Old Jan 09, 2013, 10:35 AM
Tom Smith is online now
Find More Posts by Tom Smith
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
Does HK use PayPal. I ordered from them once several years ago and 20 minutes later got a call from my credit card company saying someone in the UK was buying stuff with my card. Coincidence, who knows. I haven't ordered from them since.
Tom Smith is online now Find More Posts by Tom Smith
Old Jan 09, 2013, 12:41 PM
Aeronut41 is offline
Find More Posts by Aeronut41
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Yup!
Aeronut41 is offline Find More Posts by Aeronut41
Old Jan 09, 2013, 02:48 PM
Ken Lilja is online now
Find More Posts by Ken Lilja
I'm slow but I'm expensive
Ken Lilja's Avatar
United States, GA, Snellville
Joined Nov 2003
This is interesting. One could place some solder inside at the leading edge to help chord-wise balance or weight the blades.
Ken
Originally Posted by Tom Wright View Post
Aero
I made a new set of blades for my Auto- G by sloting 1/8" balsa into the black plastic leading edge. The step was filled in with 1mm balsa .
Tom.
Ken Lilja is online now Find More Posts by Ken Lilja
Old Jan 09, 2013, 04:15 PM
TURBOOMNI is offline
Find More Posts by TURBOOMNI
Trailer Down By The River
Joined Sep 2004
Just ordered one this morning using PayPal from the USA warehouse. Although I didnt order any spare parts. I figure I have time later cause it,s freezing here. What spare parts you guys recommend to have on hand??
TURBOOMNI is offline Find More Posts by TURBOOMNI
Old Jan 09, 2013, 05:21 PM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Rotor Blades & that Rotor Blade Grip, but seems like some of the guys are making their own blades as well as a blade grip
rcoconut is offline Find More Posts by rcoconut
Old Jan 09, 2013, 05:23 PM
rcoconut is offline
rcoconut's Avatar
Joined Sep 2006
And did you guys happen to catch this from Nightflyer:
Durafly Auto-Gyro Copter Mods, Tips, and Heavy Wind test. (10 min 0 sec)
Old Jan 09, 2013, 07:08 PM
Tom Wright is offline
Find More Posts by Tom Wright
Tom Wright's Avatar
Joined Feb 2012
Ken
Don't see why not although I used 1.5 mm piano wire as it's easy to push down the plastic l/e section., if replacing the depron blade rear section make sure the overall chord is as original, or a little more. My blades are mounted on a 0.8 mm gf delta plate which makes the set up very robust .
Oh forgot to mention that the servos are not metal gears as Scott said they would be, have now replaced mine with MG90 .
Tom.
Tom Wright is offline Find More Posts by Tom Wright
Old Jan 10, 2013, 02:56 AM
Gyrocopter is offline
Find More Posts by Gyrocopter
What could possibly go wrong!!
In Bedfordshire, UK.
Joined Oct 2008
Don't see why not although I used 1.5 mm piano wire as it's easy to push down the plastic l/e section., if replacing the depron blade rear section make sure the overall chord is as original, or a little more. My blades are mounted on a .08 mm delta plate which makes the set up very robust .
Tom.
Hi Tom,
I assume thats 0,8mm plate, I used 1,0mm plate on my Firefly and it works fine, sometimes you just have to use what is to hand
Chas
Gyrocopter is offline Find More Posts by Gyrocopter
Old Jan 10, 2013, 10:32 AM
rusty case is offline
Find More Posts by rusty case
KlonWarz
Joined Dec 2012
Has anyone yet replaced the dual servo with a single MG servo?
I have not seen discussion on this possibility.
Are two servos only for redundancy?
Would a stronger arm be required on the rotor head mech?
DO the servos conflict with each other for centering and throw?
Tnx
rc
rusty case is offline Find More Posts by rusty case
Old Jan 10, 2013, 10:01 PM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Tnx
rc
Yes i am considering putting a mg14 in mine.
aeromaniac is offline Find More Posts by aeromaniac
Old Jan 11, 2013, 03:58 AM
Dangerous Dick is offline
Find More Posts by Dangerous Dick
Dangerous Dick's Avatar
Cheshire, England
Joined Mar 2001
The rods used on the aileron control are too weak for push and pull individually, the 'stock' control is pretty much pull only - might as well be using closed loop wire instead!
The gears take some punishment in the little servos in a 'tip over' so MG is a good idea but I think you'd struggle with just one servo.
Best thing to do (not always practical I know!) is not to tip it over or bump it and you'll be fine with the ones which come with it
Just as a side note - I've put a layer of 'cross-weave' packing tape top and bottom on my latest 'Y' plastic piece with the thought of it adding a little strength and at least holding onto the blade should the plate get brittle and break. Should make crashing a little less painful?
Cheers,
Richard.
Dangerous Dick is offline Find More Posts by Dangerous Dick
Old Jan 11, 2013, 08:54 AM
KlonWarz
Joined Dec 2012
OK, that's a start!
MG is called for, and, a quality pushrod.
...I think what it is, is that I'm adverse to two independent servos mechanically connected to the same arm, with opposing functions and possibly different response times and centering.
Yet it apparently works well enough for the Auto-G to be a success...
Does the Ciervo use one servo only for each direction it's head moves?
...and as a side note... :-) Which component of the rotor disk do you wish to be the sacrificial link, Dick? The Y, the blades, the head, or the tower?
I am NEWBIE, don't yet even own an Auto-G, yet I'm able to consider the options...
Has anyone installed a Ciervo head on an Auto-G yet?
There's room for two servos! :-)
rc
Old Jan 11, 2013, 10:12 AM
Ken Lilja's Avatar
Joined Nov 2003
Single roll servo
I had a roll servo that was making strange a noise. So I have replaced the 2 servos with a single HS-85MG buried in the fuselage. The pushrod is 2-56 with a carbon tube over it. The servo has 42 in.oz. torque. What I am worried about is the strength of the arm on the head. It is not a reinforced plastic.
I will be putting the last of the paint on it today and will try to post some pictures.
Music wire in the blades. I hadn't thought of that. The problem with solder is that it is easy to stretch and that changes it's diameter. Might be hard to get a consistent weight.
Now to really over complicate things: Replacing the depron in the blades might lead to an opportunity to build some twist into the blades. It is supposed to be WASH IN
Ken
Tnx
rc
Old Jan 11, 2013, 03:06 PM
Tom Wright's Avatar
Joined Feb 2012
Ken
I don't think twisting the blade will be of any benefit at all , as they spin up very easily .
Chas.
Thanks for spotting my typo , my Auto-G delta plate is 0.8 mm thick.and not .08 as posted.
All
Lots of air time with my single servo (MG-90) Crane Fly does suggest a single servo conversion on the Auto-G would work well .Although a rod from both ends of the arm would be preferable ,it would be interesting to try one carbon rod ,as the original servo position could still be used.I have replaced the factory servos with MG 90 although other metal geared servos will also do the job.
Tom.
Old Jan 11, 2013, 11:14 PM
Glow 😡 no no no
Joined Mar 2010
I damaged my Auto G today and need new blades, it was my fault, I think I slowed it up tomuch on a downwind leg and it rolled left into the dirt.
Help! Slow-g slow stick auto gyro HyperHelis Auto Gyros 4 May 23, 2012 08:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 05, 2006 11:27 PM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 07:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 02:35 PM
