Old Feb 07, 2013, 12:34 PM
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
Has anyone changed one the stock trnsmitters from mode 1 to mode II? A friend got one and he will never be able to learn on mode 1....I seem to remember someone converting it but it took some soldering....because it;s all on a board.
I tried googling it but got no good hits...
Anyone know how to do it?
mjdee14 is offline Find More Posts by mjdee14
Old Feb 08, 2013, 10:33 PM
Sodbust is offline
Find More Posts by Sodbust
Sodbust NW Kansas
United States, KS, Penokee
Joined Oct 2012
Originally Posted by Bombay View Post
Unfortunately, it seems to fly like the gyro is not enabled. You really have to fight the sticks to keep it from shooting off down the street.
Has anyone else experienced this behavior? Is it a dud...or does he need to reset something?.
I about wore out my 949 before I woke up about this fact and it wasn't learned with my 949..
If you blind and launch off a non level area,, it will want to fly non level..! In other words it will take off down the road as what it sees as level flight was set by the blind/ gyro time on a non level area.. They just don't fly worth a darn like this..
I built a 600mm quad,, and felt I had it all dialed in and the last 2 times up it would hover like a champ.. One morning my driveway was muddy so launched off the side yard with about a 4% slope.. Just about wrecked my large quad with this mistake as level to it was not anywhere near a level hover mode..
Sodbust
Sodbust is offline Find More Posts by Sodbust
Old Feb 14, 2013, 06:19 PM
mc4fun is offline
Find More Posts by mc4fun
United States, CA, Yorba Linda
Joined Jan 2013
Just got my V949 and from reading all the great post I added some GW/EP5443 blades. Unfortunately the shipper messed up sent me 4 CCW and 4 CW blades but they are all black blades. I waited almost a month for them to show up.
Is there a US vendor that sells Orange GW/EP5443 blades?
mc4fun is offline Find More Posts by mc4fun
Old Feb 14, 2013, 11:50 PM
sajo is offline
Find More Posts by sajo
Slovenija, Cerklje na Gorenjskem
Joined Nov 2008
You have luck, I order 2xccw and 2cw blades and I got all ccw but differet colors. Second time I order 4 cw blades and I got 4 ccw blades same color. So now i have 8 ccw blades and 0 cw blades in spare ;(
sajo is offline Find More Posts by sajo
Old Feb 15, 2013, 01:08 AM
reptileman is online now
Find More Posts by reptileman
nj
Joined Jan 2004
Hi anyone know what axis system this has does it have a 4 or 6?
THANKS
reptileman is online now Find More Posts by reptileman
Old Feb 15, 2013, 04:46 AM
TamiyaCowboy is offline
Find More Posts by TamiyaCowboy
TamiyaCowboy's Avatar
Norwich, England
Joined Jan 2010
THANKS
3 axis gyro , on a four channel system
TamiyaCowboy is offline Find More Posts by TamiyaCowboy
Old Feb 15, 2013, 07:46 AM
OiOi is offline
Find More Posts by OiOi
Joined Apr 2009
Lol my GWS props just arrived today from Banggood. At least in my package, I got all the right colors and orientations...
OiOi is offline Find More Posts by OiOi
Old Feb 15, 2013, 08:01 AM
bulesz is offline
Find More Posts by bulesz
bulesz's Avatar
Hungary EU
Joined May 2007
Don't forget to balance them!
bulesz is offline Find More Posts by bulesz
Old Feb 15, 2013, 08:16 AM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Does it look to you that the heavy blade is the one with the #s printed on it?
Mine turned out that way. On one of them I took some fine sandpaper and sanded those raised numbers off. It seemed to make a difference, easier to balance.
Bart...
bartricky is offline Find More Posts by bartricky
Old Feb 15, 2013, 08:30 AM
bulesz is offline
bulesz's Avatar
Hungary EU
Joined May 2007
Bart...
Mines have both, so doesn't matter where the numbers are.
Old Feb 15, 2013, 09:22 AM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Yes. The number side has always been the heavy side for me.
It's consistent enough that I simply cut three pieces of 1cm Kapton tape. Stack them on top of each other and put them right next to the GWS letters.
It balances every time.
Then just trim off the excess the protrude past the blades.
Daryoon is online now Find More Posts by Daryoon
Old Feb 15, 2013, 10:19 AM
mc4fun is offline
Joined Jan 2013
Wow I could not believe how out of balance they are. I trimmed the first one but after seeing how much shorter it made the blade I went to adding tape. I must of took off 3/8 to 1/4 inch (5 to 10mm). And yes the GW5443 side is the heavy side.
Old Feb 16, 2013, 02:58 AM
OiOi is offline
Joined Apr 2009
Wow, I have to say, that I'm really astonished how bad these props are balanced. I've seen many rotors, also a lot of cheap chinese crap, but never some which were consistently that far off balance.
Seems like they have some serious problems in the manufacturing of these...
OK, I've now tested on all 12 props that arrived, which side is the heavier one. And it was always the side with the numbers on it.
I'm wondering if maybe already the cast mold has been produced uneven, so that all rotors have this problem.
I really cannot believe, that just due to production tolerances, such consistent high weight differences can occur. At least a mold is a mold!
Maybe I'm wrong, but seems like there's some real quality problem there.
Old Feb 19, 2013, 04:34 AM
OiOi is offline
Joined Apr 2009
I just got my V949, which was intended to be used as a FPV-gear from Banggood.
As I saw, there were some problems in the beginning with the props being bent.
But now, they have a new package, where this cannot happen so likely anymore.
Additionally they tape the props together, so that they cannot move anymore.
So this is positive news.
Unfortunately it's that cheap tape, where the glue remains, when you take it off, which is really unfortunate (you can see the glue remains on the pic).
they should use a different tape for that.
Additionally, it seems my package got some severe punching during the shipping, and the result is a broken leg...
BTW: In my manual it is indicated, that there will be a new third version V929, which also has a LED on each leg side for night flying.
Edit: Ah, from the description I just realized that they mean the V969,v979,v989,v999. The new ones with all kind os tuff on it (blubble blower, water squirter, missiles, etc..)
Old Feb 19, 2013, 06:54 AM
asanovrus is offline
Find More Posts by asanovrus
asanovrus's Avatar
Ukraine, Crimea, Bakhchysarai
Joined Mar 2012
wow. that leg seems unbreakable to me, it's carbon right? what could cause that? driving over it?
asanovrus is offline Find More Posts by asanovrus
Mini-Review WLtoys V929 Beetle Ladybird Quad Mini-Review FyreSG Mini Multirotors 3824 Jan 10, 2016 09:05 AM
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5149 Oct 29, 2014 02:57 AM
Discussion Woo.. New mini UFO V949 Beetle 4-axis Quadcopter 4CH face into the market Quadcopter MQ80 Multirotor Talk 0 Sep 14, 2012 11:20 PM
