Old Nov 17, 2012, 07:45 PM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
i just tested the retracts out, and they just keep getting better. they operate much slower than normal plastic ones. which is nice, much more scale. and when i grab the pin & try to wiggle it, theres absolutely NO movement. these things are solid. one cant go wrong with these!
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Nov 18, 2012, 05:26 AM
gchrisgo34's Avatar
Joined Nov 2010
http://rctimer.com i just ordered a couple 35-30 1100kv motors from here. i love this place. you can get 100 magnets for like $6. you can build your own motor. i ordered a couple shafts & bearings for some other motors i have. plan to swap the shaft side of some other motors i have. i also ordered some carbon fiber CW and Counter clock wise props from them. they also have regular CW & CCW props. shipping was $2 from hong kong. they've got a lot of really good deals. well worth checking out.
Old Nov 18, 2012, 05:43 AM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Not a bad company Sir, . . . . but do they offer Fast UPS shipping option? I hate waiting 2 weeks for my stuff to arrive.
demondriver is offline Find More Posts by demondriver
Latest blog entry: Flying Star Wars BB-8 Droid!
Old Nov 18, 2012, 04:27 PM
gchrisgo34's Avatar
Joined Nov 2010
they do, but its expensive. i usually get my stuff in about a week. ill let you know when my stuff arrives. i ordered last night, on a sunday. so, we'll see.
Old Nov 18, 2012, 04:29 PM
Up-Out-&-Gone
Joined Mar 2007
One week is not bad at all, I'm very impatient when it comes to having what I need to get stuff finished.
Old Nov 18, 2012, 11:42 PM
gchrisgo34's Avatar
Joined Nov 2010
more pics for ya. the only problem ive found so far, is, the kit is missing the wing bolts. i tried some bolts that were the right size, but the wrong thread pattern. ive tried a lot of different bolts & none seam to be working. im going to have to figure out what to do. i might have to drill new holes and put in some blind nuts. im thinking of doing gear doors. cut the doors out, hinge them, and let a string pull them shut when the gear goes up. those wheels are going to be perfect though. i think im just as happy with the retracts as the plane.
Old Nov 19, 2012, 01:11 AM
Up-Out-&-Gone
Joined Mar 2007
Look'in sharp Sir. . .. very nice work. .. .sorry to hear about the Missing bolts sometimes they put them in the wrong bag in the box or the bag containing the bolt rips & the bolt end up logged in some crevace in the kit.
They might give the wing bolt size in the manual.
Old Nov 19, 2012, 01:16 AM
gchrisgo34's Avatar
Joined Nov 2010
does anyone know where i can find a 35mm spinner with a 5mm collet style adapter? HK doesnt have any 35mm spinners. i figured i might have to settle for a smaller size, but most small spinners have 3.17 or 3mm collets. i'd try to order the parts and build the spinner & adapters that i need. but i cant make any sense of what parts i need. they dont display a lot of the sizes one would need to order the right parts. a lot of the adapters dont say what size they are. so, does anyone know where to get one? thanks
Old Nov 19, 2012, 01:25 AM
Up-Out-&-Gone
Joined Mar 2007
My friend somebody here on RCG will find you the 35mm spinners you need.
Old Nov 19, 2012, 01:41 AM
Herman Munster is online now
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
Wing bolts are M4 X 7
Not sure if you know this, but in case you don't, all the gear, mains and nose, retract forward.
Herman Munster is online now Find More Posts by Herman Munster
Old Nov 19, 2012, 02:26 AM
gchrisgo34's Avatar
Joined Nov 2010
m4 x 7, where would one get those? and what does that translate into dimension wise? and heres another reason why i waited till i got the plane before i ordered the motors. the biggest prop ill be able to run is 7", or it hits the feus. so, this means i can run a higher kv. which translates into higher performance. which i like. 35mm spinners are hard to find, cause most go 1", 1.25", 1.5" etc... if i had to, i would settle for something a bit smaller, but they look so good when they match the nacelle perfectly. thanks
Old Nov 19, 2012, 07:09 AM
ruff1 is offline
Find More Posts by ruff1
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
North AL, USA
Joined Nov 2009
Oops, wrong type of stuff, thought you were just looking for regular hardware, focusing on wing bolts...
Model is looking great BTW...
deleted..
ruff1 is offline Find More Posts by ruff1
Old Nov 19, 2012, 08:28 AM
gchrisgo34's Avatar
Joined Nov 2010
i was thinking, when i ordered this kit, that i was going to have to cut the monocote film off the top of the wing, and glue & bolt the motor mount to the top of the wing. this is a really nice design feature. you push the mount into the pre-cut slats, and then push it forward, and it locks in place. its a very snug fit too. i had to sand a couple spots on the mount with my dremel. took about 3 minutes to do. this kit is not going to be as much work as i thought it would be.
Old Nov 19, 2012, 10:02 AM
gchrisgo34's Avatar
Joined Nov 2010
http://www.rcgroups.com/forums/showt...t22219253heres another thread i found about the ys-11.
Old Nov 19, 2012, 10:08 AM
gchrisgo34's Avatar
Joined Nov 2010
i can see that ill have to trim the window decals down a bit. they're no where near close to stock. cutting them smaller will make the kit look a lot more scale.
New Product Hobbyking NAMC YS-11 Twin TurboProp Fiberglass Kit FieldofDreamsFlyer Scale ARF/RTF 7 Jan 06, 2013 09:42 AM
Build Log hobbyking namc ys-11 gchrisgo34 Foamy EDFs 0 Oct 26, 2012 11:15 PM
Sold Hobbyking 5300Kv 53mm EDF combo $11 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 05:45 PM
Discussion New for 2009....KYOSHO NAMC YS-11 airliner (prototype) boolis Parkflyers 1 Nov 27, 2008 03:31 PM
