Old Nov 07, 2012, 07:03 AM
Jockadopolus is offline
Find More Posts by Jockadopolus
Jockadopolus's Avatar
Scotland
Joined Jan 2010
Originally Posted by e_lm_70 View Post
It is looking a scratch build ...not a "product" ... quite a difference "to me" ...
ps: I did missed out that this was your scratch build design ! ... So congratulations for your self made autogyro ... I see you did used the Cierva rotor head .. that now is not anymore available ...
This was availiable for some time but not in the UK
http://www.helioldie.de/tragschrauber.htm
Jockadopolus is offline Find More Posts by Jockadopolus
Old Nov 07, 2012, 07:08 AM
ismith2uk is offline
Find More Posts by ismith2uk
Peterborough
Joined Feb 2009
Hi Guys,
I ordered mine on Oct 29. Apparently it was picked on Nov 2, and it has arrived in one piece today Nov 7 here in the UK.
Looks incredibly easy to put together, might finally get some of the artf mob down at out field interested enough to have a go with an autogyro. I cannot see it taking more than 30 mins to be ready.
I hope to maiden mine on Sunday. I'll let you know how it goes.
Cheers
Ian
ismith2uk is offline Find More Posts by ismith2uk
Old Nov 07, 2012, 07:18 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Ok ... you are good on history and find special stuffs ... this is a 2004 model (or even older) ... a model from Japan review by some german
Anyhow ... from wikipedia:
Flight controls
There are three primary flight controls: control stick, rudder pedals, and throttle. The control stick is termed cyclic and tilts the rotor in the desired direction to provide pitch and roll control. The rudder pedals provide yaw control, and the throttle controls engine power.
Secondary flight controls include the rotor transmission clutch, also known as a pre-rotator, which when engaged drives the rotor to start it spinning before takeoff, and collective pitch to reduce blade pitch before driving the rotor. Collective pitch controls are not usually fitted to autogyros, but can be found on the Air & Space 18A and McCulloch J-2 and the Westermayr Tragschrauber and are capable of near VTOL performance. Unlike a helicopter, autogyros without collective pitch need a runway to takeoff; however they are capable of landing with a very short or zero ground roll.
By nature ... autogyro are supposed to have 2 axis control on the rotor head ... even some pitch control and pre-rotation in some advanced model.
No mention about using the tail elevator as control
So ... for me a pure autogyro is with 2 axis rotor head ... but ... hey ... this is a "cheap" PNF model ... so ... I'm fine with the Durafly designer decision ... just .. I would like to mod it
Tchuss
e_lm_70
ps: I was looking if any commercial 1:1 scale autogyro has tail elevator control ... but it is looking I can't find any ...
e_lm_70 is offline Find More Posts by e_lm_70
Old Nov 07, 2012, 07:37 AM
Scotland
Joined Jan 2010
ps: I was looking if any commercial 1:1 scale autogyro has tail elevator control ... but it is looking I can't find any ... [/QUOTE]
Roto-Pup LW-2: Controlled by elevator, rudder and laterally tilting rotor head.
http://aviastar.org/helicopters_eng/little_wing.php
Old Nov 07, 2012, 07:42 AM
e_lm_70 is offline
Austria
Joined Jan 2004
Respect ... you are a master on find something old and very rare ...
This is a 1994 model
Ok .. personally I like these Magni autogyro .. the same that I have also seen in real life
http://www.magnigyro.it/italiano/scout.htm
All of them , on the tail the only movable control surface is the rudder
Old Nov 07, 2012, 07:48 AM
Lucam is offline
Find More Posts by Lucam
Fuzzy user
Lucam's Avatar
Italy, Lombardy, Griante
Joined Oct 2003
Anyhow ... in theory it is even possible to fly with an autogyro with a fix rotor head ... in practice, I have seen even micro model (scratch build) that fly in this way ... anyhow ... a part from this model ... I still have to see another autogyro with only 1 free axis rotation on the rotor head ...
Another Autogyro with only roll on the head and elevator for pitch
http://www.rcgroups.com/forums/showthread.php?t=1650676
The Igor Bensen's design nowdays is winner, because it's simpler to do pitch-tilt rotor in a little, homebuildt recreational gyro.
