Old Oct 25, 2012, 04:14 PM
Pyrofan is online now
Find More Posts by Pyrofan
Pyrofan's Avatar
United States, GA, Perry
Joined Jul 2011
Is this a good setup?
Ok. dont know if this should go here or not but i can remove it if need be. So iv played with the idea of FPV. I think im gonna take the dive and get in. I saw a vid made by FliteTest on youtube and it showed this setup : http://www.hobbyking.com/hobbyking/s...SC_520TVL.html I dont plan to fly too far ( I have a very open area). There are 0 towers around to interfere. This is within a 5 mile radius. I know how fly well. So what do yall recommend? The cheaper the better
Pyrofan is online now Find More Posts by Pyrofan
Old Oct 25, 2012, 04:24 PM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Go for it dude it looks like a great starter pack. Personally I've never used 900ghz but if there are no mobile towers around you then you should be ok. Have you thought about using 5.8? Or even 1.2g with a low pass filter if you are flying with 2.4g radio gear?
Teamsherman is offline Find More Posts by Teamsherman
Old Oct 25, 2012, 04:34 PM
Pyrofan's Avatar
Joined Jul 2011
Nope. Just did what i saw in the vid. I know each frequency has its Pro's and Con's. Is 5.8 or 1.2 better or is it just a matter of opinion. And yes im using 2.4Ghz.
Old Oct 25, 2012, 04:54 PM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
Check my new thread out. I listed links and info for a cheap 1.2ghz setup for easy 2 mile range http://www.rcgroups.com/forums/showthread.php?t=1756304
Koo is offline Find More Posts by Koo
Old Oct 25, 2012, 06:43 PM
Member #1
Joined Aug 2011
I fly both and find 5.8 is great for up high with clean line of sight but the 1.2 is great for down and dirty stuff as it penetrates trees and other objects quite well. I also like the small size antennas for 5.8 and the smaller Vtx's as the 1.2 gear is quite large so best suited for larger aircraft.
Old Oct 26, 2012, 03:21 PM
Pyrofan's Avatar
Joined Jul 2011
so as a platform i think im gonna build the Peace Drone. Is this a good choice? seems better to me.
Discussion 5.8 GHz 200-900mw + Fatshark goggles: Is this a good first FPV setup? VuzeDroid FPV Talk 18 Aug 14, 2012 04:21 AM
Discussion Good Setup, Bad Setup, What setup is good? Discusman Mini Helis 11 Oct 03, 2006 09:29 AM
Is this a good motor/esc setup ?? Good Advise WingsofEagles GWS (Grand Wing Servo) 6 Nov 14, 2003 09:16 AM
brushless setup is this good ? jeddy11 Parkflyers 9 Jul 01, 2003 06:06 PM
Opinions needed: Is this a good trainer setup (glow conversion) ?? ARE Power Systems 3 Sep 03, 2002 01:34 PM
