Old Mar 29, 2013, 04:18 AM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Originally Posted by prop bender View Post
I hope they improved the material in the mounting lugs. The last set of 933's I used had very brittle mounting lugs,other than that they worked OK.
That's the first thing I consider with servos nowaday...I hate when the mounting lugs or case breaks.
ridge_racer is offline Find More Posts by ridge_racer
Old Mar 29, 2013, 10:11 AM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
The only differance I can find between the 933 and the 337 ( without actualy testing ) is the 337 is a tad faster, I like the spects,I worry about the mounting lugs though. Ed
prop bender is offline Find More Posts by prop bender
Old Mar 29, 2013, 06:13 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
They're using a new plastic now that is much better:
Use Japanese raw material to produce outer shell, which is more sturdy and durable and can bear 120℃ temperature.
beenflying is offline Find More Posts by beenflying
Old May 08, 2013, 07:54 AM
jaguar1126 is offline
Find More Posts by jaguar1126
Malaysia, Penang, Balik Pulau
Joined Feb 2011
Hi is there any manual to this VCTRC 3GX Flybarless 3-Axis Gyro?
jaguar1126 is offline Find More Posts by jaguar1126
Old May 08, 2013, 07:57 AM
Joined Feb 2011
Hi, is there any manual for this VCTRC 3GX Flybarless 3-Axis Gyro
Old May 08, 2013, 11:45 AM
Joined Nov 2010
http://www.beastx.com/manuals/MICROBEAST_PV_ENG.pdf
Old Dec 08, 2013, 08:34 AM
Luchsalt is offline
Find More Posts by Luchsalt
Joined Dec 2013
No collective
I am aware that this discussion is old but I am having a problem with the vtrc 3gx/spectrum dx6i setup that I am trying to create on my 450 trex clone.
I have followed the instructions from the manual to the letter and find that the system works perfectly except for a total lack of collective.
I am a complete noob with fbl and wonder if I am missing something really obvious.
Help
Luch SALT
Luchsalt is offline Find More Posts by Luchsalt
Old Dec 09, 2013, 05:55 PM
Joined Nov 2010
Help
Luch SALT
So basically on step K you set it for -/+12 degs and once you exit setup it doesn't have the same pitch range? Did you set the pitch curve in the tx to 0-100%? Is the radio set to single servo H1?
Old Dec 11, 2013, 04:47 PM
Luchsalt is offline
Joined Dec 2013
Step k on my instructions for this flybarless unit adjusts tail gain.
The adjustment for collective is on Function D and there is no response from the collective either up or down in order to adjust it!
The cyclic works beautifully reacting to pitch and yaw adjustments instantly but I cannot get the collective to respond at all.
This is a Spectrum dx6i and is set to 0-100% pitch curve and 1 servo 90deg (only other option is 120 deg)
Ah! You have used the microbeast instructions. At step K there IS no collective to adjust. The collective doesnt do anything. Could this be a Spectrum specific problem??
I just checked all the steps in the manual again - all correct.
Old Dec 11, 2013, 08:07 PM
Joined Nov 2010
Are you sure you are using version 1 of the microbeast manual?
Old Dec 14, 2013, 10:51 AM
Luchsalt is offline
Joined Dec 2013
Hi Thanks for replying again
I am using, firstly the manual supplied with the vctrc fbl unit, then I checked on the instructions supplied by you above in order to understand your reference to 'K' but neither seem to work.
Old Dec 14, 2013, 01:02 PM
USA, CA, Red Bluff
Joined Dec 2007
Hi! I used to fly with a dx6i, it seems to me I set the swash on one servo 120 degres for a collective pitch heli. Try that. It will either work or prove I have a faulty memory
Old Dec 21, 2013, 04:22 PM
Luchsalt is offline
Joined Dec 2013
Hi, Thanks for that. I tx does not allow for that - in fact the only two options are 1 servo 90deg or 3 servo 120deg.
So no joy at the moment.
I think I will try another make of radio system - I have a KDS k7x11 but need to buy another receiver, I will report back soon.
Old Jan 07, 2014, 07:01 AM
Luchsalt is offline
Joined Dec 2013
I have tried the KDS tx/rx combo with the vctrc 3gx and success first try - so it appears to be a Spectrum specific problem.
Thanks for the help
Old Jan 07, 2014, 03:49 PM
USA, CA, Red Bluff
Joined Dec 2007
Thanks for the help
Glad to see you have it sorted out
Discussion ALZRC 3GY V2/Robird G31 Flybarless 3-Axis Gyro beenflying Mini Helis 1964 Jun 03, 2016 01:07 PM
New Product Vctrc 3gx fbl keris Mini Helis 2 Sep 19, 2012 11:41 PM
Alert Hobby King NEW 3 Axis Gyro Flybarless system w/USB Programmer $45 Mahu Hot Online Deals 6 Jun 20, 2012 03:45 AM
Discussion Hobbyking ZYX 3-Axis Flybarless System Gyro old4570 Electric Heli Talk 4 Mar 15, 2012 10:18 PM
