Old Dec 03, 2012, 06:31 AM
ing.enzo is offline
Find More Posts by ing.enzo
Joined Nov 2011
Originally Posted by doddlepots View Post
Do you have a trade name for the vynil you used? It looks like what I need for my "Magic" re-build.
Cheers,
Christopher
Dear Christopher , I send to you a pm
best regards
enzo
UPDATE
Fuselage painted with bi-component white. Rudder and Elevator covered with vynil. Now I'm ready for electronic installation. Picture will follow.
ing.enzo is offline Find More Posts by ing.enzo
Old Dec 26, 2012, 01:50 PM
doddlepots is offline
Find More Posts by doddlepots
Joined Feb 2006
News???
So, what happened with the Alpina, Enzo?
We are all waiting with baited breath?
Has it flown yet?
Happy Christmas, in any event
C
doddlepots is offline Find More Posts by doddlepots
Old Jan 12, 2013, 02:10 PM
Aussie John is offline
Find More Posts by Aussie John
Joined Jan 2004
Hi Folks
You might be interested in my Alpina M journey.
I bought a used AM from an estate for a good price BUT it had a few problems.
I fitted new servos and had some flights. I could not keep the wings locked in with the AM clamp.
After asking many questions I could not discover how the system worked nor could I see how it worked The problem was during launch the wings bent up and slid out when they relaxed on the glide the spoilers were slightly open.
I had the correct clamp. I later discovered that the previous owner had replaced the steel blade boxes and did not drill the front and back holes to enable the clamp to lock the blades.
So I made a clamp arrangement in the ballast tube boxes and a serious spring to hold the wings closed.
The covering was wrinkled An no amount of heat would fix it so I stripped all the covering and re painted the wings and tail.
That is when I discovered the wings had been broken at the inner end of the ailerons.
They had a poor repair. Easy fixed? No! The previous owner bogged the wing up and glued in the servos and wiring.
Removed wiring and servos with much dremil grinding etc. While doing this surgery one wing fell over in the work shop and stripped the new gears in the servo.
I figured the old stripped gears may have caused a crash hence the wing repair
New JR servos and a mount so that the servos can be removed. I do not like servos glued in. That is just me I am old fashioned and all parts should be able to be maintained.
During all this I fitted a home made aerotow unit in the nose.
During the first half of 2012 I had my first flights with the "new" AM at an aerotow rally.
Actually the first flight was with a new radio with unknown throws and my first aero tow. I had a good mentor.
I had 12 launches that day. What a trhrill. As I was getting to know the model, it had a strange quirk. Half spoiler produced a roll in one direction.
I discovered one spoiler was opening further than the other.
I had adjusted the spoiler mechanics to lock up and down but never thought to check the throw at half stick.
There was slop in the linkage in the wing. The old system was one aileron servo in the fuse.
With the new radio ( my first computer radio. I have been using my old KRAFT in wooden RES models.) I knew I could fit a servo on each spoiler.
Hacked up the wing to fit a servo. Glued in a box for the servos and a wooden tube for the push rod to the spoiler. Filled the cavitys with foam and covered the patch with glass as a precaution.
During the repair, the lift pin on one aileron broke. That was a low point. But I found a place in the US that sells look-a-like spoilers. A set arrived and I am quite pleased with units.
A new ply mount was fitted to the wing glassed and painted.
This forum had a discussion re the failour of the elevator horn. Will I or wont I dig in and look? I decided to dig. Glad I did. Made a new horn from novastien.
A new brass bush was made for the fin to pivot the elevator.
Just in case novastien is unknown by that name in the US a description follows.
It is a sheet stuff that looks like compressed fabric in a resin. It is an electrical product, nice to cut, drill, tap etc. It has a horrible smell when cut on a bandsaw. I used 1/16 with two extra pieces either side of the pivot.
Early Feb this year we have a local aero tow.
I am almost very happy with the final product.
I would like to aquire some 3mm spring steel for the elevator pivot rod. That is the size used by the German Kit maker.
7/64 K&S is just a bit loose.
If any one knows where this can be obtained in EUROPE I would be grateful.
Hope my story has been intersting.
Cheers John Quigley Down Under
Aussie John is offline Find More Posts by Aussie John
Old Jan 12, 2013, 03:15 PM
Phil.Taylor is offline
Find More Posts by Phil.Taylor
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
John - great story !
There's probabaly quite a few hacked/bodged Alpinas out there in need of TLC.
for 3mm steel wire/rod - try "Gliders Distribution"
http://www.gliders.uk.com/products.asp?dept=58
Always very helpful - I got some 2.5mm from them a while ago. Tell them what its for & ask them to cut it down into smaller pieces for shipping
Phil.
Phil.Taylor is offline Find More Posts by Phil.Taylor
Old Jan 12, 2013, 03:42 PM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Good one, John !
Chris
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Jan 25, 2013, 05:03 AM
ing.enzo is offline
Joined Nov 2011
C
Hello everybody..and sorry for delay.
A/C is almost ready for test flight..just waiting for snow going away from my favourite slope
I will keep you posted with final pictures and with feedback about flights
Ciao!
Careful! Alpina Magic in Ireland Woodstock 1 Slope 57 Aug 01, 2012 01:42 PM
Discussion Multiplex Alpina Magic Hellrider Scale Sailplanes 15 Jun 11, 2009 03:09 PM
Multiplex Alpina Magic pike Sailplane Talk 2 Jul 07, 2005 02:20 PM
F/S new in box Alpina Magic Bill L Aircraft - Sailplanes (FS/W) 1 Jan 10, 2004 06:48 PM
