Old Nov 22, 2012, 08:02 PM
kydawg1 is offline
Find More Posts by kydawg1
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
......they are back in stock at HOBBY KING.
kydawg1 is offline Find More Posts by kydawg1
Old Nov 23, 2012, 07:24 AM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
I added a head button on my order due to it spinning off into the grass on the second flight. Everything else is back in stock but that. It's holding up my shipping. ARRRRGGGG
ducatirdr is offline Find More Posts by ducatirdr
Old Nov 23, 2012, 08:31 AM
Mud Duck Bill is offline
Find More Posts by Mud Duck Bill
Mud Duck Bill's Avatar
Up State New York , USA
Joined Mar 2009
No kidding is that PeterO, Hi Peter I haven't seen you post something in a very long time good to see you are still in the wings keeping an eye on things.
Bill
Mud Duck Bill is offline Find More Posts by Mud Duck Bill
Old Nov 23, 2012, 02:32 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Just use a locking nut. The button is just for looks in my opinion and is an accident waiting to happen since it doesn't lock on like a locking nut does...
Sammy70 is offline Find More Posts by Sammy70
Old Nov 23, 2012, 02:40 PM
Flying_Flair is offline
Find More Posts by Flying_Flair
United Kingdom, England, Hemel Hempstead
Joined Feb 2010
You can take it off your order, sometimes you are given that option if you look at your order, other times you have to use the online support and quote your order number. They give you the money difference back in your points.
I've done it a few times
Malcolm
Flying_Flair is offline Find More Posts by Flying_Flair
Old Nov 23, 2012, 02:44 PM
Paul 1968 is offline
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
My second Auto G turned up today, maiden will be tomorrow, preferably away from Piper Cubs . This second one seems to run smoother and quieter, probably just a better prop. I've sent a little time balancing the blades this time so should fly smoother, not that the first one was bad. Number one model flew great hence the replacement. Forecast in my area tomorrow is cloudy with 5mph wind...............................Perfect, but I would have preferred a little more breeze.
Paul 1968 is offline Find More Posts by Paul 1968
Old Nov 23, 2012, 04:32 PM
Ken Lilja is offline
Find More Posts by Ken Lilja
I'm slow but I'm expensive
Ken Lilja's Avatar
United States, GA, Snellville
Joined Nov 2003
The blade rotating in the direction of flight produces more upward force due to a higher local airspeed than a blade that is rotating opposite the direction of flight. The blade assumes an angle from the otherwise flat disc the blades would form rotating about the shaft. This is because of the balance between lifting force of the blade and centrifugal force is no longer in equilibrium. I think this is the actual "coning angle". The hinge allows the blade with more upward force to bend upward. This limits the rolling tendency. Now for the neat part. Notice that the hinge is at an angle to the span of the blade. The effect of this is to lower the angle of attack of the rising blade, cutting down on the lift imbalance. Sight down a blade and bend it up at the hinge. You can see the change in blade angle. I think this is called a "Delta hinge" or Delta 3 hinge"
The fact that the hinge has stiffness dampens the system.
Some early gyros had cables that held the blades up when not rotating. There may have been up stops to, but I would bet that very bad things would have happened if the blade hit one. How the blades tracked was strictly a function of lift vs. centrifugal force.
Ken
Originally Posted by scott page View Post
What's the effect on flight?
Ken Lilja is offline Find More Posts by Ken Lilja
Old Nov 23, 2012, 04:49 PM
PeterO_UK is online now
Find More Posts by PeterO_UK
PeterO_UK's Avatar
Joined Aug 2006
I'm just off to bed so no time now to correct the misunderstandings in your description Ken. Most of all you seem to be ignoring the gyroscopic effects that mean the difference in lift between advancing and retarding (3 and 9 o'clock) blades causes nose up pitch not roll. Coning causes no imbalance between blades at these positions, but does cause imbalance between the blades at the 6 and 12 o'clock positions which causes roll.
PeterO
PeterO_UK is online now Find More Posts by PeterO_UK
Old Nov 23, 2012, 05:03 PM
Ken Lilja's Avatar
Joined Nov 2003
The gyroscopic effects have always tripped me up. 90 degrees from the location the force is applied in the direction of rotation. On my first helicopter (Schluter Heli Baby) I rigged the controls 90 degrees from how they should have been. I figured that it was a translation error from the German. I still can't do more than hover after 35 years I look forward to learning how the gyroscopic force effect an auto gyro.
Ken
Old Nov 24, 2012, 04:04 AM
norup is offline
Find More Posts by norup
norup's Avatar
Denmark, Capital Region of Denmark, KBH
Joined Jul 2009
Ken, what you are describing here is called flapping. This will cause an overall tilt of the flat rotor disc.
An autogyro has to support its own weight by the lift of the blades. Try lifting an autogyro in the blade tips, and they will bend upwards a lot. Coning is the resulting angle from the balance of this upwards pull and the centrifugal force that will tend to flatten the disc. The centrifugal force strongly depends on the rate of rotation. Due to the relatively low RPM of an autogyro compared to most helicopters, the coning angle will be larger on the autogyro.
norup is offline Find More Posts by norup
Old Nov 24, 2012, 04:38 AM
Jockadopolus is online now
Find More Posts by Jockadopolus
Jockadopolus's Avatar
Scotland
Joined Jan 2010
Video
オートジャイロ  Auto-G 初フライト (5 min 34 sec)
Jockadopolus is online now Find More Posts by Jockadopolus
Old Nov 24, 2012, 08:25 AM
ducatirdr's Avatar
Joined Aug 2006
I went to remove the head button this morning from my order and saw that the head piece went back order again. It appears that due to my head button back order the Y's were not held in reserve for my order. So my order could never process if things are never are all in stock at the same time. So much for "reserved" status.
Anyone order an extra Y head piece and want to make my day?
Old Nov 24, 2012, 08:58 AM
Scotland
Joined Jan 2010
Video
"NightFlyying" the Durafly Auto-G Autogyro with Flight tips from NightFlyyer. (7 min 32 sec)
Durafly Auto-G Gyrocopter 箱出しフライト (4 min 44 sec)
Old Nov 24, 2012, 01:33 PM
Mt.Flyer is offline
Find More Posts by Mt.Flyer
United States, CO, Frisco
Joined Jul 2010
Anyone order an extra Y head piece and want to make my day?[/QUOTE]
I really need one to. I made one out of plastic like people have been describing, but I'm unsure. The one I made is a bit more flexible than the original.
Wish they would get back in stock
Mt.Flyer is offline Find More Posts by Mt.Flyer
Old Nov 24, 2012, 02:25 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
If it's too flimsy just make a 2nd one and double them up...
Help! Slow-g slow stick auto gyro HyperHelis Auto Gyros 4 May 23, 2012 08:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 05, 2006 11:27 PM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 07:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 02:35 PM
