID, (model memory 1 actually has a model match number of 0, model memory 2 has model match value 1 etc...) and XOR that with the single byte model match number. The new GUID that is produced is used any time that particular model memory is selected.
The DSMX frequency hopping algorithm appears to use the entire 32 bit GUID to calculate the hopping pattern.
Old Dec 06, 2012, 11:57 AM
pmackenzie's Avatar
Joined Dec 2002
Thanks guys, that is sort of what I understood.
Pat MacKenzie
Old Dec 13, 2012, 07:22 AM
RW9UAO is offline
Find More Posts by RW9UAO
RW9UAO's Avatar
Russian Federation, Kemerovskaya oblast, Kemerovo
Joined Dec 2012
at now, i think, dsmX frequency hopping question is finish.
Code:
#include <stdio.h>
  DSMX channels list for Frequency Shift Hopping
  math by Alexandr Alexandrov
  code by Sergey Gimaev
  some function (like RadioSetFrequency) from Cypress old assember lib for CYRF transivers
  they used in OrangeRX DSM2 6 channel and AR6110 clone receiver
int main(void){
unsigned int manufacturerID = 0x92C65809;//inverted 0x6D39A7F6;
//manufacturerID - это то, что видим в первых 4-х байтах BIND пакета
unsigned int calc;
unsigned int channel;
int c = 0, k, part1 = 8, part2 = 7, part3 = 8, flag = 0;
unsigned char channel_list[23];
    for(k = 0; k < 23; k++){
        channel_list[k] = 0xFF;//init channel list
    calc = manufacturerID;//init randomize function
    do{
        calc *= 0x0019660D;//randomize function
        calc += 0x3C6EF35F;//from wiki, liniux, gcc, etc
        channel = calc >> 8;
        channel = channel % 0x49;
/*1.Если 4-й байт ManID - чётный ( "0" в младшем бите ), то и channel
должен быть таким же чётным ( или нечётным для нечётного 4-го байта ManID ).
Если он не такой - continue  ( генерируем в calc следующее число ).*/
//i need to compare last bit in manufacturerID and last bit in channel for both even/odd
        if((unsigned char)(channel & 1) == (unsigned char)(manufacturerID & 1)){
/*2. Если channel совпадает с каким-либо из уже полученных ранее номеров
каналов в массиве, то continue */
                if(channel_list[k] == (channel + 3)){flag = 1; k = 0xFF;}
                else    flag = 0;
            if(flag == 0){
                flag = 1;
/*3. Проверяем, к какому поддиапазону channel относится ( 0..24, 25..48 или 49..72 ).
В начале работы - завести 3 счётчика ( для каждого поддиапазона ) и задать в них 8, 7 и 8
( 7 - в счётчике для поддиапазона 25..48 ).  В каком поддиапазоне channel - проверяем, не 0 ли
уже в соответствующем счётчике. Если 0 - continue*/
                if(channel < 25){
                    if(part1){
                        part1--;
                        flag = 0;
                }else{
                    if(channel < 49){
                        if(part2){
                            part2--;
                            flag = 0;
                    }else {
                        if(part3){
                            part3--;
                            flag = 0;
                if(flag == 0){
/*Процедура вернёт, потом к этому ещё прибавится 4 ( в отличие от 2 для DSM2 ),
и с этим вызовет RadioSetFrequency, в которой отнимет ещё 1 и запишет в трансивер.*/
//i don`t use Cypress lib, write my self to CYRF. coz i need +3
                    channel_list[c] = channel + 3;//поэтому +3
                    printf ("0x%.2x ", channel + 3);
                    c++;
    }while(c < 23);
    return 7;
sorry, coments in code in russian
RW9UAO is offline Find More Posts by RW9UAO
Sold DSMX DX-8 and (2) DSMX Sats for Sale laughingstill Aircraft - General - Radio Equipment (FS/W) 3 Jan 20, 2012 11:24 AM
Wanted JR9503 DSMX or JR 11X DSMX and AR9200/AR9210 Receiver w/sats patrick21x Aircraft - General - Radio Equipment (FS/W) 0 Nov 17, 2011 10:22 PM
Discussion WALKERA 2.4 TX hack -can YOU hack it? aaronstomfoolery Radios 2 Oct 29, 2011 04:44 AM
Sold NNIB AR6210 DSMX w/sat + AR600 DSMX GeetarJoe Aircraft - General - Radio Equipment (FS/W) 0 Oct 19, 2011 01:50 AM
