Old Nov 30, 2012, 04:16 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
Well 6 1/2 flights deep and my motor and/or ESC is done. As I said when I first got it the ESC got pretty warm just setting up the control surfaces. Well today I went out with 4 batteries. The sun was setting, no wind, 58F in central Ohio....perfect. Took off and got about 25' high and the motor just stopped. I was able to save it and land perfectly with zero damage. Checked the throttle and the motor was cogging badly. Got my temp gauge and the ESC was 155F and motor 167F after a 20sec flight! Horizon is sending me a new motor and ESC, but its grounded for a week or better.
kuczy is offline Find More Posts by kuczy
Old Nov 30, 2012, 05:31 PM
TMAC4123 is offline
Find More Posts by TMAC4123
God is Good
TMAC4123's Avatar
United States, MI, Grand Rapids
Joined Jan 2011
What do you think is causing this? Too small of an esc?
TMAC4123 is offline Find More Posts by TMAC4123
Old Nov 30, 2012, 06:02 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
Honestly I'm not sure. The ESC is getting too warm just from plugging in the battery, but I had a Park280 in my Grasshopper and it did the same cogging before it smoked. So my opinion is 2 e-flite motors of the same size run the way they suggest and both have failed.....I think it's a problem with the motor itself since the Grasshopper was using a Dualsky ESC.
Old Nov 30, 2012, 08:00 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
So I found on my motor that the stator was no longer glued in place causing it to bounce back and forth which probably caused to motor to fail. I tried a 18 amp I had since it had the same connectors and it still cogs. I'll have to check the wires on the windings and see if they may have broken with all the bouncing.
Old Nov 30, 2012, 08:05 PM
slo-fly is offline
Find More Posts by slo-fly
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
I changed the esc to 12 amp and have a park 340 coming on Monday or Tuesday. I have a apc 7x4E on my park 280 pulling 140 watts and 12.2 amps static with a thunder power 325mah 65c 3s. So far the motor has survived, I'll give it a good go this weekend and see if it gets cooked before I swap motors.
slo-fly is offline Find More Posts by slo-fly
Old Nov 30, 2012, 08:26 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
So I just tried another ESC, 18amp Parkzone had the same connectors on it, motor still cogs and the wires are fine. Also tried another motor with the stock ESC and it runs it fine with not cogging. So it's the motor. The ESC still gets warm, but my IR temp. guage shows 114F which is perfectly within acceptable limits. I'm thinking of getting a Park300 for it since this is the second 280 that has crapped out on me in the last 2 months....
here's where mine needed glue:
Old Dec 02, 2012, 10:16 AM
TMAC4123 is offline
God is Good
TMAC4123's Avatar
Joined Jan 2011
Park 300 will be perfect
Old Dec 02, 2012, 11:14 AM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I just tried to mount the Park 300 and was unsuccessful. You'll need some sort of custom mount to get it on there and you'll also need to reverse the Park 300 shaft in order to use the collet styple prop adapter.
My stock motor started cogging this morning. I have to call HH.
turnerm is offline Find More Posts by turnerm
Old Dec 02, 2012, 11:37 AM
TMAC4123 is offline
God is Good
TMAC4123's Avatar
Joined Jan 2011
Have you ever thought about looking at the motorfly motors? They have good small motors that are very efficient
Old Dec 02, 2012, 11:42 AM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I have! But I think the issue that you're going to run into with ANY motor that you pick is that it appears they have used a proprietary mount on these stock 280 motors. So unless you can get that thing off the Park 280 (I couldn't) then you're not going to be able to mount another motor unless you fab something up.
Old Dec 02, 2012, 11:55 AM
TMAC4123 is offline
God is Good
TMAC4123's Avatar
Joined Jan 2011
Is it a normal x-mount that the motors is connected through?
Old Dec 02, 2012, 12:03 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
Looks like it from the pictures. I have not had mine out, but sure looks like you should be able to take the set screws out and get the x mount off the motor. But I could be completely out in left field on this one.
bobly is offline Find More Posts by bobly
Old Dec 02, 2012, 12:11 PM
slo-fly is offline
Scottsdale Arizona
Joined Dec 2009
The hacker a10 fits in the edge with the included x mount. I should be getting the park 340 in a day or two, hopefully that fits without much issue.
Old Dec 02, 2012, 12:20 PM
turnerm is offline
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
I can't seem to get the mount off. It appears to be one with the motor casing.
Old Dec 02, 2012, 12:41 PM
bradharvy is offline
Find More Posts by bradharvy
bradharvy's Avatar
United States, MO, Raymore
Joined Nov 2011
In regards to the esc warming up just setting.. Is everyone binding with throttle trim all the way down? I missed it till I read over the second time. Mine seems ok..
My thoughts are in line with other posts regaurding quality. Not liking the cowling design. Kinda loose fitting. But the plane flies very smooth to me. I flew it in ten plus winds, and it wasn't the best flying but did fly. No good tricks to come out of it from me at ten mph or more. It was fun though, made it feel real floaty just sitting in the wind not really moving! All in all a great buy. I to am waiting for a 7X3.5 gws. Broke the flimsy stock one. Too bad they make a person work so hard to modify it. Look foward to hear motor reviews!
Ohhhh, does anyone else notice that when ya spin the prop by hand, you see the backplate wobble as if the shaft isn't true? Mine did this off the bat and I spent about an hour trying to align it,Adapter, but didn't get much better. Nothing looks bent. It causes the heavier props that I have tried to shake the heck out of the plane, even after balancing the props. HH said both the ones he grabbed while speaking to me did the same thing. I've heard the, (it's normal) story b4! Anyone else notice a bit a wobble?
bradharvy is offline Find More Posts by bradharvy
New Product E-Flite P-40 Warhawk 300 ARF - 25 inch WS kydawg1 Electric Warbirds 1972 May 12, 2016 03:18 PM
Sold E-flite Delta-V 15 69mm unit w/E-flite 15 BL 3200kv and E-flite 60A Pro micromantis Aircraft - Electric - Power Systems (FS/W) 0 Sep 11, 2012 05:01 PM
Discussion F-22 Raptor 24" WS kc2pxp Foamies (Scratchbuilt) 10 Aug 08, 2012 07:21 AM
Sold E-flite 22-Amp BL ESC Combo with the E-flite park 450 pnp 890kv outrunner. hobby-plane-rc Aircraft - Electric - Power Systems (FS/W) 2 May 08, 2008 10:13 PM
Sold E-Flite 450 w/ E-Flite 22 amp ESC Bob Shultz Aircraft - Electric - Power Systems (FS/W) 3 Dec 08, 2007 06:53 PM
