I already have a bucket of 1300 packs and a spare receiver, and the model is in a warehouse in my country, but I dont know..
The last time I bought something that lasted 5 to 7 minutes (nano EDF jet) it was a bit of a letdown, I kept having to deadstick it home because the liposaver kept kicking in.
Motor City USA
Joined Mar 2007
I was out just a few minutes ago....19 deg F and 10+ mph....she flies well once you have that headwind to get the rotors moving. Had 4 good flights. One bad landing after loss of orientation tested the toothpick fix...worked as planned. Replaced em right at the snow covered frozen field and back into the air (this is going to be a major blade saver for me when there are incidents). I did however break a blade off the propellor....cold plastic and she snapped right off. Without a spare prop, I dug into my bag of props I have in my vehicle and found that the Parkzone P51 prop works perfectly (I knew that already based on the motor being the same as the original Art Tech P51 that I also use this prop on). Better performance and better balanced. Thumbs up on this this alternative if you do not have a spare Durafly prop. All in all, after my failed initial attemps and delays...finally I was able to enjoy this unique aircraft. So far, I really enjoy it. I am in for a spare. Good fun. |
though im not fond of having to swap out a pack every 5 circles. ![]() Sadly I do, a little nanojet. So much fun to fly, but if I had a penny for every time I had to go look for it in some crop field next door, I could buy an auto-G. ![]() To me, 5 minutes just isnt enough to "get into it", you know? |
Motor City USA
Joined Mar 2007
Joined Feb 2012
My Auto- G has been converted to a 3" 0.8 mm delta plate as shown in the post above, this has elliminated the problem of replacing the flapping membraine. I cut the blade roots in half to use the inner hole,and used the origional wedges . The model flew fine on the first test flight ,but I suspect further improvements could be had by bringing the blade cog forward a little .
Tom. |
Austria
Joined Jan 2004
Just find the cierva head back in stock at HK
It is a perfect upgrade for this auto.g Here you can get for 50 cent extra discount: http://www.hobbyking.com/buddy.asp?c...7-064E91B5196D |
Do you simply use the 'upper head-blade grip' part to replace the stock Auto-G one? |
| Thread Tools | |
| Help! Slow-g slow stick auto gyro | HyperHelis | Auto Gyros | 4 | May 23, 2012 08:14 PM |
| Sold Zenoah G-23 w/muffler and FEMA auto start | LotusTRBO | Aircraft - Fuel - Engines and Accessories (FS/W) | 1 | Jul 05, 2006 11:27 PM |
| Discussion Xero G Auto. | epc2 | Electric Heli Talk | 2 | Apr 01, 2006 07:08 PM |
| Video Xero G Auto. | epc2 | Electric Heli Talk | 0 | Apr 01, 2006 02:35 PM |
