Old Jan 13, 2013, 08:54 PM
RW9UAO is offline
Find More Posts by RW9UAO
RW9UAO's Avatar
Russian Federation, Kemerovskaya oblast, Kemerovo
Joined Dec 2012
RF frontend is OK. i change receiver. same.
in a short range channel hopping work good. on (my software) transmitter channel hopping work good. at last a hour. i grab channel list from AR8000 and compare to my channel list. all corect.
orange 6 ch hardware copied from original spektrum. satellites copied to. 7 and 9 channel dsm2 orange receivers look like a own orange make. spektrum does not use xmega and NUVOTON M054LAN cpu.
RW9UAO is offline Find More Posts by RW9UAO
Old Jan 13, 2013, 10:11 PM
hammer22 is offline
Find More Posts by hammer22
United States, NH, Exeter
Joined Oct 2010
RW9UAO,
I think I see an error in your CYRF6936 init code:
CYRF_write(0x9D, 0x01);// - wr MODE_OVERRIDE_ADR = RST
for(temp = 0; temp < 20; temp++)asm("nop");
CYRF_write(0xA8, 0x02);// - wr CLK_EN_ADR = RXF
CYRF_write(0xB2, 0x3C);// - wr AUTO_CAL_TIME_ADR = 0x3C
CYRF_write(0xB5, 0x14);// - wr AUTO_CAL_OFFSET_ADR = 0x14
temp = CYRF_read(0x0D);// - rd IO_CFG_ADR
CYRF_write(0x8D, temp | 0x40);// - wr IO_CFG_ADR = IRQ POL ; Set IRQ polarity to positive.
temp &= ~0x10;//XOUT as GPIO
--> shouldn't this be CYRF_write(0x8D, temp | 0x04)?
CYRF_write(0x0D, temp | 0x04); //From Devo - Enable PACTL as GPIO
--> and shouldn't this be CYRF_write(0x8E,0x00)?
CYRF_write(0x0E, 0x00); //From Devo
CYRF_write(0x86, 0x48);// - wr RX_CFG_ADR = LNA | FAST TURN EN
CYRF_write(0x9B, 0x55);// - wr TX_OFFSET_LSB_ADR
CYRF_write(0x9C, 0x05);// - wr TX_OFFSET_MSB_ADR
CYRF_write(0x8F, 0x2C);// - wr XACT_CFG_ADR = FRC END | Synth Mode (RX)
CYRF_write(0x83, 0x3F);// - wr TX_CFG_ADR = 64 chip codes | SDR Mode | +4 dBm
CYRF_write(0x92, 0x0E);// - wr DATA64_THOLD_ADR = 0x0E
--> Here too
CYRF_write(0x0C, 0xC0);// - wr XTAL_CTRL_ADR XTAL - GPIO
CYRF_write(0x8F, 0x0C);// - wr XACT_CFG_ADR = Synth Mode (RX)
hammer22 is offline Find More Posts by hammer22
Old Jan 14, 2013, 03:02 AM
RW9UAO is offline
RW9UAO's Avatar
Joined Dec 2012
hi. it`s not a problem.
void CYRF_write(unsigned char reg, unsigned char value){
M8C_SetBank0;
SS_Data_ADDR &= ~SS_MASK;
while( ! (SPIM_1_bReadStatus() & SPIM_1_SPIM_TX_BUFFER_EMPTY ) );
SPIM_1_SendTxData(reg | 0x80);
Old Feb 25, 2013, 11:36 PM
Tomf35 is offline
Find More Posts by Tomf35
Joined Jun 2011
Nothing for many days.
Any progress, which can be announced?
Thanks.
Tomf35 is offline Find More Posts by Tomf35
Old Feb 26, 2013, 08:32 PM
RW9UAO is offline
RW9UAO's Avatar
Joined Dec 2012
yes. my receiver work fine. LemonRX say they did dsmX receiver, hextronic too. now i work for dsmX telemetry.
Old Mar 01, 2013, 08:18 PM
Tomf35 is offline
Joined Jun 2011
Thanks, RW9UAO.
Kindly provide future development/success/progress etc if possible.
