Old Nov 21, 2012, 09:40 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Instead of the spinning rotor blades remaining in a completely flat plane, they flex upwards slightly creating a slight "V" shape...
Sammy70 is offline Find More Posts by Sammy70
Old Nov 21, 2012, 09:49 PM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
What's the effect on flight?
scott page is offline Find More Posts by scott page
Old Nov 21, 2012, 10:09 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
When the spinning blades begin to lift the heli/autogyro they cone upward due to the weight of the aircraft pulling down on the central mast.
A little coning is similar to adding dihedral to a flat wing.
There's more to it than that, but that's all I remember from A&P school
Old Nov 21, 2012, 10:22 PM
skydanz is offline
Find More Posts by skydanz
Sky's not the limit, ground is
skydanz's Avatar
United States, CA, Grass Valley
Joined Dec 2007
A very basic explanation would be that it has a similar effect as dihedral. There is a lot of other aerodynamic phenomena going on but that's boring stuff to read.
skydanz is offline Find More Posts by skydanz
Old Nov 22, 2012, 10:40 AM
norup is offline
Find More Posts by norup
norup's Avatar
Denmark, Capital Region of Denmark, KBH
Joined Jul 2009
On coning and other stuff, you should read mnowell129's excellent detailed explanations in the thread Gyrocopter Aerodynamics
As I recall, we need the head to flex in order to allow the blades to flap and to allow for a control equivalent to cyclic on a heli, without large forces on the servos. Flapping is required to cancel out the difference in lift between the blades moving at different airspeeds in the headwind.
Coning is a different thing and is not really wanted - it reduces stability and efficiency. This is why you often have lead near the blade tips to make the centripetal force reduce the coning.
Anyway, this is a can of worms that I am not really qualified to discuss, so listen to Mick Nowell.
norup is offline Find More Posts by norup
Old Nov 22, 2012, 11:16 AM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
How do you locate the spares for the Auto-G? I've tried the search function but I'm either not putting in the correct description or whatever. Would be nice if HK put a link to the various spare parts available on the same page as the model description.
GBR2 is offline Find More Posts by GBR2
Old Nov 22, 2012, 11:39 AM
alfoot is offline
Find More Posts by alfoot
Keep it simple
alfoot's Avatar
Salisbury,England
Joined Jan 2005
Here you go:-
http://www.hobbyking.com/hobbyking/s...1mm_Parts.html
Al
alfoot is offline Find More Posts by alfoot
Old Nov 22, 2012, 01:00 PM
Commander Clumsy is offline
Find More Posts by Commander Clumsy
Proud of Brushless Sprouts
Commander Clumsy's Avatar
Belgium, Flanders, Antwerp
Joined Feb 2007
Found this on the French HK Facebook page, they call it l'auto-G Mad Max.
Commander Clumsy is offline Find More Posts by Commander Clumsy
Old Nov 22, 2012, 02:45 PM
skydanz is offline
skydanz's Avatar
Joined Dec 2007
Very clever
Old Nov 22, 2012, 03:08 PM
PeterO_UK is offline
Find More Posts by PeterO_UK
PeterO_UK's Avatar
Joined Aug 2006
Sorry, but you are perpetuating a myth.
Coning does not aid stability at all, in fact it causes roll due to the different airflow over that blades when they are at the 12 and 6 o'clock positions. At 12 o'clock the blades have an increased angle of attack compared to the blades at 6 o'clock due to the a larger component of the rearward airflow (due to the forward motion) appearing as an "upward" or "through the rotor disk" flow.
PeterOGB
PeterO_UK is offline Find More Posts by PeterO_UK
Old Nov 22, 2012, 03:44 PM
skydanz is offline
skydanz's Avatar
Joined Dec 2007
PeterOGB
Um, OK
There is a long standing debate on CONING that has become more of an inside joke. I was perpetuating the joke. Sorry guys, I won't do that again.
Old Nov 22, 2012, 04:55 PM
Wolfman is offline
Find More Posts by Wolfman
Boondocks, East Coast, USA
Joined Jun 2003
Are you guys holding some right aileron during the ROG take off run to compensate for the left roll tendency at rotation?
Wolfman is offline Find More Posts by Wolfman
Old Nov 22, 2012, 05:00 PM
ask21! is offline
Find More Posts by ask21!
Be here now!
ask21!'s Avatar
Rome,Ciampino
There is any tendency to roll left if the rotor is spinning at the right rpm. So, no, any left roll applied.
ask21! is offline Find More Posts by ask21!
Old Nov 22, 2012, 05:58 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
The inportant think is that the blades are up to speed prior to ROG. If they are not,then the model will roll on to it's left side.So if the blades are up to speed then no right roll is needed.
It is best to try to maintain a level disk at ROG.The biggest problem is that UP elevator is applied to early.When the blades are up to speed ,then the model will rise as the power is slowly applied.
A gentle hand launch is suitable for this size of model as it gives your model height and air speed and you can feel and here the pull on the rotors .
Chris..........
britinoz is offline Find More Posts by britinoz
Old Nov 22, 2012, 06:32 PM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
PeterOGB
Agreed!...I tested this a few years back and it adds unwanted roll but can be trimmed out, stability does come into effect but only because the CG position of the rotors is moved upwards and in theory generates a longer mast. A longer mast adds stability but reduces roll sensitivity.
It is impossible to eliminate cone but the less the better, especially in windier conditions.
From time to time this does come up but if you read the sticky at the top f the page then it is explained better.
'To cone or not to cone'.....that is the question
Regards
Rich
SafeLandings is offline Find More Posts by SafeLandings
Help! Slow-g slow stick auto gyro HyperHelis Auto Gyros 4 May 23, 2012 08:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 05, 2006 11:27 PM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 07:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 02:35 PM
