Old Oct 25, 2012, 07:17 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
the HK/Holybro MultiWii 328P Flight Controller w/FTDI & DSM2 Port
i couldn't find a dedicated thread, so i guess i'll open one up.
this thread is primary about the:
Hobby King / Holybro MultiWii 328P Flight Controller w/FTDI & DSM2 Port
if you have any "good to know info" questions or other stuff you want to share about the HK/HolyBro MultiWii 328P Flight Controller w/FTDI & DSM2 Port this is the thread to be.
i will try to keep the most usefull stuff in the first two posts, but to get the usefull stuff i will need your help.
the Hobby King / Holybro MultiWii 328P Flight Controller is a flight controller which runs on the MultiWii code. MultiWii (MWII) is an open source code. for more in depth info and such check out the RC groups thread..
the HK MultiWii 328P flight controller (MWII 328P) comes with the following sensors:
• Atmega328P
• ITG3205 Triple Axis Gyro
• BMA180 Accelerometer
• BMP085 Barometer
• HMC5883L Magnetometer
• Servo output for camera pitch and roll control
• Separate 3.3v regulated power supply for the sensors
• On board logic level converter
Dimensions 50x50x12mm
The MWII328P comes preloaded with quadX 2.1 firmware if you get it from HobbyKing.
if you want other firmwares (tri, quad+, hexaX,hexa+ etc etc) you have to compile your own.
to change the firmware you need arduino (which can be found here) and change some lines/defines in config.h and def.h. (more info later if needed.)
the MultiWii firmware can be found here, this package contains the MWII code and the MWII GUI (MultiWii Graphic User Interface).
to calibrate and fine tune your MWII328P and setup auxchannels as well check settings you will need the MWII GUI.
a nice tutorial can be found here.
all files can be found in my cloud storage also.
i hope this thread will grow for newbe's in the MWII world using the MWII 328P.
dutchcommando is offline Find More Posts by dutchcommando
Old Oct 25, 2012, 07:18 PM
Joined Feb 2012
additional info
reserved for additional info.
Old Oct 25, 2012, 09:44 PM
rhokita is online now
Find More Posts by rhokita
gardena, ca
Joined Feb 2003
The above links to MWII GUI and tutorial do not work.
rhokita is online now Find More Posts by rhokita
Old Oct 26, 2012, 04:52 AM
Joined Feb 2012
thanks fixed.
Old Oct 30, 2012, 08:04 AM
justk1w1 is offline
Find More Posts by justk1w1
Joined Apr 2012
schematics for the board
Anyone know where to get the schematics of the board - or what changes are required to enable the AUX channels - need to know what pins the other three are connected to so that I can enable them in the def.h
justk1w1 is offline Find More Posts by justk1w1
Old Oct 31, 2012, 03:43 PM
macinr is online now
Find More Posts by macinr
macinr's Avatar
USA, CA, Santa Barbara
Joined Feb 2003
AUX1 works out of the box. I could not get AUX2 to work - there are reports that the processor cannot handle more than one AUX port unless you use the satellite. When you use the satellite with this board you cannot also use the USB port - and the satellite connection maps AUX1 to the GEAR switch, and AUX1 to the AUX2 switch, at least on my JR9503.
The latest issue I am having with this board is that I can no longer flash it after uploading the r1177 multiwii. Guess I'll have to figure out how to program with an AVR programmer...
macinr is online now Find More Posts by macinr
Old Oct 31, 2012, 06:38 PM
justk1w1 is offline
Joined Apr 2012
What is the issue that you are having in flashing the board?? If you are get the not in sync error then I have actually found a couple of issues that have caused this: The first was having the AUX2 connected to the RX. I'm assuming that it is actually connected to the Serial RX/TX lines and therefore creating the issue.
The second was a silly config change that I did.
There could have been a change in the code that has effected the serial for R1177 - for this you need to try to catch the board startup while the bootloader is running and not the actual program.
Start the compile and flash of the board from the Arduino Gui without the board plugged in. Once it gets to about halfway then plug the board in. It will probably take a few goes to try to catch it at the right time - other option is as you say use the AVR programmer.
I actually wanted the schematic so that I could see where the AUX2-4 pins were actually connected to. The 328P should be capable of atleast 2 AUX ports with a standard RX and all 4 ports with a serial RX.
Old Oct 31, 2012, 08:16 PM
Joined Feb 2012
i have heard about using the unnamed pin next to the D11 pin,it should be D12 but is unnamed, for the AUX2 and comment out the line that let's you use D12 as Aux2.
i haven't tried it though..
Old Nov 01, 2012, 08:40 PM
macinr's Avatar
Joined Feb 2003
Thanks for the tip about receiver being connected to AUX2. That's what it was.
Old Nov 02, 2012, 03:51 AM
xardinen is offline
Find More Posts by xardinen
Joined Aug 2011
I've been waiting for a thread dedicated to this board as I am a owner of one .
Im using it on my micro quad which is about 20cm m2m, it's a pain to calibrate the PIDs. I can barely get of the ground with it currently, the problem is that the quad seems to tilt to any side in the air which causes it to kiss the floor and send the props flying across the room . Every since one of the folding props of my sailplane came loose and smacked me between my eyes I've always used safety goggles while operating RC stuff.
xardinen is offline Find More Posts by xardinen
Old Nov 02, 2012, 05:22 AM
Joined Feb 2012
did you trim it out in acro before attempting PID tunning?
also i had problems at first, although the board was calibrated with the upside up en perfect level, in the GUI it showed up like it was upside down..
a recalibration fixed that for me.
i am still PID tunning and i still have a slight wobble and drift.. my PID's are pretty high P and D above ten, but I under 0,030.
it flies ok, but not as great is it should be..
Old Nov 02, 2012, 11:00 AM
xardinen is offline
Joined Aug 2011
No I didnt as I couldnt read my PIDs from the GUI if I only had the gyros defined in the code and leaved the acc commented. Now I've assigned acc to aux1 but its still a bitch to tune. As I said the quad seems to tilt to either side when trying to fly, maybe too low P.
Old Nov 02, 2012, 03:07 PM
Joined Feb 2012
yeah sounds familiar..
Old Nov 03, 2012, 01:04 PM
xardinen is offline
Joined Aug 2011
Second time it flips over and sends pieces of two props flying across the room, this is getting really frustrating. I dont know what Im missing in the configuration.
Old Nov 03, 2012, 04:04 PM
Joined Feb 2012
can you paste your config.H?
Discussion Has anyone tried the new HobbyKing MultiWii SE V2.0 Flight Controller w/FTDI rernewe Multirotor Electronics 2 Jun 09, 2014 10:07 AM
For Sale Flash Sale: $33 bucks! MultiWii SE 1.0 w/FTDI & DSM2 Port mcashatt Aircraft - Electric - Multirotor (FS/W) 13 Oct 26, 2012 05:26 PM
Sold Now in stock: MultiWii SE 1.0 w/FTDI & DSM2 Port mcashatt Aircraft - Electric - Multirotor (FS/W) 0 Oct 25, 2012 12:37 AM
Discussion New MultiWii SE V2.0 Flight Controller w/FTDI Crissbrasil Multirotor Electronics 7 Oct 20, 2012 04:28 AM
Discussion HK MultiWii SE V2.0 Flight Controller w/FTDI Sketch Judar Multirotor Electronics 7 Oct 15, 2012 12:56 PM
