Old Nov 29, 2012, 02:05 AM
addifromgermany is offline
Find More Posts by addifromgermany
Joined Sep 2012
its a digital Servo, an analog servo would fry very fast at this rx
addifromgermany is offline Find More Posts by addifromgermany
Old Nov 29, 2012, 02:22 PM
TonyTypeS is offline
Find More Posts by TonyTypeS
United States, CA, Hacienda Heights
Joined Jun 2004
according to Walkera's website they say to only use digital servos with the FBL system
TonyTypeS is offline Find More Posts by TonyTypeS
Old Nov 29, 2012, 07:25 PM
jldean78 is offline
Find More Posts by jldean78
USA, Virginia
Joined Dec 2010
Has anyone used their Spektrum radio with this heli? I'm assuming you could put your own rx if you purchased the body only?
jldean78 is offline Find More Posts by jldean78
Old Nov 30, 2012, 04:01 AM
asp is offline
asp
Find More Posts by asp
asp
Spain, CN, Villaverde
Joined Apr 2012
To do something like that you would have to put a different gyro too. Walkera rx it's a all in one thing. I don't think it's possible to wire it to a spektrum rx.
So you'll have to take away the most expensive of this heli electronic elements.
asp is offline Find More Posts by asp
Old Nov 30, 2012, 04:30 AM
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
The easiest way will be to use a Spektrum AR7200BX receiver with BeastX.
I don't think the receiver for the V450D03 will be that expensive. It appears to be a stripped down version of the 2702V. It will probably be on sale on its own for around $60-70.
zadaw is online now Find More Posts by zadaw
Old Nov 30, 2012, 05:13 AM
Joined Sep 2012
In Germany its the same prive for the 2703 as for the 2702.
So i think its an upgradet rx in comparison to the 2702, it working much better then the 2702.
The only thing they stripped down is a free channel for a gear or other aux devices
Old Nov 30, 2012, 06:01 AM
zadaw is online now
Hong Kong
Joined Jan 2010
I wonder if you can program the 2703 to compensate in either direction as the 2702 for elevator, aileron and rudder?
Old Nov 30, 2012, 10:03 AM
eugenechong is offline
Find More Posts by eugenechong
Joined Jun 2011
There's no setup button on the 2703 at all. I have both 2702 n 2703. 2703 is plug n play but I'm not sure if u can use any other servos on it as u can't set it up at all.....
eugenechong is offline Find More Posts by eugenechong
Old Dec 01, 2012, 03:45 AM
Joined Sep 2012
i am using kds servos on it, they work fine :-)
Ok, youre right, the 2702 had some more options to setup, but the 2703 works better in flight and thats the most importand thing for me.
Old Dec 01, 2012, 06:51 AM
Joined Jun 2011
ya I totally agree that the 2703 is much way better flying gyro than the 2702....
Old Dec 02, 2012, 01:57 AM
Joined Jun 2011
Which kids servos r u using?have u got a link to it? Is it just plug n play or do u have to reverse anything .....?
Old Dec 02, 2012, 04:26 AM
Joined Sep 2012
This ones http://www.ready2fly.com/shop/USER_A...3&Ziel_ID=1232
they are nearly plug n play, they run in the right direction but you will have do modify the frame a little bit for the elev and aile servo with a dremel. Only a few milimeters have to be removed from the frame to make them fit in
Old Dec 02, 2012, 05:48 AM
Joined Jun 2011
Thx for the heads up addi
Old Dec 02, 2012, 05:56 AM
Joined Sep 2012
you´re welcome :-)
Old Dec 02, 2012, 07:42 AM
Joined Jun 2011
Addi,
Is this the same? The speed of this one is somehow different from the one that u have shown....
http://www.myrcmart.com/kds20044-n29...vo-p-3489.html
New Product Walkera's new Y6 and octo minis! ddoltar Multirotor Talk 19 Feb 28, 2016 12:40 PM
New Product Walkera New V120D02S V2---NEW 6-Axis Gyro and Upgrade online receiver! bigflier Micro Helis 144 Feb 14, 2016 10:56 PM
Discussion Walkera New Product Forecast: V450D03 oomodel Large Electric Helis 4 Apr 09, 2015 11:27 PM
Sold Walkera CB100 Like New - Brushless Tail Motor Upgrade scharlach Aircraft - Electric - Helis (FS/W) 1 Jun 11, 2012 06:48 PM
Sold Walkera 4G6S 4G3 4#6S 4G6 4#6 BL Brushless motor and walkera like new esc blueindian Aircraft - Electric - Helis (FS/W) 1 Feb 19, 2011 12:51 AM
