Old Dec 12, 2012, 12:50 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I have thoroughly enjoyed following this thread since the first post Humbertomelo!
Fantastic build log and progress.
I wish you the best of luck with the maiden!
NitroCharged is offline Find More Posts by NitroCharged
Old Dec 12, 2012, 12:43 PM
humbertomelo is offline
Find More Posts by humbertomelo
Brasil, GO, Goi‚nia
Joined Feb 2009
CoolerByTheLake, you are right! I did a quick test here and guess what, the blades has broke in thousand pieces, che*t ! Too fragile this CS 12 blade EDF... I did the static balancing before running the EDF for hours and get the maximum balancing point... well, not enough. I have one spare EDF, let's try again...
The super habu has become a big one jet, 90mm EDF are off the table, did order a new 120mm EDF, 4 blades, 5000w motor...
Turnigy C580L-870 Brushless Inrunner EDF Motor
http://www.hobbyking.com/hobbyking/s...1968&aff=97846
High-Performance 4 Blade 120mm EDF Unit
http://www.hobbyking.com/hobbyking/s...7617&aff=97846
humbertomelo is offline Find More Posts by humbertomelo
Old Dec 12, 2012, 12:48 PM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
Sorry to hear that. There is an entire thread on RCGroups Electric Ducted Fan Jet Talk on this fan, which contains a number of tips to keeping this fan together. If you haven't already, you should check it out.
alexandermh is offline Find More Posts by alexandermh
Old Dec 12, 2012, 01:38 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
That CS fan is just not meant for high power, they just expolde. I have the JetFan 90 for my build. Mine will be smaller than yours, so I think 3000W+ (Het 700-68-1680KV 8s, could also use there 1500KV) will be more than enough. If the weight comes out close to what I am shooting for, that's over 300/W lb.
Just glad you found out before doing damage, or totaling the plane.
I would say that the JetFan 90 with the right motor would fly your Habu very nicely.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Dec 12, 2012, 03:03 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
OK, i think 90mm are good for 3000g to 4000g jets, this big Habu reaches 5500g ....so, i need a bigger EDF.
Old Dec 12, 2012, 03:18 PM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
http://www.hobbyking.com/hobbyking/s...att_980KV.html
D_FAST is offline Find More Posts by D_FAST
Old Dec 12, 2012, 04:18 PM
Joined Dec 2008
humbertomelo You may change your mind after seeing this video. His plane weighs 16lb or 7257g. You be the judge!
My F-86F will weigh about 15lb/6800g and I will be using the JF90.
http://www.rcgroups.com/forums/showp...&postcount=628
Old Dec 13, 2012, 10:31 PM
Brasil, GO, Goi‚nia
Joined Feb 2009
CoolerByTheLake, It seems a very good setup. I have one here very similar in numbers:
CS 5 blades 90mm EDF, 140a and 3100 watts at Max power, 8s Lipo 40c,
D_FAST, It looks like a great EDF!
Let's try on this Saturday... :-)
Old Dec 14, 2012, 12:14 AM
stingeragents is offline
Find More Posts by stingeragents
Joined Jan 2011
Better for fan to blow on ground than in air
stingeragents is offline Find More Posts by stingeragents
Old Dec 15, 2012, 12:44 AM
Joined Dec 2008
Originally Posted by humbertomelo View Post
Weight specs
Fuselage: 2200g
Lipos: 1400g
Servos, EDF, Speed: 600g
Total: 4200g
humbertomelo Does the 2200g include ALL the flying surfaces, too?
Old Dec 15, 2012, 08:35 AM
Brasil, GO, Goi‚nia
Joined Feb 2009
CoolerByTheLake,
2200g was a weight estimative, the final weights are:
Lipos: 1380g for 12s and 920g for 8s
Fuselage with electronics: 4120g
Total: 5500g
Old Dec 15, 2012, 10:51 AM
Joined Dec 2008
humbertomelo thanks for taking the time to answer my questions. It has been very helpfull. I am still in the planning stages, but I did notice that your Habu and
my project have the same Length vs WS ratio, 6/5. Mine will be 1/6th smaller at 60"Length, WS 50". By using the various numbers you have provided, I am failry confident I can come up with an AUW of around 9lb/4082g with an estimated thrust of 4.2-4.3Kg.
Now all I need is lots of practice in your foam bending technics. I am sure there will be many mistakes!!!
You have taken the next step in the evolution of building with foam.
Can't wait to see the maiden video.
Old Dec 16, 2012, 01:22 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
This fan produces 9.9 lbs static on the bench, on 9s. I didn't get the thrust on 10s, but she flies on 10s now. My Habu 32 weighs approx 8.5 lbs.
It's faster than P-20 power in this airframe.
The motor is a HET 700-68-1680 with a CC ICE2 120HV
The video is on 4000mAH, but 5000's will be in there shortly.
This setup should fly many 90mm birds nicely, at a nice little weight savings. Something to consider.
Las Vegas 2012 Habu 32 demo (4 min 30 sec)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Dec 17, 2012, 06:31 AM
Brasil, GO, Goi‚nia
Joined Feb 2009
efflux RC,
Sure, the 90mm habu with efflux edf and Het motor are a great combination! but i need a sponsor to get one efflux EDF :-) are u interested?
Old Dec 19, 2012, 06:44 AM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Mark,
On bending the depron......
If you can find a good place to lay your heat gun (i use an old shirt to keep it still on my work surface) and use 2 hands to work the foam passing it back and forth in front of the heat you will have good luck...Its a little harder to hold the gun andfoam to work it into the bend you desire...
Just try not to leave the hot air in one place for long or it will ruin the piece..
Another cool trick is if you get the bend to tight you just add heat again and the foam will open right back up on its own if no force is beiing applied to any of the sides...
Its very cool when you get a piece bent perfect and it fits right in the spot you are trying to cover...
Take care all..............Chris
Hover or die is offline Find More Posts by Hover or die
Sold Eflite 80amp esc and Delta V 32 fan and motor from Habu 32 Mattsrcking Aircraft - Electric - Jets (FS/W) 0 Aug 22, 2012 10:44 PM
Discussion Habu 32 -- where to use metal gear servo's ? rcfun2005 Electric Ducted Fan Jet Talk 14 Mar 29, 2012 07:00 AM
Sold Habu 32 complete electric package choopi Aircraft - Electric - Jets (FS/W) 6 Mar 10, 2012 08:34 PM
Wanted Habu 32 wings and stab fred685 Aircraft - Electric - Jets (FS/W) 0 Feb 25, 2012 06:39 AM
Sold NIB delta 32 fan unit & 32 motor for habu 32 yf22raptor Aircraft - Electric - Jets (FS/W) 2 Apr 29, 2011 11:23 AM
