Going the whole hog and making a mould for this one.
Spent a few minutes (read hours) shaping the fuse today. Going to need about another 10 hours to get it 100% Don't worry Johann, i'll be throwing this one off the local slopes too ![]() I have chosen to use HQ 3,0 - 13 (the 13% thickness in keeping with the 13% thickness of the full scale airfoil) |
Managed to finish the shaping today. There are still some lines I'm not 100% happy with, but those will get sorted out with microballoons once the cloth is on. I find it easier to fix on a hard surface, instead of the soft foam.
I detached the tail boom during shaping because it was getting in the way. It was then shaped and re-attached. |
Hi Dudley,
This is looking real good, My very first big sailplane was made with expanded polystyrene and keeping the boom part straight became a big problem. I eventually heated a piece of spring steel (normally used on undercarraiges etc) and pushed it all the way down the middle of the boom ,from the tail and then managed to epoxy in a hardwood dowel with good effect, carbon will also do the trick. It will get better as you start adding some glass, I do a layer at a time. regards Mike |
Hey Mike,
Thanks, the first layer of glass in on, the boom is pretty stiff now. I'm going to have to learn how to put glass on a large foam plug in one go. I did the bottom in the morning and the top in the afternoon. It need to give it a little sand around the seams and add the lighter glass. |
Thats exactly right, top, and then bottom , you battle to do both sides at once. ![]() To get the glass to work easy use something like the 163gr from AMT it drapes on compound curves nicely. more pictures? cheers Mike |
| Thread Tools | |
| Discussion Scratch Building the Gee Bee Model -Z 1/4 scale (thread #2 | jay/jay | The Builders Workshop | 9 | May 19, 2013 07:15 PM |
| New Product LET 1/3 ASH-31 from SoaringUSA | s2000 | Scale Sailplanes | 9 | Jul 23, 2012 12:43 AM |
| New Product LET 1/3 scale ASH 31 Mi | xroadie | Scale Sailplanes | 2 | Jul 13, 2011 12:12 PM |
| Discussion 1/4 Scale F4U Corsair-Scratch Build | jwlane | Fuel Warbirds | 0 | Feb 13, 2009 09:11 AM |
| Discussion Scratch Building A Gee Bee Model - Z Super Sportster 1/4 scale | jay/jay | The Builders Workshop | 0 | May 19, 2007 11:35 AM |
