Ultimate´s Airtronics OLY ll e-conversion
Hi buddies. Just to share. Many years ago, when I was almost a kid, a gentle US military modeller gave me a RCM review and my friend Carmelo and me saw this wonderful sailplane. We together built this O2 just from the little plans on the review, swapping dimensions and so...During some years, we shared the glider and flew with a Hobby Shack Cirrus 2 channels, latter we used another 6 ch. Cirrus and Futaba. We enjoyed a lot with this glider and flew it on slope soaring near home over the ocean coast dunes, high star catapult launches, and ocassionals electric winches on duration and the new LOL F3B competitions on Seville, ( Spain ), during last seventies and new eigthies,.... ( a long time ago... on a galaxy... far .... far away.... ). Really this Reanud´s sailplane fall to me in love with soaring. We did on that time some others O2, now from RCM plans and kits. Now, almost 35 years later I just some days ago started to build another Olimpic from scratch and plan to do a E conversión....., let´s see.... My idea is to build again that classics sailplanes that I flew on my youth and enjoyed so much. On that time I flew an Airtronics Aquila and O2, a BOT and a Mirage. Aquila it is still flying and a new E-conversion BOT was finished last month, so now it is the time for the old O2. After that will be Mirage´s time...., really I like these oldies but wonderful sailplanes.... but Olimpic II was my very first ..... and I loved so much....
After tail surfaces were framed and hinged added I traced some patterns from cardboard of the tips contours and shaped to the right curves. Now looks cooler.Tail group needs yet some light holes on the elevators as Rob did, reinforce the joiner dowel and horns area with ciano and fine glass cloth, V shaping the hinge area and final sanding, but I will do these steps to more later when all airframe will be done. So next step we will go to work on the fuse sides... Manolo. |
Hi Davis, welcome to the blog. My Oly is built by plans from the original Airtronics kit, and plan to stay very close to it, even fighting to change some things, but I want to keep the most from the original good Renaud´s ideas, without of course the e-conversion, some more streamlined nose area and simulated built canopy, a little more rounded fuse corners, individual servo operated spoilers, and a bolt on wing.Anyway I have read a lot of good things about Skybench kits and the more modern versions and the rest of the production of that fine company. So please feel free to posting and share your ideas and opinion. ![]() Best regards. Manolo. |
Well buddies, after the tail group were framed, lets go to the fuse by now and built the fuse sides only....![]() Just started to build the fuse sides, gluing the ply nose cone and balsa tail post, add the inside balsa reinforcement and interiors stringers. I just changed the rear center pine reinforcement spar by hard balsa to compensate the weigh cause I added also some 1/8 sq. balsa spars on the bottom and upper line of the fuse to let a more rounded corners. By the same idea, I just changed the 1/4 triangle front bottom balsa spars for anothers one of 8mm. to lend a more agressive sanding on this area and let flow the boxy fuse box contour to the roundness of the prop spinner more latter... ![]() After that we will set aside the fuse sides apart and start on the wing building.... Manolo. |
| Thread Tools | |
| Sold Carl Goldberg Ultimate w/ OS 1.20 Surpass-II | clandestoy | Aircraft - Fuel - Airplanes (FS/W) | 1 | Nov 26, 2012 06:43 AM |
| Sold Carl Goldberg Ultimate w/ OS 1.20 Surpass-II | clandestoy | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jul 23, 2012 09:29 AM |
| Wanted OLY II or OLY II S | clayrb | Aircraft - Sailplanes (FS/W) | 11 | Jun 25, 2012 08:54 PM |
| Discussion question about E-OSD II and a G-OSD II | smitty919 | Video Piloting (FPV/RPV) | 3 | May 30, 2012 05:02 AM |
| Discussion E-S Lama II Vs E-S Honey Bee | ggregory | Coaxial Helicopters | 6 | Apr 07, 2006 04:06 PM |
