Old Feb 03, 2013, 02:58 PM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
Cant make anything from the cad file :-(
Can you upload it in dwg or dxf
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Feb 03, 2013, 10:31 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Conversion of formats sometimes works, but I'm not having much luck at it with this project. I'll work some more on it.
Roto Rob is offline Find More Posts by Roto Rob
Old Feb 05, 2013, 02:54 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
The best I can do for another version is an STL file. I'll try to figure out a way to get to DXF. All my attempts so far either fail, or butcher the part. I made these STL files in four parts so it will be easier to work with. Should look like the Jpegs, when assembled.
I'll keep working on the tabbed parts.
I posted a better Bobcad file in my previous post. http://www.rcgroups.com/forums/showt...4#post23998633
Old Feb 09, 2013, 03:34 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Ok, All the parts are now uploaded in CAD. http://www.rcgroups.com/forums/showt...4#post23998633
Hope its enough for some to make it.
Continued gluing the fans in place. Need to route the servo wires, then I can glue the fuselage halves together.
Old Feb 09, 2013, 12:56 PM
Flying Dutchman!
Joined Sep 2011
Last edited by robertboxhoorn; Feb 11, 2013 at 09:22 AM. Reason: Sorry I'm blind....
Old Feb 10, 2013, 02:00 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Decided to inlay the servo wire to the inside of the duct. Think I will tie it in with thread, and glue to keep it from coming loose.
Old Feb 10, 2013, 02:37 AM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
That looks very nice RR! Not much room in there for wiring! Small models are tough!
pdawg is online now Find More Posts by pdawg
Old Feb 10, 2013, 02:54 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Yes, I keep thinking I should not build anything small, but go ahead and do it anyway.
Old Feb 12, 2013, 03:58 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Got the electronics completed. Taped it together to do some test glides. I think it is ok on the CG. Was easy to throw into a glide. Might have been a little nose heavy, but not sure since I stopped after the second try. Hit the leg of the workbench. Scrunched the nose a little. Think I can get it straight, without having to make a new nose.
Old Feb 12, 2013, 01:47 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
i kept breaking the nose on my last F-22, make sure when you put it in your car to set it on the floor .
If you want some good painting tips or help let me know! I have an air bursh and loads of paint
chester2240 is offline Find More Posts by chester2240
Old Feb 13, 2013, 03:47 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Might have to take you up on the paint help, you do nice work. I have an airbrush. I do ok on most painting, but need some practice on painting fine details.
The nose repair came out decent. After the fiberglass is on it, it should be hard to notice.
Glued the fuselage halves together tonight. Waiting for glue to dry. Weight is at 92 grams so far, (all parts including lipo).
Old Feb 13, 2013, 01:51 PM
Joined Jul 2011
I'll pm you my number.
I could even give you my last f22 airframe im not using it any more its pretty beat up but gives you the idea how i did it.
Im using the cheap hobbyking paintbrush it does good work but im looking forward to the day i can get a badger
Old Feb 18, 2013, 03:18 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
My airbrush is a Badger. Its good, have a little trouble getting a very fine spray. But usually I have sprayed acrylics with it, so not the best paint for that. It does work better than the cheapo plastic one I had before it.
I got the fiberglass finished. Started on filler, Probably mixed it to thin. So likely will need another coat. I'll see when it dries.
Old Feb 21, 2013, 03:03 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Not pink anymore. Maybe a second coat, and I can work on the details.
Old Feb 21, 2013, 03:25 PM
Flying Dutchman!
Joined Sep 2011
That looks sleek! Great job
I've got a great color to spray ;-)
Sold TX LPU: 30mm EPO Nano F-86 Sabre - PNP w/batteries: $55 Roswalt Aircraft - Electric - Jets (FS/W) 2 Jul 28, 2012 04:03 PM
Sold LPU San Antonio TX: JPower 50mm MiG-15, F-86, F-22 and F-35. FoamJunkE Aircraft - Electric - Jets (FS/W) 3 May 09, 2012 12:00 PM
For Sale Great Planes F-86 Micro EDF 30mm with Anylink $85 Shipped tsever00 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 28, 2012 03:01 PM
Alert HEY EVERYONE! the great planes 30mm f-86 foam parts are all in stock! Mason W. Micro EDF Jets and Power Systems 5 Mar 05, 2012 09:28 PM
Off Site Great Planes 30mm Brushless Micro EDF F-86 Sabre battery adapters glenn2626 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 26, 2012 01:17 PM
