This thread is privately moderated by gkamysz, who may elect to delete unwanted replies.
Old Oct 25, 2012, 11:51 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
A tiny diesel engine AE 0.1CC
I took this video of an AE 0.1CC diesel last year. I thought I get around to building an airplane for it this year, but it still hasn't happened.
AE 0.1CC Diesel Model Engine Micro (4 min 57 sec)
gkamysz is offline Find More Posts by gkamysz
Old Oct 25, 2012, 03:19 PM
tobermei is offline
Find More Posts by tobermei
Mt Tamborine, Queensland, Australia
Joined May 2008
Really enjoyed hearing that come to life!
tobermei is offline Find More Posts by tobermei
Old Oct 25, 2012, 07:22 PM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
Ohhhh, I want that engine.
I love the spring starter around the prop.
Why is it common language in modelling to call these "diesel" engines?
I know they are compression ignition, sure.
But isn't there something else that is more accurate to define them? Its not running on any diesel right?
Sad Sack is offline Find More Posts by Sad Sack
Old Oct 25, 2012, 08:16 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
They have been called diesel since the dark ages. The fuel is made up of oil, kerosene and ether. In the video it was the second time I actually ran it, so it starts easier than that.
Greg
Old Oct 26, 2012, 04:50 PM
tobermei is offline
Joined May 2008
http://en.wikipedia.org/wiki/Diesel_engine
Diesel engines are engines that use the heat of compression for ignition. So, these are clearly such motors, the fuel is different to what you may know as "diesel" fuel.
The glow motors we also use in model planes are also technically diesel motors but aren't commonly called that. The example in this video uses an adjustment at the top of the head to increase compression till you get ignition.
Hope that makes sense.
Old Oct 27, 2012, 10:50 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
If we get technical, both model diesel and glwo engines are HCCI type.
Greg
Old Nov 22, 2012, 07:46 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
That would be perfect for it:
http://www.rcgroups.com/forums/showthread.php?t=1559483
Or one of the "Frog junior/senior serie"
http://www.houseoffrog.co.uk/senior_plans.htm
http://www.houseoffrog.co.uk/junior_plans.htm
coriolan is offline Find More Posts by coriolan
Old Nov 22, 2012, 08:29 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
That Widgeon is right up my alley. I had actually decided on a plan bashed Vee-Tween.
Greg
Old Mar 08, 2013, 10:25 AM
RyanNX211 is offline
Find More Posts by RyanNX211
Thermals, Tom
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
That radially mounted engine might be a viable alternative to those waiting for their PAL Imps.
RyanNX211 is offline Find More Posts by RyanNX211
Old Jul 02, 2013, 09:54 AM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Looks good Greg. It's even smaller than the Cox .010.
I made a 17" Nut Ball that flies at 3.5 oz. (electric).
The Cox puts out about 3 oz thrust. Maybe the AE with a slightly larger prop might generate similar thrust.
John
JohnAV8R is offline Find More Posts by JohnAV8R
Sold Mills 1.3cc and Litmo 0.6cc Diesels Engines High & Mighty Aircraft - Fuel - Engines and Accessories (FS/W) 1 Sep 29, 2012 02:40 PM
Discussion AE .2cc diesel videos nitroairplane Vintage & Old-Timer Designs 2 Apr 29, 2012 04:19 PM
Sold AE 1cc Diesel - Last One SRM Aircraft - Fuel - Engines and Accessories (FS/W) 3 Feb 16, 2011 05:34 AM
Sold AE 1cc Diesel SRM Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 25, 2011 07:11 PM
Wanted Wanted: tiny Diesel engines! misfitsailor Aircraft - Fuel - Engines and Accessories (FS/W) 3 Sep 19, 2007 10:42 AM
