Old Oct 26, 2012, 05:13 PM
Brian Courtice is offline
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
Source for wood booms for fpvmanuals tricopter?
I got my tri flying today, and I love it! Despite winds over 15 mph for the maiden, the machine was stable and fun to fly. Unfortunately, I managed to break one of the wooden arms already.
Has anyone got a source for some replacement arms?
Brian Courtice is offline Find More Posts by Brian Courtice
Old Oct 26, 2012, 05:30 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
Lowes maybe homedepot as well sell 3/8's square poplar and spruce stock is 36 inch lenght's, I used them on mine before switching over to 10mm fiberglass tube W/ 5/16 wood inserts glued in.
http://www.lowes.com/pd_27594-261-44...lar&facetInfo=
John
shultz is offline Find More Posts by shultz
Old Dec 03, 2012, 08:53 PM
overmyhead is offline
Find More Posts by overmyhead
United States, FL, Bradenton
Joined Jan 2012
"10mm fiberglass tube W/ 5/16 wood inserts glued in"
So do you think the fiberglass tube is stronger and lighter?
How is it working out for you.
Thanks.
overmyhead is offline Find More Posts by overmyhead
Old Dec 03, 2012, 10:05 PM
shultz is offline
Joined Sep 2009
The fiberglass is stiffer than wood with or without the insert but weaker, with the wood insert glued in the fibergalss is stronger than the wood arm. as for weight, I think the fibergalss W/ wood insert is slightly heavier... well worth it IMHO.
If you use fibergalss tube on a frame like the FPVmanuals IMHO you MUST add the wood insert, the holes needed for mounting to the frame and the groves that need to be cut for the motor mounts weaken the fiberglass far to much without the wood insert.
So far the arms are working fine, I see no reason to change. The only problem is finding the 10mm fiberglass arms... out of stock EVERYWHERE last I looked
John
Old Dec 04, 2012, 07:53 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
10mm wooden arms in a number of woods.
https://www.magnumwood.com/cart/Prod...?ProductId=942
-K
kad is offline Find More Posts by kad
Old Dec 04, 2012, 09:22 PM
Free as a bird now.
Joined May 2002
I found exactly the right replacement wood that I needed at Lowes.
Old Dec 04, 2012, 09:51 PM
Joined Jan 2012
Thanks for the pointers. Do you think the wood or wood/fiberglass will be weak enough in a crash to break before the black delrin plates on the FPManuals? or do you recomend kirfing or notching the wood slightly as someone mentioned in order to form a break point?
It appears that Radical RC has the fiberglass booms used for Slowsitcks:
http://www.radicalrc.com/category/Mu...or-Copters-458
Has anybody tried joining the wood to fiberglass with the boom joiners also on that website?
Help! FPVmanuals Tri V1.2 "BOOM JIG" partzee Multirotor Talk 0 Oct 08, 2012 02:39 PM
Wanted Need Parts For FPVmanuals Tricopter V1.2 partzee Aircraft - Electric - Multirotor (FS/W) 10 Oct 06, 2012 08:55 AM
Discussion Source for CF Tail Booms? acetech09 Electric Sailplanes 3 Sep 05, 2012 01:58 PM
Sold FPVmanuals.com Tricopter V1.1 HansAuf Aircraft - Electric - Multirotor (FS/W) 3 Feb 09, 2012 10:18 AM
Sold FPVmanuals Tricopter w/ motors airbagit13 Aircraft - Electric - Multirotor (FS/W) 12 Jan 17, 2012 09:06 PM
