Old Nov 07, 2012, 11:39 AM
Tasche is offline
Find More Posts by Tasche
United States, CO, Denver
Joined Nov 2012
Is it possible to fly two of these quads at the same time?
Tasche is offline Find More Posts by Tasche
Old Nov 07, 2012, 11:55 AM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Yes, if you can handle both.
Technically not a problem. Just Bind them as you do with one.
Why would anybody do that ?
mystman is offline Find More Posts by mystman
Old Nov 07, 2012, 02:35 PM
Irock1985 is online now
Find More Posts by Irock1985
aka RC Flyer85
Irock1985's Avatar
United States, CA, Moreno Valley
Joined Jan 2012
New video from Rc-Fever
WL V949 UFO Force 4CH RC Aircraft RTF 2.4GHz w/ Built-in Gyro (2 min 45 sec)
Irock1985 is online now Find More Posts by Irock1985
Old Nov 07, 2012, 03:34 PM
Tasche is offline
Joined Nov 2012
I am interested in flying at the same time as my brother who has one.
Old Nov 07, 2012, 03:38 PM
mystman is offline
Joined Jan 2012
Ah, OK. Different flyer at the same time.
Yes, possible.
Each should bind his v929 after another to avoid binding both to 1 transmitter
Old Nov 08, 2012, 12:03 AM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
The V949 canopy is on sale now. I like the pink one!
FyreSG is offline Find More Posts by FyreSG
Old Nov 08, 2012, 02:35 AM
spike007 is offline
Find More Posts by spike007
Joined Nov 2012
I had order my WLtoys V949 Beetle RC Quadcopter Mini UFO RTF from banggood, just received today but had a problem, after i plug in the Lipo battery to the Quadcopter and push up the throttle (speed stick) to test, the front left blade is not spinning, only the other 3 blades are spinning. At first I thought the front left motor got problem, but when I unplug the Lipo battery and plug in again, now the back right blade is not spinning and the other 3 blades are spinning fine. Do anyone know what wrong with it? Btw, I also received only 2 extra blades(red), there are suppose 4 extra blades missing 2(black) blades. I am disappointed with banggood.
spike007 is offline Find More Posts by spike007
Old Nov 08, 2012, 02:42 AM
XFM is offline
XFM
Find More Posts by XFM
XFM
eXperimental Flying Machines
Joined Aug 2010
Did you charge the lipo first?
They don't come fully charged.
XFM is offline Find More Posts by XFM
Old Nov 08, 2012, 02:45 AM
spike007 is offline
Joined Nov 2012
yes, I had charged it. I also tested with my other old charged lipo.
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
When the quad is on the ground, not all blades will spin. The moment it lifts off, all 4 motors will spin. Try giving it more throttle and let it lift off the ground.
Example, if you place only half of the quad (i.e. 2 motors) on the table, and the other half of the quad suspended in the air, then apply throttle, only the motors of the suspended half will spin while the half on the table will not spin.
Old Nov 08, 2012, 02:50 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
This is the mQX which is very similar to the V949.
MQX, edge of table (1 min 51 sec)
The motors only spin when needed.
Old Nov 08, 2012, 02:54 AM
spike007 is offline
Joined Nov 2012
I will borrow my friend lipo battery (V929) to test again tonight. Thanks XFM.
Old Nov 08, 2012, 03:03 AM
spike007 is offline
Joined Nov 2012
Thanks FyreSG, I had tried put on more throttle but the quad will always swing to one side due to front left blade not spinning, I unplug the lipo and plug in again. Now the back right blade not spinning (other 3 blades spinning), it swing to other side when i put on more throttle.
Old Nov 08, 2012, 03:06 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
The quad needs to be horizontally level when power up. This is to allow the gyros initialize. Try to plug in the battery when it is on a flat surface, e.g. table. Or, plug in the battery then very quickly put it on a level surface.
Old Nov 08, 2012, 04:21 AM
spike007 is offline
Joined Nov 2012
Thanks, I will try it & let you know if it solve the issue. Thanks again.
Mini-Review WLtoys V929 Beetle Ladybird Quad Mini-Review FyreSG Mini Multirotors 3824 Jan 10, 2016 08:05 AM
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5149 Oct 29, 2014 01:57 AM
Discussion Woo.. New mini UFO V949 Beetle 4-axis Quadcopter 4CH face into the market Quadcopter MQ80 Multirotor Talk 0 Sep 14, 2012 10:20 PM
