Scottsdale Arizona
Joined Dec 2009
I used a 2mm collet for apc props. It did weigh 5.4g though and apc 7x4E is 8.4g. If anybody has a problem with prop adapters flying off you need to try a dab of blue loctite. I had a 3mm collet that liked to fly off, a dab of loctite cured it, I had the prop fly off once after that but the collet stayed attached to motor shaft, just pulled the shaft right out of the motor with it.
More flights today, finally got some flat spins out of it, blenders and some really fast rollers. Way too much aileron throw. On mine, the aileron pushrods were in the outside holes of the servo arm and I had to cut max throw down to 75% and it was still way too high roll rate. Once I got home I removed the pushrods and put them in the inside holes of the aileron servos.
Also, this thing acts like it is really nose heavy a lot. Took max elevator throw (150% on the DX8) to get enough to flatten the spins. And that was with the battery at the very back of the battery box area. Next up- add some weight to the tail. Once I get everything worked out I think its going to be wonderful. Its going to take a while to zero in on the mixes and trim,but I can see it will be worth it. It does land very well without a lot of work, every landing was smooth and slow. I didn't know what to expect, but now I'm liking it a lot! |
finished
Hi all..
finished my Edge >now ready to fly and will try maiden asap (tomorrow) - First of all, many thanks to user slow-fly for his postings concerning props here ![]() - I modified a lot of things at my Edge, also checked all screws and figured out one motor mount srew was overdrilled .First I had big trouble to loose the prop nut while motor was turning around with it . I re-glued my motor mount too, was bad glued and I used Pattex Extreme Repair for it.Also one lip at my motor hatch (cowling) was not glued fix--I use a little tape 'tesa" here. Wires from ESC are fix in better position on left side in the battery compartment. Prop and spinner are balanced- little tape on one blade makes the plane quiet All linkage/rods are adjusted. - Unfortunatelly,mods are done, my Edge has some "cosmetic damages" more -the foam quality is a mess and I hope HH learn from that, also their QC isn't good enough here.Now....I have to fly and hope all negative points will erase after I had the "Edge feeling" in the air ![]() I have only SLS 3S/500mAh 30C (52g) but want to have GensAce 460 next, prop change to GWS 7x 3,5 HD and the pilot has to go out (payload). |
Guess I'll have to run around the house with it making airplane noises for now.
Joined Sep 2010
| Thread Tools | |
| New Product E-flite 300 A6M5 Zero BNF Basic | Afraidtoregister | Electric Warbirds | 619 | May 03, 2013 01:53 PM |
| Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS | peterswolf | Aircraft - Electric - Micro & Indoor Airplanes | 4 | Sep 14, 2012 07:43 PM |
| For Sale E-Flite MSR X BNF Basic edition | daign | Aircraft - Electric - Helis (FS/W) | 0 | Jun 01, 2012 08:59 PM |
| Sold Edge 540 3D ARF by E-Flite | freirem | Aircraft - Electric - Airplanes (FS/W) | 2 | Feb 28, 2012 06:38 PM |
| Discussion A6M5 Zero 300 BNF Basic by E-flite | BlazingStar | Micro RTF | 2 | Feb 03, 2012 02:22 AM |
