Old Feb 14, 2013, 01:21 PM
skydanz is offline
Find More Posts by skydanz
Sky's not the limit, ground is
skydanz's Avatar
United States, CA, Grass Valley
Joined Dec 2007
Ditto. Anything over 3 mph will spinup nicely on its own.
skydanz is offline Find More Posts by skydanz
Old Feb 14, 2013, 01:27 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Well there's a problem....we "never" have wind over 3mph at the SCCMAS.....
SteveT.
Yeah right!!!!
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 14, 2013, 01:44 PM
Tom Wright is offline
Find More Posts by Tom Wright
Tom Wright's Avatar
Joined Feb 2012
Just an update on my Auto-G head and rotor mods .
The depron parts of the blades have been replaced with balsa , the blade root tags are now cut off and a new bolt hole made 12 mm in from the root and 18 mm from the l/e .
The blades are mounted on a 0.8 mm gf tri plate and the two servos have been replaced with a single MG .
The origional shims were used resulting in good spin up in light winds and the model still performs well ,but is now far more robust ,and I think the low speed performance is better than ever.
Tom.
Tom Wright is offline Find More Posts by Tom Wright
Old Feb 14, 2013, 03:54 PM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Originally Posted by Sammy70 View Post
If you have a decent wind you won't need the leafblower. I take about 5-6 brisk steps into the wind while at 3/4 throttle and she just flys away without issue...
I am 63 with bad knees, hence the leaf blower idea.
One thing I noticed today when installing the larger wheels was that there was quite a bit of "toe in" on both wheels. I always prefer a bit of "toe out" on tail draggers. Perhaps this could be attributing some of the ROG issues?
Rickochet is offline Find More Posts by Rickochet
Old Feb 14, 2013, 04:36 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Toe in is actually best for tail draggers.....at least that is what I have been told, and I have had a few planes that didn't handle well on the ground, as soon as I bent some toe in into the gear, they handled much better..... YMMV...
And, I feel for you on the knees... I am 62 with one failed right knee replacement, and the other one is giving me fits also....
SteveT.
Old Feb 14, 2013, 10:30 PM
TURBOOMNI is offline
Find More Posts by TURBOOMNI
Trailer Down By The River
Joined Sep 2004
Has anyone posted any info on how much down and right thrust the motor has from the factory??
TURBOOMNI is offline Find More Posts by TURBOOMNI
Old Feb 15, 2013, 06:29 AM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
BLADE GRIP IN STOCK as well as all replacement parts for the Auto-G..... Both USA Warehouse & GLOBAL if anyone is in need of 'em:
http://www.hobbyking.com/hobbyking/s...arehouse_.html
rcoconut is offline Find More Posts by rcoconut
Old Feb 15, 2013, 06:50 AM
Aeronut41 is offline
Find More Posts by Aeronut41
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Tks for the heads up!, Just ordered some back up blades Best, Aero
Aeronut41 is offline Find More Posts by Aeronut41
Old Feb 15, 2013, 08:31 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Me too, just in case of dumb thumbs.
Old Feb 15, 2013, 08:33 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
SteveT.
I guess I will just leave the toe in as is. I am sure that if there is an issue my expert piloting skills will bail me out.
I thought the OEM wheels might be too small for my grass soccer field so I installed some 3" wheels. This will change the relative angle of the rotor disc and I wondered if there would be any negative or positive issues during an ROG takeoff?
Old Feb 15, 2013, 11:35 AM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
If anything the bigger wheels will only help matters IMO...
Sammy70 is offline Find More Posts by Sammy70
Old Feb 15, 2013, 12:33 PM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Bugger!!
Had put them in my cart whilst still on backorder but left the order till I could think of some cart 'fillers' that I wasn't in a hurry for.
Now they've come and gone (again).
Oh well.......will have a backorder in for when they next appear
EDIT...oops. Was looking through the link at the USA store. Still available at the HK store.
Thanks for the headsup!!!!!
Goody63 is offline Find More Posts by Goody63
Old Feb 15, 2013, 03:49 PM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Got the AG finished today. Overall I am very pleased with the quality of the kit. All of the parts were there and fit well. There were also some extra small parts, glue and a screw driver. Does anyone know what kind of glue is in the tube? I used FoamTac on mine and didn't open it.
For those who haven't built one yet I will suggest three things.
1. Everything is in plastic bags. Make sure you carefully open each bag. The bag with the h-stab clamps on mine had two nuts loose I just happened to find before I chucked the bag.
2. Before tightening down the clamps on the h-stab center your servos and silde the stab up or back on the fuse tube to match the clevices with the control surfaces straight. The fuse tube on mine sticks out about 1/16" past the rear clamp. The clevices are adjustable and you might have to make a few turns in or out.
3. Put safety bands on all of the clevices. These pop open easier than any I have ever dealt with.
Here is "Otto." Pretty much stock except for the 3" wheels and tooth pick shear pins in the blades.
Old Feb 15, 2013, 10:43 PM
fritz2460 is offline
Find More Posts by fritz2460
Australia, QLD, Maleny
Joined Jul 2005
tooth pick mod
Hi folks,
would somebody please point me in the direction the above.
Mine is ready to go as soon as the weather clears. The field I fly in is not suitable for ROG so I will leave the UC off but place some weight in the slot for the UC to maintain the CofG it weighs 30gm.
Ray
fritz2460 is offline Find More Posts by fritz2460
Old Feb 15, 2013, 11:30 PM
rcoconut is offline
rcoconut's Avatar
Joined Sep 2006
Originally Posted by fritz2460 View Post
Hi folks,
Ray
Read this post from Sammy70:
http://www.rcgroups.com/forums/showp...&postcount=361
Good luck, hope to re-maiden mine Tues
Help! Slow-g slow stick auto gyro HyperHelis Auto Gyros 4 May 23, 2012 08:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 05, 2006 11:27 PM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 07:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 02:35 PM
