Old Oct 31, 2012, 06:41 AM
John Cole is offline
Find More Posts by John Cole
John Cole's Avatar
United States, CA, Santa Rosa
Joined Jun 2001
Enzo, all;
I'm currently working on my Alpina again, big delay due to move to N. Calif. Just wondering what the difference is in the 'magic' and the first version of Alpina is. Mine is the early model with blade joiners and Ritz 2 foil.
In regards to adding flaps to this airfoil, I believe the Ritz 2 will not respond efficiently to conventional flap arrangement. Probably best to leave this idea behind (IMO).
John Cole is offline Find More Posts by John Cole
Old Oct 31, 2012, 08:00 AM
Phil.Taylor is offline
Find More Posts by Phil.Taylor
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
Originally Posted by John Cole View Post
Enzo, all;
Magic has wingtip extensions & the fuselage / fin is a slightly different shape to the original Alpina - otherwise, pretty much the same thing!
Phil.
Phil.Taylor is offline Find More Posts by Phil.Taylor
Old Oct 31, 2012, 08:06 AM
ing.enzo is offline
Find More Posts by ing.enzo
Joined Nov 2011
Enzo, all;
The magic also has Ritz Mod airfoil and balde joiners... I don't know which can be the differences..sorry.
I agree with you about flaps. Considering also that I will not glass the wings, I will elave them as is.
ing.enzo is offline Find More Posts by ing.enzo
Old Oct 31, 2012, 08:09 AM
ing.enzo is offline
Joined Nov 2011
Originally Posted by Phil.Taylor View Post
Magic has wingtip extensions .......Phil.
and what about this wingtips extension: are they useful? I'm wondering to three different options:
1- leave them in box and never use them: due the fact I believe they will not change anything ( or at least in a evident way)
2 - install them definitively ( resin them on the wings)
3- follow instruction and keep them removable ( useful for car transportation)
we will see
Old Oct 31, 2012, 09:11 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
wing extentions
My take on this subject is as that the tips transform the Alpina from a "sports" glider into a thermal glider. The tips lower the wing loading of the plane to a surprising degree considering how small they look. Once they are on, however, you can forget about performing any aerobatics other than loops: rolls become particularly hard.
So, the choice is down to the conditions you normally, or want to, fly in. I have another thermal soarer with electric assist that I use when consitions are very light, so I rarely use the Alpina tips. Before I had that other plane, I used them quite a lot....
Hth.
Chris
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Oct 31, 2012, 09:37 AM
Gary Binnie is offline
Find More Posts by Gary Binnie
Late for work again!
Gary Binnie's Avatar
Northampton, England
Joined May 2004
I always fly with the tips on with my MPX DG600, they're not particularly big. They are fitted with turbulators as suggested in the instructions.
Looks better with them on!!
Gary Binnie is offline Find More Posts by Gary Binnie
Old Oct 31, 2012, 12:10 PM
John Cole's Avatar
Joined Jun 2001
Thanks for the information about Alpina differences. I too am planning to cover mine with film. The tip extensions are neat! Gives me some ideas since I've not started on my wings yet.
I was intending to rig wing controls per plan, servos in fuselage, but now considering in-wing servos. Newer technology makes sense...
John
Old Oct 31, 2012, 12:17 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Thanks for the information about Alpina differences. I too am planning to cover mine with film. The tip extensions are neat! Gives me some ideas since I've not started on them yet.
John
I'm quite sure that if small servos were commonly available when the Alpina was new, Multiplex wouldn't have gone near all that bowden-cable based malarkey!
Every time you just slide the wings on and the plugs automatically connect (?!) you'll be glad you aren't kneeling down peering into the fuz, waving a screwdriver about trying to connecting ailerons AND airbrakes....
Do post pics
Shedofdread is offline Find More Posts by Shedofdread
Old Nov 04, 2012, 11:06 AM
ing.enzo is offline
Joined Nov 2011
HI everybody..build is going on.
Now I was at the step to prepare servo location in the wings. I tried to make some holes to find out where is the bowden of the spolier..no way to find it out.
I want to stay at least 20cm far from wing root, in order not to make this zone too weak. But at this point I`m not finding the bowden...strange routing ( spoiler is in the middle of the wing, pull rod goes out at the leading edge: I tried to follow a straight line and a normal curved one unsuccesfully )
Anybody has an idea of where it is located exactly ( before I have to cut the wing into two pieces )
thank you!
Old Nov 04, 2012, 11:22 AM
ing.enzo is offline
Joined Nov 2011
In the mean time I share with you some pics of what I`m doing:
- Aileron cut, sand.ready to be covered ( waiting to finish servo modification in the wings)
- Elevator and rudder sand and ready to be covered, the installed
- Wing tips ready to be sand , brass tube joiner installed and glued
- Bellcrank homemade ( as per your suggestion)
to be continued
Old Nov 05, 2012, 10:02 AM
ing.enzo is offline
Joined Nov 2011
Originally Posted by ing.enzo View Post
H...
thank you!
Found it: 22.5 cm from wing root and 5 cm from leading edge on RH wing.
In the LH one the routing is different: is a couple of cm more far from the LE.
In case that may be useful for somebody else
Bye
enzo
Old Nov 05, 2012, 12:40 PM
ing.enzo is offline
Joined Nov 2011
New pics
Some progress:
- wing extension finished
- Anti compression rod (rear one intalled in the fuselage)
Now I`m wondering about wing joiner blades in the fuselage: I would like to have wings levelled as good as possible ..but it is not so much clear to me how to proceed..
Old Nov 05, 2012, 02:08 PM
John Cole's Avatar
Joined Jun 2001
Enzo, it looks great! The tip extensions are larger than I had imagined. I believe dihedral is variable with the blade system. Set desired angle, then unit is bonded into fuselage. Most importantly, align blade box with stabilizer.
John
Old Nov 06, 2012, 10:01 AM
doddlepots is offline
Find More Posts by doddlepots
Joined Feb 2006
Some progress:
The Multiplex instructions, from the manual, are quite clear on how to get the wings lined up. REally, it is quite simple. If you have any problems, let me know and I will attempt to find my manual and scan the necessary bits and forward.
Good luck. It will be worth it!
Cheers,
Christopher
doddlepots is offline Find More Posts by doddlepots
Old Nov 06, 2012, 10:24 AM
Phil.T-tailer
Devon, UK
Joined Jun 2003
Cheers,
Christopher
Alpina Magic instruction manual still available to download from the Multiplex website - here:
http://www.multiplex-rc.de/en/servic...push&docID=580
Phil.
Careful! Alpina Magic in Ireland Woodstock 1 Slope 57 Aug 01, 2012 02:42 PM
Discussion Multiplex Alpina Magic Hellrider Scale Sailplanes 15 Jun 11, 2009 04:09 PM
Multiplex Alpina Magic pike Sailplane Talk 2 Jul 07, 2005 03:20 PM
F/S new in box Alpina Magic Bill L Aircraft - Sailplanes (FS/W) 1 Jan 10, 2004 07:48 PM
