Old Nov 04, 2012, 01:41 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
Thats 2 cool !!!!!!!
chester2240 is offline Find More Posts by chester2240
Old Nov 05, 2012, 02:48 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I did a quick duct drawing for a single 25 mm fan. It would fit fine. I don't have much of a clue with split duct design. I need to find out some more about the shape, and area that works best.
Roto Rob is offline Find More Posts by Roto Rob
Old Nov 06, 2012, 03:05 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Fiberglassed the tailerons. Came out to 0.80 grams each as pictured. Now I need to figure out how I'm going to secure them in the fuselage.
Old Nov 07, 2012, 04:27 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
I think I figured out how I will go with the taileron pivot. I'll try to make a bushing from something fairly strong like aluminum, or maybe a plastic. I'll look at my scrap material to see what I have. I'll use heat shrink for a pivot tube, it'll be glued into the foam. Not sure if the heat shrink will be good enough, so might try it out in some scrap foam. The bushing will come in from the back, and the tailerons carbon shaft will be glued into the bushing.
I'll have to cut it appart if it ever needs fixed.
Old Nov 07, 2012, 04:58 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Sounds like a good mount rob.
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 09, 2012, 02:34 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Got the vertical fins fiberglassed. They came out at 0.70 grams each. Started fiberglassing the tail of the fuselage. I probably went farther forward than needed, but I want it to be fairly stiff for the tailerons.
Old Nov 09, 2012, 05:35 AM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
As ive mentioned the work you are doing is fabulous...
Keep the pics coming!
Take care..........Chris
Hover or die is offline Find More Posts by Hover or die
Old Nov 10, 2012, 12:14 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Rob, I agree in areas of strength, more is better and safer.
Looking great to date!
Old Nov 10, 2012, 03:30 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Started making the bushings for the tailerons. Looks like it will work out. Need to trim them to length.
Ordered some esc's. Turnigy Plush 6 amps. Hope they work out. If not I'll take my Pheonix 10 amps out of helicopters to use.
Added servo arms to the tailerons. Left both horns on it since I have not decided if I'll run the linkages on top, or under the wing.
Old Nov 11, 2012, 03:08 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Continued work on the taileron pivots. Decided to try a carbon tube for the bushing. I'm going to try to put a screw with a washer in the end to secure it. That way I can remove it easier if needed. I think I got it glued in fairly straight. Will wait till morning for it to harden, before I mess with it.
Old Nov 12, 2012, 03:14 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Continued cleaning up the pivots.
Thinking about if I will fiberglass the whole plane, or put carbon rods in the wings. I think it can take quite a bit of additional weight, but every time I think that I end up on the heavy side.
Old Nov 12, 2012, 02:57 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
If it were me - rods in the wings.
Old Nov 12, 2012, 05:55 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
I will put the carbon rods in the wing. I still need to decide on fiberglass, or maybe Polycrylic to toughen the foam, or just paint.
I used little pieces of heat shrink to center the carbon tube for glueing. I'm also thinking about trimming the tailerons a little smaller.
edit: added the carbon rods, and trimmed a little on the tailerons.
Old Nov 15, 2012, 02:18 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Waiting for the esc's to arrive. Current weight of bare fuselage is a little higher than I thought it would be. It adds up fast. Going with a lighter lipo, and reciever so still a little ahead. Fuselage 18.2 grams, fans 16.2, Battery 500mah Hyperion 2 cell 32 grams, Servo's 8.6, esc's 10, reciever 2.5.
For a total of 87.5 grams.
That should give me room for any reinforcement, and paint.
Old Nov 15, 2012, 05:11 AM
ksqm is offline
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Roto Rob,
Very nicely done!
Ksqm
ksqm is offline Find More Posts by ksqm
Sold TX LPU: 30mm EPO Nano F-86 Sabre - PNP w/batteries: $55 Roswalt Aircraft - Electric - Jets (FS/W) 2 Jul 28, 2012 04:03 PM
Sold LPU San Antonio TX: JPower 50mm MiG-15, F-86, F-22 and F-35. FoamJunkE Aircraft - Electric - Jets (FS/W) 3 May 09, 2012 12:00 PM
For Sale Great Planes F-86 Micro EDF 30mm with Anylink $85 Shipped tsever00 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 28, 2012 03:01 PM
Alert HEY EVERYONE! the great planes 30mm f-86 foam parts are all in stock! Mason W. Micro EDF Jets and Power Systems 5 Mar 05, 2012 09:28 PM
Off Site Great Planes 30mm Brushless Micro EDF F-86 Sabre battery adapters glenn2626 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 26, 2012 01:17 PM
