Old Jan 26, 2013, 07:07 PM
xairflyer is offline
Find More Posts by xairflyer
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
Originally Posted by TURBOOMNI View Post
I am sure many just put the blades on without any balancing and it works fine. But I bet even with the low headspeeds that if everything is nicely balanced there maybe an improvement with a smoother machine and perhaps better headspeed and better acceration of the head in wind. I do know it is not good on a rc helicopter to not care about the cg and put tape at the end of the blade to balance. When run up they will still be out of balance.
Yes agree, the snag with this is there is so much play in the head, with the fit of the bearings in the holder and the bolt itself in the bearing. I shimmed the bolt with fine washers and used a 3mm nyloc nut which helped a bit.
Will see how it goes and if I dont like it I will have to do the normal CG blade balance as well.
xairflyer is offline Find More Posts by xairflyer
Old Jan 26, 2013, 07:51 PM
rusty case is offline
Find More Posts by rusty case
KlonWarz
Joined Dec 2012
lol
I am newbie!
what is 'normal CG blade balance' ? :-)
all I know is balancing 2 blade fixed props for tractor nitro planes.
rusty case is offline Find More Posts by rusty case
Old Jan 27, 2013, 05:38 AM
Bleriot's R Us
xairflyer's Avatar
Ireland, Donegal
Joined Nov 2003
When balancing helicopter blades you would always weigh and balance each blade to find the CG position of the blade, i.e. where it would balance if put flat on a knife edge.
If for example (extreme conditions) if all the weight was at the tip of one blade and all at the root of another, but their overall weight was the same, they still would balance ok doing a static balance as shown above with the brushless motor.
However because the dynamic balance is way out, the helicopter would still vibrate and shake.
So ideally what you want is to have all three blades weighing the same and each blade CG point in the same position.
So if you have one light blade it may be better to add the weight to the middle of the blade rather than at the tip.
The blades of the big wind turbines and some fullsize helicopters have moveable weight engineered into the blade, this can be screwed up and down the blade to adjust the balance.
There are loads of info about model helicopter blade balancing, do a search on google sometimes seeing it done makes it better to understand.
Old Jan 27, 2013, 10:54 AM
KlonWarz
Joined Dec 2012
Thanks, X.
Well, yah caught me being lazy, I guess...
186,412 hits in .0942 seconds...
I was hoping someone would say, 'I did a video on balancing rotor blades (HERE)' :-)
but I get distracted, and side-tracked... was looking at some FPV build vids and had to press a button for Top Tracks for Jimi Hendrix.... I think I'll let it run 'til it ends... :-)
then, I'll search further for the balancing vid.
rc
Old Jan 27, 2013, 03:42 PM
TURBOOMNI is offline
Find More Posts by TURBOOMNI
Trailer Down By The River
Joined Sep 2004
Yes to what Xairflyer said. You want the weight of the blades to be the same but just as important the weight distribution of the blades must also be the same before you actually balance them.. Say you want to balance two blades. One is twice as heavy as the other and most of the heavy blade's weight center is near the bolt hole. The lighter blade's weight center is much further out. You don't check the CG and you just put put it on a balancer. You add weight to the light blade at the tip and it balances out perfect but in reality the light blade is still way lighter than the heavy one.
I also put a spacer from my Trex 450 parts bin and finished off with a nylock nut to take out the slop of the rotor head bolt. too bad it is so cold as I have yet to maiden the bird.
TURBOOMNI is offline Find More Posts by TURBOOMNI
Old Jan 27, 2013, 09:26 PM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Blade Balancing
500-Class Radio Control Helicopter Assembly : Radio Control Helicopter: Balance Blades (4 min 26 sec)
Goody63 is offline Find More Posts by Goody63
Old Jan 27, 2013, 09:52 PM
KlonWarz
Joined Dec 2012
That's it!
Thanks Goody!
rc
Old Jan 27, 2013, 10:14 PM
Joined Sep 2004
well as long as you guys get it there is no excuse,,,,,,
Old Jan 28, 2013, 07:26 AM
Goody63 is offline
Goody63's Avatar
Joined Apr 2008
Originally Posted by rusty case View Post
That's it!
Thanks Goody!
rc
No probs mate.
Good luck with the build.
Old Jan 30, 2013, 10:21 AM
Aeronut41 is offline
Find More Posts by Aeronut41
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Kermit Takes Over
While the snow continues to fall and the maiden flight is delayed till more favorable conditions I have plenty of time to waste playing with my Auto-G Decided that the AG is missing a pilot so drafted Kermit to take over those duties. He is pretty light so hopefully the CG won't be too far forward. Not sure about the additional side area but he is stuck on with Velcro so can be quickly grounded if that presents a problem! Anyway, he looks cute sitting in the "cockpit" battery hatch Best, Aero
Aeronut41 is offline Find More Posts by Aeronut41
Old Jan 30, 2013, 10:33 AM
KlonWarz
Joined Dec 2012
kermag is Great!
Old Jan 30, 2013, 10:44 AM
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Well, we'll find out how good his or my AG piloting skills are when the weather breaks
Old Jan 30, 2013, 10:55 AM
KlonWarz
Joined Dec 2012
Sry mod...
Old Jan 30, 2013, 11:23 AM
mark675 is offline
Find More Posts by mark675
scale microlights
mark675's Avatar
midlands uk
Joined Sep 2004
just got 2 of these auto-g's
got one for spares cus the blades were out of stock,
looking forward to testing it the weekend
mark675 is offline Find More Posts by mark675
Old Jan 30, 2013, 02:45 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Mark
Don't loose it in the snow........white on white..........
Happy Landings
Chris................
britinoz is offline Find More Posts by britinoz
Help! Slow-g slow stick auto gyro HyperHelis Auto Gyros 4 May 23, 2012 08:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 05, 2006 11:27 PM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 07:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 02:35 PM
