United States, NY, Cortland
Joined Sep 2010
Some of my non-horrible ones with my trainer
Kilsyth, Victoria, Australia
Joined Oct 2003
It took me a long time but mainly because I insisted for too long in making bad choices of models. Our problem is generally that those nice shiny boxes tempt us too much and we imagine we can fly anything straight away.
Sorry to ask but what stage are you at in your flying? Do you have an instructor or are you going it alone? If really in the primary stage are you flying on just rudder, elevator, motor or full four channel including ailerons? A good instructor can shorten the learning process and reduce difficulties with aileron. If you are a lone flyer then it is much easier to fly just R.E.M. This is just because the aircraft if properly designed is (or should be) self stable. This means you can concentrate on direction, attitude, throttle setting etc. Nothing wrong with ailerons other than that it is yet one more thing to think about particularly in moments of stress. It has been assumed over recent times that all "trainers" must have ailerons but this is no so. A good basic trainer, especially for the lone flyer, is better if it is of a reasonable size say about 1600mm span. Is nice and stable and in effect can fly hands off if well trimmed at average throttle power. This sort of model only requires steering and can get you used to looking at the attitude of the aeroplane, which direction it is going and which way it is turning, particularly at a distance. Once all of this is second nature the move to ailerons is an easy transition. Once again the aircraft still should be easy to fly but somewhat more neutral in stability so that turns and rolls require input from the flier. Once again I apologise if you already know all this but I thought a reminder might be worthwhile. |
Nigel |
Larry |
Joined Sep 2010
How much 'weight' is on the wheels is a factor, I think there's yet another factor- often if not usually with 'bounce' there will be positive attitude change, if the airspeed is high this will result in the plane climbing upwards without any elevator input.
I have put in 4 flights on my WWI biplane over the past 2 days (weather has been crap), just after some repairs, and one landing was a little off to the side but all were pretty decent (no bou7ncing no groundloops gentle touchdowns) just-off-the-ground pull-pull-pull that elevator until it stalls touchdowns. A big reason for that is I just said the heck with trying to save a messed-up approach and I went around on about 3 of those (4 landings, but 7 approaches). Saving a bad approach is good practice for dead-stick landings, but I grew too accustomed to saving a hideous approach with my trainer, and my bipe just doesn't like that type of treatment. The bipe doesn't really like elevator-for-speed throttle-for-altitude landings, the speed at which the plane will fly that way slow enough for approach is slow enough that the smaller-than-scale ailerons and elevator lose most of their effectiveness. What it likes is a shallow descent with a fair bit of power (but I don't like being that close to the ground for that long), or a steeper descent with a bit more speed but little or no power (almost dead-stick or dead-stick). The steeper descent favors my runway when I'm landing to the south as the north end has an obstruction. |
After nigh on 45yrs at it .. i would like to eliminate landing bounce !!
It's fine all the technical and various details why it happens ... but in real world when a gust of wind blows ... changes direction .... engine gives a blip .... the thousand and 1 things that bedevil us occur ... we bounce ! I don't reckon anyone ever stops doing it now and again !! Nigel |
I flew a scale Nieuport 28 years ago ... what a beautiful model - but OH what a dog to take-off and land ! Bring her in slow and nice descent ... BOUNCE ! Bring her in with throttle to grease in ..... she'd land and then ground-loop taking the wing-tips with her ... Nigel |
Joined Sep 2010
| Thread Tools | |
| Discussion How do you eliminate pull to gear in knife edge flight | kenh3497 | Competition Aerobatics | 8 | Jun 15, 2013 09:38 PM |
| For Sale Landing Gear for and nice wheels for "Eliminator" | Kenneth Henius | Aircraft - General - Miscellaneous (FS/W) | 0 | Jun 30, 2012 12:21 PM |
| For Sale Landing Gear for and nice wheels for "Eliminator" | Kenneth Henius | Aircraft - Electric - Jets (FS/W) | 1 | Apr 08, 2012 09:02 AM |
| Help! My a-4 bounces on landing | zaskarkid | Foamy EDFs | 2 | Aug 14, 2008 11:54 PM |
| Discussion Bouncing Landing Wheel | asm_ | Foamies (Kits) | 1 | Oct 05, 2006 06:08 PM |
