| Thread Tools |
| This thread is privately moderated by SkyCadet, who may elect to delete unwanted replies. |
ORX 3AS system test video!!!
I have below the test video of my newly-installed Orange RX 3-axis rate servo stabilization system (ORX 3AS for short!).
The unit in this case was installed under the wing facing down (upside down technically), and thi srequired me to reverse the aileron channel behavior to allow for opposite correction. I also had to reverse my elevator channel as well. No big deal. The idea here is to be able to run the servos as normal, but with opposing movement upon a non-input change in orientation. In the case of this plane, being a 3-channel model, the ailerons are running the rudder. This model also has a LOT of rudder authority, and as such, roll was the better option to correct for. I see this when flying in wind, where the plane may roll suddenly a bit during gusts. I set both channels around the 2-o'clock position, which was enough movement to do SOME correction, but hopefully not too much to prevent more serious aerobatics with the model. I may have to tweak these settings, but we'll see... Video below, showing the action I set for my first trials:
Enjoy! SkyCadet |
Latest blog entry: more "bling" for the glider...
Thanks Lynden!
Actually, I was reading up and found the HK i86 3-axis system ($3 more at HK) supports 3D/aerobatics better, from reports I have found. I'd love to oblige you on the video, it got VERY windy (windier than will be flying EVER!) and snowy this weekend. If the wind drops around 15-20km/h, I'll shoot some video and post it here. SkyCadet |
| Thread Tools | |
| Discussion HEXA SUPER HEAVY LIFT TESTING Video! - Maiden flight, 10lb payload test & GPS PH | wac | Multirotor Talk | 23 | Oct 15, 2012 07:34 PM |
| ***HELIUP*** Testing the new CNC FLYBAR SYSTEM VIDEO | HighFreq | Mini Helis | 18 | Mar 29, 2005 08:43 AM |
| Alert "Hong Kong" video systems on eBay etc: TEST REPORT! | CactusJackSlade | Aerial Photography | 2 | Feb 18, 2005 07:55 AM |