Old Mar 02, 2013, 10:04 AM
donato.jun is offline
Find More Posts by donato.jun
Joined Mar 2011
@RW9UAO - What do I need to compile and run this code on my Orange RX?
The Orange RX R615, R620 and R910 are compatible?
Thanks. This is a amazing work
donato.jun is offline Find More Posts by donato.jun
Old Apr 07, 2013, 04:24 PM
randmental is offline
Find More Posts by randmental
South Africa, GP, Centurion
Joined Oct 2012
Bump
randmental is offline Find More Posts by randmental
Old Apr 11, 2013, 01:05 PM
TuMadre is offline
Find More Posts by TuMadre
Silly n00b
TuMadre's Avatar
United States, NC, Charlotte
Joined Sep 2011
Subbed
TuMadre is offline Find More Posts by TuMadre
Latest blog entry: 808 Camera pays for itself!
Old Apr 18, 2013, 08:46 AM
Felixrising is offline
Find More Posts by Felixrising
has an opinion
Felixrising's Avatar
Australia, VIC, Southbank
Joined Jan 2013
Looks like the Spektrum guys think you may have missed something.. http://www.rcgroups.com/forums/showp...&postcount=373
Felixrising is offline Find More Posts by Felixrising
Old May 01, 2013, 10:12 PM
MAVA is offline
Find More Posts by MAVA
MAVA's Avatar
El Dorado Hills, California, U.S.A.
Joined Mar 2000
Just a thought ???
Gentlemen,
I had a light-bulb moment to get this bind-code?
Now, I'm not software guy, I'm AC/DC guy(move current around-the analog way...)
I know Tomf35 is salivating for the code or some DIY data, so he can make some PCB's, and several others here are drooling for a DIY process to DIYing for some DSMXing...
Question, Could the bind "codes(locking data) be captured by the software that decodes over-air WIFI WEP network keys? Read this:
http://www.makeuseof.com/tag/crack-w...find-insecure/
The software is BackTrack 5 that does this, and all the major torrent sites have this software, but the piece of hardware that is needed to sniff-out is WIFI adapter capable of packet injection.
http://lifehacker.com/5305094/how-to...with-backtrack
Would this work? Possible?
I did a google search of the following phrase:
How to crack a WEP network.
Martin
MAVA is offline Find More Posts by MAVA
Old Aug 06, 2013, 06:13 PM
Imho is offline
Find More Posts by Imho
Imho's Avatar
Hobart, Tasmania.
Joined Jan 2005
Subscribed.
Imho is offline Find More Posts by Imho
Old Sep 26, 2013, 05:01 AM
Sp1k3 is offline
Find More Posts by Sp1k3
Joined Mar 2011
Hi,
Ive been wanting to read out on my DSM2 Rx Orange the RSSI, I know the rf IC stores the RSSI digitally and can be read out be SPI. Would it be possible to read it out and send it to the battery input signal line as a PWM signal that with a low pass filter I can make it analog?
Sp1k3 is offline Find More Posts by Sp1k3
Old Sep 30, 2013, 11:47 PM
Imho is offline
Imho's Avatar
Hobart, Tasmania.
Joined Jan 2005
Originally Posted by Sp1k3 View Post
Hi,
I'm pretty sure what you suggest could be done but I think this project went closed-source at some stage and you're unlikely to see much more here.
Old Oct 01, 2013, 06:03 AM
darkith is offline
Find More Posts by darkith
Canada, NB, Fredericton
Joined May 2002
Is that what happened? Shame...
D.
darkith is offline Find More Posts by darkith
Sold DSMX DX-8 and (2) DSMX Sats for Sale laughingstill Aircraft - General - Radio Equipment (FS/W) 3 Jan 20, 2012 11:24 AM
Wanted JR9503 DSMX or JR 11X DSMX and AR9200/AR9210 Receiver w/sats patrick21x Aircraft - General - Radio Equipment (FS/W) 0 Nov 17, 2011 10:22 PM
Discussion WALKERA 2.4 TX hack -can YOU hack it? aaronstomfoolery Radios 2 Oct 29, 2011 04:44 AM
Sold NNIB AR6210 DSMX w/sat + AR600 DSMX GeetarJoe Aircraft - General - Radio Equipment (FS/W) 0 Oct 19, 2011 01:50 AM
