Old Oct 25, 2012, 12:50 PM
WVrailfan is offline
Find More Posts by WVrailfan
WVrailfan's Avatar
United States, WV, St Albans
Joined Jun 2011
Display with nav lights "on" question
I have been invited to display a couple of my planes at a CAP seminar and banquet. I would like to put a battery in one with nav lights for the display.
Will it hurt the receiver or other components to have power to them for extended periods of time?
Jim
WVrailfan is offline Find More Posts by WVrailfan
Old Oct 25, 2012, 01:33 PM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
It all depends. Assuming your lights are run off the radio power circuit, then...
If you're using a seperate radio battery, running the radio without the transmitter may result in erratic, uncontrolled servo movements. The servos may run against the stops and could be damaged. It all depends on what your radio system does when the Rx is on and the Tx is off.
If you going to run off of the motor battery, through a BEC, you can add to the above the potential of the motor starting up unexpectedly. If this is the case, consider removing the prop and/or disconnecting the wires between the ESC and motor.
Why not just temporarily unplug the lights from the radio power buss and use an independent radio batter to power the lights during the display?
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old Oct 25, 2012, 01:36 PM
WVrailfan's Avatar
Joined Jun 2011
The lights are just plugged in to an unused channel on the reciever.
I have a couple of 2 cell batteries I don't use any more, I may just make an adaptor and see if the lights will run off of that for a while.
Jim
Old Oct 25, 2012, 01:57 PM
Darryl Miller is offline
Find More Posts by Darryl Miller
R/C Addict for Life!!
Darryl Miller's Avatar
Sterling/Rock Falls, Illinois, United States
Joined Oct 2001
Your solution will work, just dont use a 7.4 volt 2 cell lipo..........it would be too much. If your lights run off a reciever channel, they are set up for 4.8 volts. Try a one cell lipo, or a couple AA-s first to see if it works.
D
Darryl Miller is offline Find More Posts by Darryl Miller
Old Oct 25, 2012, 05:56 PM
Johnny Five is offline
Find More Posts by Johnny Five
Johnny Five's Avatar
Canada, AB, Fort MacLeod
Joined Aug 2011
You could use a reciever battery pack and unplug everything but the lights. I would be tempted to use another reciever to power the lights and leave the plane reciever alone.
http://www.headsuprc.com/servlet/the...IES/Categories
Johnny Five is offline Find More Posts by Johnny Five
Old Oct 26, 2012, 12:26 AM
MattZC is offline
Find More Posts by MattZC
I just love flying
MattZC's Avatar
Traverse City ,MI
Joined Dec 2005
I've been using a servo-testor to run my lights during my recent build.
Matt
MattZC is offline Find More Posts by MattZC
Question How Can I Hook Up the Included Nav Lights On my Plane? ClevelandBaller Electric Plane Talk 11 Aug 13, 2012 10:49 PM
Discussion MQX with LED Nav Lights Ron_RC Night Flying 0 Apr 10, 2012 03:57 PM
Alert Nav lights at poundland uk ballores Night Flying 0 Feb 23, 2012 12:32 PM
Discussion airfield sky trainer 55 inch with flaps and nav lights connector question?? flysohigh Electric Plane Talk 1 Apr 26, 2011 11:03 PM
Question Xtreme Battery Alarm & Nav Lights modification question? Mactadpole Power Systems 0 Apr 26, 2010 06:19 PM