BUT single, as well as zero degree rotors were used in the past, when gyrocopter were nor little nor recreational: some example,,,
About my Cierva 30, yes, flies well, but it's too heavy to be confortable, and two axis rotor is scale wise but a bit imprecise, better just one axis, IMHO
Lucam is offline Find More Posts by Lucam
Old Nov 07, 2012, 09:25 AM
Vrated is offline
Find More Posts by Vrated
Vrated's Avatar
United States, UT, Marysvale
Joined Aug 2004
There are some model Autogyros with out any controls at all, other than little trim here and there..... "Free Flight Autogyros". Seems there were plenty of them quite successful over the years. Funny, they were still called Autogyros too. Here's a link to some along with a few helicopters all FF.
http://www.rcgroups.com/forums/showt...light=autogyro
Now back to the Auto-G.....
~Fred
Vrated is offline Find More Posts by Vrated
Old Nov 07, 2012, 11:07 AM
ask21! is offline
Find More Posts by ask21!
Be here now!
ask21!'s Avatar
Rome,Ciampino
Tchuss
e_lm_70
Have you ever read about autogyros?! There are some good books that could open your mind.
Any autogyro CAN have the rotor in 3 config at least.
Earlier gyros had a fixed configuration rotor, in example you can look at the pca2 that is a famous one. It needed of flying surfaces to be controlled on its axis. With the growing of technology and know-how, builders were able to build semirigid rotors. Theese one were articulated only on roll sense. This way the could make a gyro lighter and more efficent due to minor resistance and wheight...wings were no more needed.
Than full articolated rotor have appeared...
ask21! is offline Find More Posts by ask21!
Old Nov 07, 2012, 11:11 AM
Lucam is offline
Fuzzy user
Lucam's Avatar
Joined Oct 2003
~Fred
My father in the sixties buildt a very, very nice Cierva 30 all balsa, free flight, powered with .049 cox babe bee
very difficult to set up, but really a unique ship
Old Nov 07, 2012, 11:18 AM
Lucam is offline
Fuzzy user
Lucam's Avatar
Joined Oct 2003
~Fred
Tchuss
e_lm_70
two axis rotor in common, because is simple and cheap, but it's NOT the best, as you can read here, the best is elevator control: more accurate, and more safe than simply rotor tilting.
http://www.emeraldinsight.com/journa...6159&show=html
A
Old Nov 07, 2012, 11:33 AM
Lucam is offline
Fuzzy user
Lucam's Avatar
Joined Oct 2003
look here:
http://www.littlewingautogyro.com/specs.html
Old Nov 07, 2012, 11:52 AM
bzfrank is offline
Find More Posts by bzfrank
4.2V of pure Kraut power
bzfrank's Avatar
Germany
Joined Nov 2006
Ask Tian Sheng <autogyro@126.com> directly. I bought my Cooler from him and also a Luobo-15 that still waits in the basement. A colleague also purchased the head separately. They come in different sizes.
bzfrank is offline Find More Posts by bzfrank
Old Nov 07, 2012, 12:02 PM
will3d4food is offline
Find More Posts by will3d4food
H-King, DuraFly, Turnigy
Joined Mar 2008
Originally Posted by will3d4food View Post
The Head was designed to be kept simple and light, reducing your risk of damage during a low-speed tip-over. We fine-tuned the rotor disc angle and blade angle for a wide variety of flying style's, especially low speed handling.
Words of Wisdom for Beginners: Point the nose up into the wind to get some head-speed before takeoff and then fly it like a Bixler.
From the first unboxing ... it is looking like there is already 1 spare included in the box .. is this correct ?
That setup look's complicated and easy to break.
will3d4food is offline Find More Posts by will3d4food
Old Nov 07, 2012, 12:14 PM
bzfrank is offline
bzfrank's Avatar
Germany
Joined Nov 2006
Nope, its in fact very sturdy and handles even bad days well. Trust me, I know...
Old Nov 07, 2012, 12:28 PM
Joined Mar 2008
LOL that's funny.
In the initial test phases we we're experimenting with the folding blades but decided it was best to keep them fix so hand start-ups would'nt convolute the blade's.
Help! Slow-g slow stick auto gyro HyperHelis Auto Gyros 4 May 23, 2012 09:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 06, 2006 12:27 AM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 08:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 03:35 PM
