Old Nov 24, 2012, 08:32 PM
accel8or is offline
Find More Posts by accel8or
Mark Beltran
accel8or's Avatar
United States, CA, Westminster
Joined Dec 2010
How are you determining the c.g....upright or inverted? Or does it matter?
accel8or is offline Find More Posts by accel8or
Old Nov 24, 2012, 08:53 PM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
Originally Posted by AeroRecon View Post
Just picked one up. Had not even heard of it until yesterday. Time for more batteries. Wonder if it would tow an ASK-21?
No problem with this kind of power. :-)
Airman74 is offline Find More Posts by Airman74
Old Nov 24, 2012, 08:56 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Been experimenting with moving CG back,, my 48g battery now about 1/2 in back from front edge of battery compartment,, CG back about 46mm flys much better. Anybody here experiment with differential??? I did on mine,, with 27% negative differential rolls seem a little more axial
Old Nov 24, 2012, 09:03 PM
RyPlane is offline
Find More Posts by RyPlane
United States, MN, Clearwater
Joined Jul 2012
Just be carefull that you don't rip the wings off the ASK
RyPlane is offline Find More Posts by RyPlane
Old Nov 24, 2012, 09:06 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Maybe ill try aero towing my ASK with this edge,, might be fun. :-)
Old Nov 24, 2012, 09:14 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Just got back from a few flights this evening,,,,, MAN!!!! This thing flys REALLY AWSOME at slow speeds. So radar clocked it with the GWS 7x3.5 prop,, got 44 mph , with stock prop I got 40-42mph,, my Sbach 3d on 2s was 42 mph, on 3s it was 47mph
Old Nov 24, 2012, 09:36 PM
ForsheeMS is offline
Find More Posts by ForsheeMS
ForsheeMS's Avatar
United States, NC, Lexington
Joined Jul 2012
Finally finished up the Edge travel box. Took way longer than I expected but should be well worth it to avoid dinging her up going to and from flying. Started out with a 30 x 30 x 18 box and trimmed it down a little. Then added the foam which took forever! Not something I would want to do again.
ForsheeMS is offline Find More Posts by ForsheeMS
Old Nov 24, 2012, 09:46 PM
FlyWW1 is offline
Find More Posts by FlyWW1
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
Great job!!! Now fix your prop and you'll be all set
FlyWW1 is offline Find More Posts by FlyWW1
Old Nov 24, 2012, 09:51 PM
ForsheeMS's Avatar
Joined Jul 2012
Thanks! I picked up the GWS 7x3.5 when I got the plane. Now that the box is done its time to get the plane ready. Still waiting on the batteries for it so I have a little time.
Old Nov 24, 2012, 10:12 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
Great job on that box
brushless55 is offline Find More Posts by brushless55
Old Nov 24, 2012, 11:40 PM
Tomdomification is offline
Find More Posts by Tomdomification
Tomdomification's Avatar
Joined Sep 2011
Originally Posted by bobly View Post
The only thing that I have found easier on the sbach 3d vs the edge is knife edge . But a little practice and mix cured that. I suppose I could add that the as3x maybe makes it a bit easier to keep the nose on point in rolls, but the Edge does not have problems there anyway. The Sbach had been my most used plane since the first version came out, but afraid it's lost its place now. Edit: just to add - there is really no comparing the way the two fly - they are completely different breeds of animal. The edge does not fly like a um plane. It flies much more like bigger balsa planes. It's light on the wings and will float around compared to the sbach and will even glide. The sbach stalls like a brick if you get it too slow, the Edge stalls like a feather if you get it too slow.
Thanks for your answer.
I thought something like this. I do understand, just from videos, that they are very different planes. I was just wondering because I've ordered the Sbach and I was wondering if it will be worth upgrading to the Edge. The Sbach will be my first aerobatic plane which is why I was asking about how easy they are to fly :-)
Tom
Tomdomification is offline Find More Posts by Tomdomification
Old Nov 25, 2012, 12:39 AM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Maiden flight
One flight so far,will dial it in more when i have time to fly again. A little windy out but it handled the wind surprisingly well for a 26'' span plane.
E-Flite QQ Edge 540 Maiden (5 min 49 sec)
Get Real is offline Find More Posts by Get Real
Old Nov 25, 2012, 01:23 AM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
I'll ask again since I haven't had time to rip through the pages. Is it easy to change the prop to 7X3.5 HD? Can the spinner fit? I haven't flown it yet and have 3 stock props and 3 HD props on the way. Thanks.
J
jabsten is offline Find More Posts by jabsten
Old Nov 25, 2012, 06:32 AM
mygeneration is offline
Find More Posts by mygeneration
mygeneration's Avatar
United Kingdom
Joined May 2012
J
Pretty sure you have to sand the prop and or swap the prop nut over to make the gws 7x3.5 fit securely. You need to trim the spinner slightly too.
I've got 5 gws props coming (only available in sets of 5 on ebay) and still waiting for the 540qq to be released in the uk
Cheers
mygeneration is offline Find More Posts by mygeneration
Old Nov 25, 2012, 07:26 AM
AeroMaestro is offline
Find More Posts by AeroMaestro
Smasher of foam
AeroMaestro's Avatar
United States, OH, Stow
Joined Sep 2012
http://www.youtube.com/watch?v=6-NLR5DQlWY&feature=plcp
Thanks very much for this video. I think you fly very much the same way I do, so this was perfect. I loved it when you chased the crow out of your fly zone, too. I've got a few hawks I like to chase but they couldn't care less about my tiny little polecat. Maybe the edge would ruffle some feathers.
AeroMaestro is offline Find More Posts by AeroMaestro
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1176 Mar 18, 2016 07:37 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 07:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 08:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 06:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 02:22 AM
