Espritmodel.com Heli Air
Old Nov 23, 2012, 01:58 PM
Brasil, GO, Goiânia
Joined Feb 2009
Yes, the hinges are made from fiberglass reinforced tape
humbertomelo is offline Find More Posts by humbertomelo
Italia, Veneto, Cordignano
Joined Jun 2011
Very cool!
Axl_74 is offline Find More Posts by Axl_74
Old Nov 26, 2012, 12:48 PM
Brasil, GO, Goiânia
Joined Feb 2009
Hi!
I need some heavy duty horns to install on habu, but i hate buy expensive horns, so i decide to build them. I take my precious blank copper plate an cut 2 small fiber glass parts and voila a heavy duty horn! great!
Old Nov 26, 2012, 12:54 PM
Brasil, GO, Goiânia
Joined Feb 2009
Intake bell mouth EDF
Old Nov 26, 2012, 12:56 PM
Brasil, GO, Goiânia
Joined Feb 2009
After automotive bi-component varnish, My daughter and son to give a real scale.
Old Nov 26, 2012, 02:20 PM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
holy shiznat! she really gives that plane some scale. it's a beast.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 26, 2012, 06:33 PM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Simply amazing! Beautiful work.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Nov 26, 2012, 06:42 PM
Brasil, GO, Goiânia
Joined Feb 2009
LuvEvolution7, Thanks a lot, i know you follow my post since the first one.
efflux RC, also thanks and one day i'll buy one of efflux EDF for my jets!
Old Nov 28, 2012, 10:04 AM
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
This is pretty slick, you have some excellent fabrication skillz my friend. I'd like to see a little more detail on the construction if you have time, maybe how you fold the wings, do they have ribs, etc? I have always wanted to build a very large EDF and this would be a great way to do it very light...
Very nice work!
Jack
jfetter is offline Find More Posts by jfetter
Old Nov 29, 2012, 11:47 AM
Brasil, GO, Goiânia
Joined Feb 2009
Thank's Jack,
The wings have a main tube glued inside the foam core, and a larger size tube glued in to a fuselage, just slide the main wing in to fuselage and align the pins to lock in place. No ribs, because the wing it is a solid foam glassed in both sides.
Humberto
Old Nov 29, 2012, 05:05 PM
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Originally Posted by humbertomelo View Post
Thank's Jack,
Humberto
Thanks for the pictures! So do you crease or put a cut in the back side of the foam when you bend it, does it need heat or anything to curve that tight (leading edge)? Also, what glue are you using for all the foam?
Jack
Old Nov 29, 2012, 05:16 PM
Swat Team Member
P. Richards's Avatar
LV, NV
Joined Apr 2003
Foam Cores
Jack the cores are cut using a wire and bow method from a square block of white foam. they can then be laminated for strength and prepared for operation. You can either order pre-cut foam wing cores with your desired air foil, or cut them yourself. I would think that Humbertomelo, cut them himself using a heated wire string. Those wings are not depron...
P. Richards aka SwatTeam
P. Richards is offline Find More Posts by P. Richards
Old Nov 29, 2012, 08:01 PM
Brasil, GO, Goiânia
Joined Feb 2009
Jack,
P. Richards are right, i use a hot wire and bow method to cut the wing from a square block of white foam (medium density), also i use a regular epoxi glue (5-10min to cure) for all parts.
Old Dec 03, 2012, 10:34 PM
Brasil, GO, Goiânia
Joined Feb 2009
Today i finished the canopy mold and did a cristal PVC canopy on vacuum forming machine. The electronics are almost done! I think i can do the maiden on next saturday...Let's see.
Old Dec 03, 2012, 11:47 PM
“Do it Right The First Time!”
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
humbertomelo , Do you have a new web site, or is yours just down for now?
Can you also fill us in on your components. What Fan, motor, batteries. etc--- Thanks.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Sold Eflite 80amp esc and Delta V 32 fan and motor from Habu 32 Mattsrcking Aircraft - Electric - Jets (FS/W) 0 Aug 22, 2012 09:44 PM
Discussion Habu 32 -- where to use metal gear servo's ? rcfun2005 Electric Ducted Fan Jet Talk 14 Mar 29, 2012 06:00 AM
Sold Habu 32 complete electric package choopi Aircraft - Electric - Jets (FS/W) 6 Mar 10, 2012 07:34 PM
Wanted Habu 32 wings and stab fred685 Aircraft - Electric - Jets (FS/W) 0 Feb 25, 2012 05:39 AM
Sold NIB delta 32 fan unit & 32 motor for habu 32 yf22raptor Aircraft - Electric - Jets (FS/W) 2 Apr 29, 2011 10:23 AM
