Old Nov 13, 2012, 03:07 AM
BigTradioman is offline
Find More Posts by BigTradioman
BigTradioman's Avatar
United Kingdom, Harpenden
Joined Oct 2009
Originally Posted by Sammy70 View Post
Did he say "yea, I meant to do that" ?
No he just said" bloody hell did I just do a loop?
BigTradioman is offline Find More Posts by BigTradioman
Old Nov 13, 2012, 03:59 AM
Aender69 is offline
Find More Posts by Aender69
Grand-Duchy of Luxembourg
Aender69's Avatar
Joined Sep 2005
Originally Posted by BigTradioman View Post
In my opinion and experience as a AutoGyro pilot: there are many circumstances with AutoGyros that need opposite control inputs unlike conventional fixed wing models. For example Gyro's do not like turning to the right so you need to initiate the turn with the rudder and then hold in some degree of left rotor to maintain a smooth turn and prevent the nose from tucking under, which will educe the lift as the blades slow down. Also, when landing and doing "auto's" the Gyro will need lots of rudder inputs and hardly any roll input as some torque reaction (good old Newtons law of motion "every action has a reaction") is experienced.
Thanks for that good explanation. Taking the guesswork out somehow
Aender69 is offline Find More Posts by Aender69
Old Nov 13, 2012, 06:54 AM
Dangerous Dick is offline
Find More Posts by Dangerous Dick
Dangerous Dick's Avatar
Cheshire, England
Joined Mar 2001
Just 'maidened' my Auto'G.
Actually got it from HK last Wednesday but was away on business, then had to complete the decorating I started a couple of weeks ago before I could get the box open .
Had a couple of spare minutes this morning so got the kit out and before I knew it I had it together, programmed into the Tx and ready for the off.
It is a bit windy today but you know how it is with new models - they've just got to go up .
Tried an ROG as no-one around to hand-launch for me. Spun the blades a bit as directed, slowly increased the throttle and away she went lifting off without any drama at all. Flew around getting the trims sorted and she was perfectly happy in the sky - I was tempted to start chucking the controls around but then I remembered the battery was just 'placed' into the bay and not secured - a recipe for disaster if any loops or rolls were attempted .
The timer went at seven minutes and I bought her around to land - she slowed up perfectly and touched down gently onto the grass. The battery is charging now so I don't have any power draw as yet but another is ready to go when I've eaten my lunch.
What a fantastic little toy - almost straight out of the box to the field before you can charge a LiPo (that's if you still go at 1C that is!). Well impressed.
Dangerous Dick is offline Find More Posts by Dangerous Dick
Old Nov 13, 2012, 07:49 AM
Aender69 is offline
Aender69's Avatar
Joined Sep 2005
Is that windsock on your picture showing your actual maiden wind conditions?
Old Nov 13, 2012, 08:18 AM
Cheshire, England
Joined Mar 2001
Yep - gusting a bit
Old Nov 13, 2012, 09:19 AM
Vrated is offline
Find More Posts by Vrated
Vrated's Avatar
United States, UT, Marysvale
Joined Aug 2004
Double D,
Thanks for shareing. I hope my first experiance with the Auto-G is as pleasant as yours was.
Vrated is offline Find More Posts by Vrated
Old Nov 13, 2012, 03:49 PM
rcoconut is online now
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Maiden was this morning with no wind..... Didn't go well
Pre-rotated the blades for a ROG take off, slowly applied power and she rolled left coming to a stop leaning on her rotor blades as well as her ELE. No damage but we did have to re-center the tail section since she was leaning to the left on her rotor and ELE.
Take two, tried to pre-rotate the blades "faster" and full power was immediately applied. The roll to the left began and the sticks were full right AIL & full right RUDD, she did get airborne a tad but was rolling to far to the left and came down to a stop on one of her rotors and nose. Damage this time,
The Blade Grip did it's job (good thing they give you an extra one) breaking at the rotor head. Need to be replaced with the supplied Blade Grip.
