Old Nov 24, 2012, 11:28 PM
beaverbuddy is offline
Find More Posts by beaverbuddy
New Zealand, Canterbury, Christchurch
Joined Sep 2011
Just putting in my $0.02:
As delivered,the rotor head on mine had a distinct lean to the left,so check this before 1st flight.One rod was also slightly bent,so this was removed and straightened.
The rudder and elevator pushrods were too long,so i put a little kink in it:
I fitted slightly larger wheels,as well as a locknut under the rotor top disk.Also replaced one of the screws on each blade with a toothpick.
I'm not confident about the magnets holding the battery hatch down,so i fitted an external latch:
I really would like a steerable tail wheel,but I'll try it as is first.
Finally,a couple of pics of the gyro in it's finished state:
beaverbuddy is offline Find More Posts by beaverbuddy
Old Nov 24, 2012, 11:31 PM
Joined Sep 2011
Actually,those wheels still look a bit small.May need to go up another couple of sizes.
Old Nov 24, 2012, 11:49 PM
Joined Sep 2011
Forgot to mention,test ran the motor.
16.4A and 184W on a 1300mah 3-cell pack.
Old Nov 25, 2012, 02:27 AM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Not quite sure of the set up on this motor ....but all that exposed motor shaft is just asking to be bent. It is usually best to keep the prop,hard up to the motor,as the prop touching the deck is always going to bend the shaft...........
Good Luck
Chris..................
britinoz is offline Find More Posts by britinoz
Old Nov 25, 2012, 03:59 AM
Scott Cuppello is offline
Find More Posts by Scott Cuppello
Commercial UAV Pilot
United Kingdom, England, Carlisle
Joined Mar 2007
Erm, isn't that U/C in the wrong way round?
Scott Cuppello is offline Find More Posts by Scott Cuppello
Old Nov 25, 2012, 04:16 AM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Yes that's the wrong way round, they should be raked forwards.
Mine has 60mm diameter wheels on and I spread the wire out a bit more to help with ground handling.
Did my first loops Friday, really easy to do ... just gather speed and pull back on the elevator. Tracks straight through the loop as well
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Nov 25, 2012, 04:29 AM
Paul 1968 is offline
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
Rich
Have you rolled it yet? I tried yesterday, it went over but it was certainly "interesting". Great fun though, I'm really enjoying mine as my first autogyro. I guess I'm smitten, I have a rotorshape on the way now too .
Paul 1968 is offline Find More Posts by Paul 1968
Old Nov 25, 2012, 04:55 AM
Joined Dec 2007
No I haven't ....not brave enough as the roll control doesn't seem that responsive. I am give it a go this afternoon.
Will try and get some video.
Rich
Old Nov 25, 2012, 08:09 AM
PeterO_UK is offline
Find More Posts by PeterO_UK
PeterO_UK's Avatar
Joined Aug 2006
You may find it useful to look at my pages on Rotorshape build/modifications. Some tips there on strengthening some parts and adding a rudder.
http://www.peteronion.org.uk/Autogyros/index.html
PeterO_UK
PeterO_UK is offline Find More Posts by PeterO_UK
Old Nov 25, 2012, 08:18 AM
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
PeterO_UK
Seen it and bookmarked already PeterO, actually it's your fault I ordered it! I will be making the rudder modification and probably larger wheels for ROG takeoffs.
Old Nov 25, 2012, 08:22 AM
PeterO_UK's Avatar
Joined Aug 2006
You'll be wanting plans for a Minimum next then ?
PeterO_UK
Old Nov 25, 2012, 08:29 AM
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
My wife says you mustn't encourage me . I might have to sneak it in on the QT!
Paul
Old Nov 25, 2012, 12:39 PM
scott page is offline
Find More Posts by scott page
Left RCG because of Trolls
Joined May 2009
Good Luck
First thing I did was spin the motor on high and use a cutoff wheel (spinning opposite direction) to cut the shaft right below the threads. Then put a 4mm collet on the shaft -- and since I'm paranoid about compression collets I used red locktite to assist holding the collet in place.
scott page is offline Find More Posts by scott page
Latest blog entry: Making my own tray
Old Nov 25, 2012, 01:47 PM
ask21! is offline
Find More Posts by ask21!
Be here now!
ask21!'s Avatar
Rome,Ciampino
Ok, i really got and headache thinking about what appens to my auto-g:
I'm using a 1800 3s lipo. Maiden it and what i found was that to fly straight without tendencies to go up or down at 1/3 motor, my elevator is down trimmed.
Using a bigger lipo, what i expected was to have up elevator.
ask21! is offline Find More Posts by ask21!
Old Nov 25, 2012, 02:17 PM
skydanz is offline
Find More Posts by skydanz
Sky's not the limit, ground is
skydanz's Avatar
United States, CA, Grass Valley
Joined Dec 2007
I've flown three of them and they all have a bit of down trim. The horizontal stab and elevator almost looks like a semi-symmetrical airfoil with a flatter bottom, if that makes sense. The battery is so close to the CG, I doubt the few extra grams would require any trim. I mount a GoPro camera to the mast structure and I can barely feel the difference.
I can think of a few odd reasons to have more down with a nose heavy AG, probably due to increased speed for the weight, but you never know with these little devils.
Don
skydanz is offline Find More Posts by skydanz
Help! Slow-g slow stick auto gyro HyperHelis Auto Gyros 4 May 23, 2012 08:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 05, 2006 11:27 PM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 07:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 02:35 PM
