Old Oct 25, 2012, 10:09 PM
rpstar is offline
Find More Posts by rpstar
rpstar's Avatar
Dacula, GA
Joined Feb 2008
Need help
So, was all happy with the Extreme Flight Edge quality until I tried to get the left wing on. Something must be wrong with the blind nut as every time I try and thread the wing bolt it just strips the threads down. Trimmed the wing bolt a bit and tried again but it won't go in. It's like the blind nut is a size too small. What do I do now? Can't fly if I can't get the wing attached securely. Hate to call them but I may have to ask for a new wing or at least take it over there and see if they can thread a bolt to it. Seems defective.
Any suggestions?
rpstar is offline Find More Posts by rpstar
Old Oct 25, 2012, 11:46 PM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
Any suggestions?
Definitely call... or email (info@extremeflightrc.com) and just explain the problem.
There may be a burr in the blind nut, I've gotten one or two new in a pack like that before.
Easy to imagine a factory dealing with many thousands of them in a year will get a bad one now and then.
(I've also messed one up by accidentally crossthreading it, but it does generally mess up the bolt threads instead... unless you use a bolt harder than the nut like I did that time)
Generally, I use to use a tap to clear the threads, on any nut that doesn't feel 'right' on my first attempt... but then again, I've always had that sort of tool on hand.
Call 'em! I'm sure they'll take care of you.
C_Watkins is offline Find More Posts by C_Watkins
Old Oct 26, 2012, 12:12 AM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
agree, blind nuts are bad about having problems. If you have a tap you might want to run it through the threads, if not SLOWLY run a metal screw through the threads, if it starts fighting you dont force it. but it will tell you something is for sure a problem on the nut side.
Will the wing bolt screw into the wing when its not in the plane? i have seen the wing holes not line up exact and cause this problem as well.
which edge is this? i might have some spare blind nuts around here somewhere if you cant make it work.
shadow102 is offline Find More Posts by shadow102
Old Oct 26, 2012, 07:11 AM
MLT67 is offline
Find More Posts by MLT67
Joined Nov 2005
Russ this is a simple fix - blind nut probably has some glue that got in the threads. With the wing off - thread a regular bolt through the blind nut and it should clean the glue from the thread. If that doesn't work we can meet up and I'll fix it for ya.
MLT
MLT67 is offline Find More Posts by MLT67
Old Oct 26, 2012, 08:16 AM
rpstar is offline
rpstar's Avatar
Dacula, GA
Joined Feb 2008
MLT
Tried it out of the plane quite a bit last night. I'll try the metal screw idea today. Might be that the nut is twisted also (need to look) and making it impossible to thread. Either way I think I'll be needing a new wing bolt as the nylon one now has too many ruined threads.
Old Oct 26, 2012, 08:25 AM
MLT67 is offline
Joined Nov 2005
I've probably got extra wing bolts
Old Oct 26, 2012, 10:42 AM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
Yeah....my bet is a bad thread in the blind nut. Do as MLT suggest.....if the metal bolt starts to meet resistance back it out an then start it again like you would a tap....go slow. A tap would be better.
GoldCraft is offline Find More Posts by GoldCraft
Old Oct 26, 2012, 12:18 PM
LannyT2 is online now
Find More Posts by LannyT2
LannyT2's Avatar
Braselton Ga
Joined Apr 2009
Had that problem with my FunCub. Went to Ace and got a tap for it.
LannyT2 is online now Find More Posts by LannyT2
Old Oct 26, 2012, 01:15 PM
pecanpatch is online now
Find More Posts by pecanpatch
Home of "Golf Cart Flying"
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
Hate to call them but I may have to ask for a new wing ,
Any suggestions?
Seriously?
Colin had this same problem last week. He ended up shortening the screw down to about 1/2" and it was enough to suffice.
I would call EF and ask them what the thread is.... I tried 3 mm and 4mm and 8-32 on his plane and it wasnt any of those.
I almost think it's 3.5MM.
I would buy the proper Tap, and make them send you 2 new bolts.
I would tap both wings for good measure.
McMaster has all sizes..... this one is under $7
pecanpatch is online now Find More Posts by pecanpatch
Old Oct 26, 2012, 04:52 PM
rpstar is offline
rpstar's Avatar
Dacula, GA
Joined Feb 2008
Ok, you guys were right. You made me remember I had a set of Yak54e wings lying around one of which still had a metal wingbolt installed. Same size as for the 48" Edge. Carefully used it to repair the threads of the nut and now even the nylon bolt goes in, although I really should ask for a new one of those as I ended up trimming it a bit more than I'd like due to the damaged threads.
Really should get a set of thread taps though as this is not the first time they would have been handy.
All I have now is receiver install and hookup as the servo's are already in and adjusted. Oh yes.
Old Oct 26, 2012, 05:07 PM
MLT67 is offline
Joined Nov 2005
I usually trim mine down anyway so I don't have to twist it so much to install it. HOwever I check to see if I have any extras
MLT
Help! I NEED MORE SPEED!!! need some help!!!! cjmartinez103 Power Systems 18 Apr 29, 2012 01:20 AM
Question About to buy a motor and need help deciding what one I need!!!!! bluemeane 3D Flying 4 Mar 14, 2012 11:49 AM
Discussion About to buy a motor and need help deciding what one I need!!!!! bluemeane 3D Foamies 8 Mar 08, 2012 10:40 AM
Question About to buy a motor and need help deciding what one I need!!!!! bluemeane Electric Plane Talk 14 Mar 07, 2012 12:14 PM
Discussion About to buy a motor and need help deciding what one I need!!!!! bluemeane Parkflyers 0 Mar 02, 2012 01:15 PM
