| Thread Tools |
| This thread is privately moderated by IntegrityHndywrk, who may elect to delete unwanted replies. |
Flight #10 - Time to push my limits
Flight Video Update 12-02-12
Gaui X5 - Replacing First bevel torque tube gear.
So after a perfectly good flight i managed to slap the tail really hard coming in for a landing. These gears have taken a few hits on the foam pad and even a few roll overs during AR practice. But this time it stripped out pretty bad. The swap out was pretty simple, but it did require something i was not fond of. Loosening the tail boom and sliding the boom back to access the first gear in the line. This is the most likely gear to strip it seems. The bottom section of this gear has a metal gear pressed against the AR gear. So this one is most likely to absorb all the damage, in my opinion. The images below have notes on what i did. Don't forget. If you have trouble removing the bolts. Apply some heat with a soldering iron to break the thread lock.
Flight Video Update 02-23-2013
Flight video Update 03-30-13
I have to say. These three videos here are probably some of the best flights i have on film so far. I lengthened my cyclic stick on my TX and it just fits better in my hand now. So i have a better control over the heli, which gives me added comfort.
My Youtube Channel: http://www.youtube.com/IntegrityRC |
Gaui X5 FES Tail Wag Issues
Okay, in this section i wanted to talk about something that seems to be a common issue with the Gaui X5. It's not a big problem and it's more annoying than it is dangerous. But it seems at some point everyone ends up fighting a slight tail wag on this heli. I just wanted to point out here the few basic things i did to keep my tail from wagging. There are basically only 3 things i attribute to my tail not wagging anymore after over 370 flights @ 5-6 minutes each.
First of all I want to mention that i didn't have any tail wagging till around 200 flights or so. Then it begin to have a slight wag when hovering or if i flipped very hard the tail might wag a little around the flip. It was never a heading lock issue or anything. Just a slight wag that didn't seem to have any relation to the gyro gain at all. I checked all of the mechanics repeatedly and nothing seemed out of place. In other words nothing seemed to be binding or have any slop in it. Well, eventually i got around to checking out all of my ball linkages on my main rotor and that gave me the brilliant idea to check the rudder linkages... DOH! The rear plastic linkage was so worn out i could practically pop it off with no pressure at all. So first thing to check if your getting tail wagging after many flights would be your rudder linkages. With that out of the way. I thought i was in the clear! the wag seemed to go away for the most part. But it started to show up again every now and then. It was a slightly different wag.....So on to the second thing.. #2.. Clean your tail shaft and slider and keep them dry lubed if possible. I use Tri-Flow "Superior Dry" on my tail shaft & slider. It goes on wet and dried into a dry film of P.T.F.E. Or Teflon. It's very important not to get this into your bearings because it could make them gritty. The white carrier solution seems to work well at getting the lubricant inside the slider on the shaft and removing some of the dirt. Turning the white solution black. You swab away the gunk and repeat till it seems to not get so black any more. Again, keep this stuff out of the bearings. Both on the slider and on the tail box. Once you have the black gunk and cleaning part out of the way. Apply a small drop of the solution and work it in till it dries. Wipe away any gunk that forms and bring some swabs with you when you go flying to clean the shaft and slider preflight if they look dirty or gunky. #3. I don't honestly know if this third one actually had anything to do with fixing my tail wag issue. I'm fairly certain the above two things took care of 90% of it. But reducing the cord width on the tail blades could calm the gyro a little too. I don't know. But i installed the KDBB tail blades and ever since i haven't noticed the tail wag start back up again. I also am keeping up on lubricating the tail bearings and shaft now though. So the stock blades are not the "problem", I'm sure. But at higher head speeds, the narrow blades might be best. It's pure speculation on my part. |
Scorpion Backup Guard
Since the stock X5 ESC's BEC seems to fluctuate voltage to the RX during flight. I thought about installing a separate BEC. But first i wanted to try the lazy way of fixing it and adding some security to the X5. So far, it doesn't keep the voltage above 5V because it receives drain from the servos etc. So it was registering at a minimum voltage on my DX8 at 4.6v or 4.7v. This is much better than the 3.6-4.1v that it was typically dropping down to. I might add the voltage drops seem to be random and not exactly in relation to my stick movements. I have a feeling the Telemetry system has something to do with this issue. Because it is drawing power to transmit also. Just a guess. Previous to the Scorpion Backup Guard. I had installed some capacitors in the RX line. This seemed to help keep the voltage up above 4.1v most of the time. Lots of times it would stay around 4.5. But it still did drop down to 3.8 or so every now and then. I've only flown 4 flights with the backup in place and so far the lowest reading has been 4.6v. I'm very sure these are very short voltage drops but 3.6 or 3.8v is scary as hell. So I find the backup guard to be doing it's job quite well so far. Possibly one of the best solutions for redundant rx power on your heli. Update 04-14-13: Okay this thing is working out nicely. When i have my DX8 data logging turned on the RX voltage spikes down as low as 3.6v and it does it much more often when data logging is on. But it still happens occasionally when it is not on also. So here is two graphs. The first one is with the backup guard turned off. The second one is with it turned on. You can definitely see the difference. |
Flight Video Update 04-22-13
04/20/2013:
04/21/2013:
| Thread Tools | |
| Wanted gaui x5 fes airframe | BIG JOSH | Aircraft - Electric - Helis (FS/W) | 1 | Oct 14, 2012 07:06 PM |
| Wanted gaui x5 FES | sagsag | Aircraft - Electric - Helis (FS/W) | 0 | Jul 06, 2012 07:28 AM |
| Question Opinions on the Gaui X5 FES | Username> | Large Electric Helis | 8 | May 01, 2012 03:21 PM |
| Sold Gaui X5 FES flybarless | rablett | Aircraft - Electric - Helis (FS/W) | 2 | Apr 05, 2012 04:03 PM |
