Old Nov 15, 2012, 10:50 PM
volumax is offline
Find More Posts by volumax
Joined Mar 2012
Any update on the vctrc gyro?
volumax is offline Find More Posts by volumax
Old Nov 18, 2012, 08:26 AM
GVhelimike is offline
Find More Posts by GVhelimike
K.I.S.S.
KC Mo suburb
Joined Nov 2005
Hi guys Question, can a satellite RX be used with this gyro? Is it non receiver ready?
Michael
GVhelimike is offline Find More Posts by GVhelimike
Old Nov 18, 2012, 09:20 AM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
No sat rx functions available with this firmware version.
ridge_racer is offline Find More Posts by ridge_racer
Old Nov 18, 2012, 02:16 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Even thought the manual says it can work with a satellite or S-Bus, it can't. I've had it confirmed with the manufacturer, as well.
beenflying is offline Find More Posts by beenflying
Old Nov 19, 2012, 01:37 AM
volumax is offline
Joined Mar 2012
so BF have you been able to test the vctrc gyro?
Old Nov 19, 2012, 11:37 AM
Seregasvi is offline
Find More Posts by Seregasvi
Russia
Joined May 2009
Я купил тоже данный FBL, но только с надписью RCX. В отличие от того, который описывается здесь, мой был не в пластиковом, а алюминиевом корпусе. Его вес 25 грамм. Прошивка V1 от Microbeast X оригинала. У меня на 500 и 600PRO стоят оригинальные Microbeast, поэтому я могу сравнить их.
На третью Rex500 я поставил клона. Он так же сразу полетел как и оригиналы. Разницы я не заметил. Хотя на Microbeast X у меня стоит на одном V3.0.8 и на другом V3.0.12
Летал по кругу, так полёт первый и боялся что он сломается в полёте
Hello. I do not know English, so I will write in Russian and then translated by the computer into English. So for translation scold http://translate.google.com
I also bought this FBL, but only with the words RCX. In contrast to the one described here, I was not in the plastic, and aluminum. Its weight is 25 grams. Firmware V1 Microbeast X from the original. I have a T-Rex500 and T-Rex600PRO are original Microbeast, so I can compare them.
On the third I put Rex500 clone. He also once flew as the originals. I have not noticed a difference. While on Microbeast X I have is one on another V3.0.8 V3.0.12
Here's a video
Первый полёт клона Microbeast.mp4 (3 min 59 sec)
He flew in a circle, so the first flight, and was afraid that it will break in the air
Seregasvi is offline Find More Posts by Seregasvi
Old Nov 19, 2012, 12:02 PM
Russia
Joined May 2009
Сейчас попробовал подключить клона через оригинальный шнур от Microbeast X. Хочется попробовать прошить его новой прошивкой 3.0.8, но боюсь.
Через программу настройки показывает вот что:
Как вы думаете? Стоит попробовать или не надо прошивать?
Now try to connect the power cord through the original clone from Microbeast X. I want to try to flash the new firmware to 3.0.8, but I'm afraid.
After setup shows this:
What do you think? Worth a try or do not flash?
Old Nov 19, 2012, 01:17 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Hi Seregasvi. Thanks for the video. Yes, it certainly looks like the same gyro, using a metal case instead of the plastic case.
I wouldn't attempt the flash to v3. An attempt with the HB800 failed and left the gyro unusable. I suspect the boot loader does not know how to decrypt the firmware properly. Of course it may be different with this version, but it's unlikely.
Old Nov 19, 2012, 01:19 PM
Joined Nov 2010
DO not try and flash it!!!! You will more than likely brick it like the HB800....Do not do it!!!!
Old Nov 19, 2012, 01:22 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Risky
Hi Seregasvi, I'd be really surprised if you could flash the VCTRC unit with the latest MicroBeast firmware - if you could, it would make it easily the best value for money unit on the market!
Your attached screenshot seems to show the Microbeast software not recognising the unit.
Loading the later firmware would be a step into the unknown, and you would risk disabling your VCTRC - but if it worked, I suspect there would be a mad rush to buy VCTRC controllers, and then maybe some legal action from the makers of Microbeast!
2Doggs is offline Find More Posts by 2Doggs
Old Nov 19, 2012, 01:25 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
My ALZRC Devil 450 FAST build is being held up by the servos coming from HobbyKing.
They're obviously getting a better shipping rate from Singapore Post, at the moment, but Singapore post is so backlogged that the parcel isn't even showing on their tracking site 13 days after it was shipped from the HK warehouse. I've complained to HobbyKing, but they just said to wait 7 to 10 business days for it to appear on Singposts site.
Old Nov 19, 2012, 01:28 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
I'm still waiting on my last HK order, despite having had a bunch of stuff from Leadershobby about a week ago that I ordered on the same day as my HK stuff.
Old Nov 19, 2012, 03:38 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
In my reply to HK's response saying to wait, I told them just that, that other suppliers in the same region are not having the same delays, and that I would have to think twice before using HK again, if this was going to continue. Not that they would probably care, but it made me feel better.
The reply will be interesting, and will make up my mind as to whether to use my contact the boss of HK feature.
I've had a good response to this in the pass. I contacted him about upgrading the HK450 Pro head from the sport one they were using and got a good reply.
Old Nov 20, 2012, 10:00 PM
mrmarc is offline
Find More Posts by mrmarc
Not da momma!
mrmarc's Avatar
United States, CA, San Diego
Joined Jul 2012
Если бы я владел двумя гироскопами, я хотел бы попытаться обновить один. Это, скорее всего, не получится, но даже если это произойдет, вам все равно придется еще один, чтобы использовать. Если бы это был успешным, это было бы здорово!
If I owned two gyros, I would attempt to upgrade one. It will probably fail, but even if it does, you will still have another one to use. If it were successful, it would be great!
Where are you guys ordering the ALZRC bits from? I'm really digging that *cough* goblin-esque canopy/fuse.
mrmarc is offline Find More Posts by mrmarc
Old Nov 20, 2012, 10:13 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
The best place I found is http://www.rc711.com/shop/index.php
mhills51 is offline Find More Posts by mhills51
Discussion ALZRC 3GY V2/Robird G31 Flybarless 3-Axis Gyro beenflying Mini Helis 1974 Aug 07, 2016 11:24 AM
New Product Vctrc 3gx fbl keris Mini Helis 2 Sep 19, 2012 11:41 PM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