Prop broke as well as the motor mount. New prop/rotor blades were ordered last week in case I needed 'em, obviously I need 'em BUT the rotor blades are fine and the motor mount looks like it can be saved with Gorilla Glue
That's where she's at now, awaiting to be repaired. As far as critiquing the maiden goes.... we're guessing from other experiences described here it was rotor speed, LACK OF ROTOR speed!!
Next time around if the wind is not blowing we're gonna hand launch her. Even if the wind is blowing I think I'll hand launch her so I can get the "feel" of what the rotor speed needs to be before she gets airborne. Also, nobody has mentioned control horn placement, I think we'll also move the control rod to the inner most hole of the control horn on the AIL? What do you guys think?
Good luck and hope your maiden goes well, look forward to hearing more experiences regarding maidens and flights!
p.s.- congrats with your maiden Dangerous!!
rcoconut is online now Find More Posts by rcoconut
Old Nov 13, 2012, 04:12 PM
blau is offline
Find More Posts by blau
Joined Apr 2009
I come today to self-g.
someone could tell me where is the center of grabedad exactly?
spyner to 220mm of this?
do not quite understand the manual.
greetings and thanks.
blau is offline Find More Posts by blau
Old Nov 13, 2012, 04:18 PM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
blau
You must be using a translator but I think I understand. How to measure the center of gravity?
I used the recommended battery and just flew it. That worked fine.
Anyone else have a picture on how to measure CG on this thing?
ducatirdr is offline Find More Posts by ducatirdr
Old Nov 13, 2012, 05:46 PM
Mt.Flyer is offline
Find More Posts by Mt.Flyer
United States, CO, Frisco
Joined Jul 2010
Has anyone tried a two blade prop? If so, what size and how is the performance?
Thanks!
Mt.Flyer is offline Find More Posts by Mt.Flyer
Old Nov 13, 2012, 06:49 PM
suzanne lee is offline
Find More Posts by suzanne lee
China, Guangdong, Shenzhen
Joined May 2011
the "220mm"on manual means:From the tip of the spinner to CG,the distance is 220mm
suzanne lee is offline Find More Posts by suzanne lee
Old Nov 13, 2012, 07:23 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Remember guys, autogyros don't have a "fixed" CG point like a fixed wing aircraft.
Instead, it's all about the hang angle.
Install your lipo, hold the Auto-G by the mast button and the nose should hang down around 15* (at least that's a decent starting point for most a/gyros)
Sammy70 is offline Find More Posts by Sammy70
Old Nov 13, 2012, 07:35 PM
will3d4food is offline
Find More Posts by will3d4food
H-King, DuraFly, Turnigy
Joined Mar 2008
Surprisingly the more wind the better, 10mph +/-. When the blades start spinning in the wind you will know when their going fast enough and the model will get light in your hands.
For your first flight I recommend hand launching, just get comfortable holding it and then gently launch it with some power. If the blades are spinning fast enough the auto-g will have excellent slow-flight performance.
will3d4food is offline Find More Posts by will3d4food
Old Nov 13, 2012, 09:46 PM
rcoconut's Avatar
Joined Sep 2006
Thank you for confirming a hand launch for sure when she's back up and running for me!! Any thoughts about moving the control rods to the inner most hole with the AIL? Or is that not necessary?
Thanks again for the help!
Old Nov 14, 2012, 12:12 AM
ask21! is offline
Find More Posts by ask21!
Be here now!
ask21!'s Avatar
Rome,Ciampino
So, when hanging at 15 will the rotor disc be at 0 or not? I assume not...
So there will be 2 angles needed to know...i think! Can anyone clarify my doubts please.
If I hang my auto-g, it will hangh over 15 but the rotor disc won't be parallel to terrain.
ask21! is offline Find More Posts by ask21!
Help! Slow-g slow stick auto gyro HyperHelis Auto Gyros 4 May 23, 2012 08:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 05, 2006 11:27 PM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 07:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 02:35 PM
