Old Oct 27, 2012, 03:32 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
F-22 30mm
This is the F-22 I started last January, I know, I'm really slow. This is the thread I first posted about it in. http://www.rcgroups.com/forums/showt...5#post23056593
It was inspired by his work. It has evolved to something so different, I decided to do my own thread. It has a 12.1 inch wing span, and is built for the Great Planes F-86 fans. So far the lower half, and wing sections are 5 grams total. The Cad file has changed quite abit since this one, I'll update the picture when I have time.
Roto Rob is offline Find More Posts by Roto Rob
Old Oct 27, 2012, 11:17 AM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
That is some pretty awesome use of technology rotorob!
pdawg is online now Find More Posts by pdawg
Old Oct 29, 2012, 03:25 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Thanks, I could have carved out many by hand in the time it took for me to draw it.
I really messed up the top half tonight. Was getting rushed to much. The part is slightly taller than the 1.5 inch foam I had. I used Supper 77 spray to attach a piece on top. I didn't wait for it to dry, and it melted some of the foam behind the canopy cutout. Right after it finished milling I was called away, and I quickly cut it loose from the table. The foam broke free rather suddenly, and I tore the tabs out of the fuselage, and tore the nose off. I have some more patch work to do.
Top came out at 5.8 grams, but will be lighter after I sand the fuzz off. Good news is that it fit nicely in the lower half.
Old Oct 31, 2012, 12:24 AM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
Thats cheating !!!! Im kidding.
Good luck, thats gonna look awsome when its finished;.
chester2240 is offline Find More Posts by chester2240
Old Oct 31, 2012, 05:17 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Didn't feel like cheating with all the time spent drawing it.
Deciding on what to make the tailerons from, thinking the foam may be to thin. Maybe balsa, or fiberglass. Did a little patch work. Also considering how to finish the foam, thought about fiberglass, tissue, polycrylic, or just paint
Old Oct 31, 2012, 11:35 AM
Joined Jul 2011
1mm depron will work for the vertical staberlizers and maybe the tailerons, might need to stiffen them with a cf rod. I use polycrlic mixed with a little bit of micro balloons on my nose cones and canopys to stiffin them up and keep the tip of the nose from breakig off.
If you need some 1mm depron let me know i have a few more large sheets of the stuff
Old Oct 31, 2012, 02:49 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Thanks, I still have a sheet of Depron. Looks like it is a little stiffer than the XPS foam.
Old Oct 31, 2012, 05:44 PM
Joined Jul 2011
What r u thinking the final weight of the airframe gonna be and when its RTF ?
Old Oct 31, 2012, 06:40 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
I think around 20 grams for the airframe, 16.2 grams for the two fans, about 3 grams for servo's, and 10 grams for esc's, Not sure about the lipo, and reciever, I think 50 to 60 grams should be doable for them. So about 100 to 110 grams total. Might be able to get a little under that, but not much.
Old Oct 31, 2012, 10:58 PM
Joined Jul 2011
O nice it should fly fine at that weight and having 2 of those 30mm edf, are u gonna use 3s?
Im building another F22 but mine is a 15in WS and a pusher and im aiming at a 60gr RTF with 180mah 2s lipo so far it weighs 45 gr with all the electronics (not including battery) and all i have left to do is add the vertical stabilizers and canopy then its off to paint!!!
Old Nov 01, 2012, 02:50 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
I see that some are running F-86 fans on 3 cells. I don't know how long they would last on 3s, so will probably use 2 cells at first. I have some Bluebird 303 servo's I'll probably use, unless I find something better. That will add a couple grams, but save some money.
I'm looking at the XP7A esc's for it, but most stores are out of stock.
Old Nov 02, 2012, 01:59 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
The two fans should total around 18g.
Great job on the model so far Rob! You could even use one fan and split the air out the back to save more weight. It would still scoot along.
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 02, 2012, 03:04 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Thanks.
Maybe my scale is broken. I'm getting 8.1 grams per fan with motor, on my other scale. I was thinking about fitting one fan. It would have to be scaled up a little, or the fuselage fattened to make room. That would make fitting servo's, and the esc's much easier.
I glued the wings on today.
Old Nov 03, 2012, 03:10 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Cut the canopy. Can finish the repair behind the canopy now that I know where the edge is. Thinking of fiberglassing it. I'll have to decide on what to use. Thinking epoxy, or a mix of white glue, gorilla glue, and water.
it glides nicely, and tail heavy as is. So think i'll be ok on the balance when its done.
Old Nov 04, 2012, 03:00 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Here is a short video of cutting the fuselage on the mill.
http://www.rcgroups.com/forums/showa...2&d=1352019431
Worked on the tail. Need to figure out how I'm going to hinge it.
Sold TX LPU: 30mm EPO Nano F-86 Sabre - PNP w/batteries: $55 Roswalt Aircraft - Electric - Jets (FS/W) 2 Jul 28, 2012 04:03 PM
Sold LPU San Antonio TX: JPower 50mm MiG-15, F-86, F-22 and F-35. FoamJunkE Aircraft - Electric - Jets (FS/W) 3 May 09, 2012 12:00 PM
For Sale Great Planes F-86 Micro EDF 30mm with Anylink $85 Shipped tsever00 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 28, 2012 03:01 PM
Alert HEY EVERYONE! the great planes 30mm f-86 foam parts are all in stock! Mason W. Micro EDF Jets and Power Systems 5 Mar 05, 2012 09:28 PM
Off Site Great Planes 30mm Brushless Micro EDF F-86 Sabre battery adapters glenn2626 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 26, 2012 01:17 PM
