Old Nov 19, 2012, 09:07 PM
slo-fly is offline
Find More Posts by slo-fly
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
The apc 7x4E looks to be the best prop upgrade on 3s. It pulls 133 watts @ 11.7 amps, stock is 112 watts @ 9.9 amps. The 7x3.8 slow fly pulls 155 @ 13.9 amps. These tests were done static on a full battery, I'd say the 7x4E is pushing the limits but still safe with a little throttle management on a stock edge.
slo-fly is offline Find More Posts by slo-fly
Old Nov 19, 2012, 09:13 PM
BigEast is offline
Find More Posts by BigEast
Enjoying life through flight
Joined Mar 2012
So..... Just got the Edge. Have been having some troubles, especially with removing the aileron servo leads from the y-harness. After I finally separated them, the fuselage cracked from the recoil of separating the leads. Then after my first flight, a light landing in grass resulted in cracked/bent landing gear. Lastly, the manual doesn't give recommended differential!mixing. It says to go to the e-flite website for advanced settings but nothing is there. There aren't any program files for the Dx7/8/18 either. Someone please persuade me to keep this plane!
BigEast is offline Find More Posts by BigEast
Old Nov 19, 2012, 09:22 PM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
This what MikeRX on Eflite zero thread said about the 340 motor
With a 460 mah 3s and 7x4" prop it pulls about 13amps at 130 watts static.
Now it has around 20 oz of thrust to pull the same 8.9 oz of weight!
(Stock is around 9oz thrust on 2s, and 14 on 3s)
Airman74 is offline Find More Posts by Airman74
Old Nov 19, 2012, 09:24 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Originally Posted by Fish99 View Post
Think I am all in on this one ... though I will definately blame you when I am explaining it to my wife Jerry!
Marlin
That's OK,,, just say Jerry MADE me do it. :-)
Old Nov 19, 2012, 09:29 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Yes those very small servo wires ARE a pain!! And the plugs take a bit of patience and some tweezers??? But the bent landing gear in grass??? I've accidentally landed mine in grass once with no issues,,, can't you just bend it back??? I think once you get past these issues,, I think you'll find it to be a GREAT flying plane
Old Nov 19, 2012, 09:33 PM
FlyWW1 is offline
Find More Posts by FlyWW1
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
Does anyone have one of these to try out?
http://www3.towerhobbies.com/cgi-bin...?&I=LXHY14&P=7
FlyWW1 is offline Find More Posts by FlyWW1
Old Nov 19, 2012, 09:37 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Thanks Slofly!!!! Sounds like the apc 7x4 prop is the easy upgrade path,, works out to about 250watts/lb,,, should be just enough performance boost to make her Puuuuurfect!!! And,,, as you said,, with throttle management,, should be OK,, as stock ESC is rated for 12amps for 15sec burst,,, plus that's static, and once unloaded prob amp draw maybe lower ???
Although ,,,,,, the 340 motor on 4S ,,,, could be FUN ,, for those who dare. :-O
Old Nov 19, 2012, 09:41 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Looks cool,,, who's gona be first to try it???? :-)
I LOVE the looks of a wood prop,,, but I wonder how much it weighs compares to stock plastic??
Old Nov 19, 2012, 09:42 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
Differential mixing help please
I can't help but thought I'd try too as
I've read at least 3 requests for this in past 2 days.
some have asked for dx6i, dx8, etc
thanks in advance
rate/expo settings here
http://www.e-fliterc.com/ProdInfo/Fi...-Manual_EN.pdf
High Rate Low Rate, high expo, low expo
Aileron 25mm / 15mm / Aileron 40% 30%
Elevator 35mm / 8mm / Elev 60% 20%
Rudder 20mm / 13mm / Rudder 35% 20%
EDITED--had wrong info
flyrtim is offline Find More Posts by flyrtim
Old Nov 19, 2012, 09:46 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Can you imagine if 3S on this 340 motor produces 20oz of thrust,, what 4S would do??!!! :-O
Old Nov 19, 2012, 09:48 PM
brushless55 is online now
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
so where the heck are all the videos of this one?
brushless55 is online now Find More Posts by brushless55
Old Nov 19, 2012, 09:49 PM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
I looked today at both my LHS but no luck. They couldn't get it for me before the weekend because of Thanksgiving. I was hoping someone would have it on hand to try. As far as weight goes this thing can easily handle a little extra plus wood props are more efficient. So lower amps and more power
Old Nov 19, 2012, 09:50 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
I'm sure... with this crowd... we're gonna find out! And that's the first time I've used that icon!
erkq is offline Find More Posts by erkq
Old Nov 19, 2012, 09:58 PM
Drewkc is offline
Find More Posts by Drewkc
United States, VA, Stafford
Joined Jul 2011
Can anybody share there differential settings im running a dx6i never had to run ailerons on a different channel before. Also would like to fly this plane more sport like what would be good dual rates and expo. The expo on low rates still seem alittle wild to me. Anybody out there care to help with the differential and maybe some help with dual rates are the low rates insane or do they tame this beast down abit? I have a dx6i thanks for any help. DrewC
Drewkc is offline Find More Posts by Drewkc
Old Nov 19, 2012, 10:02 PM
turnerm is offline
Find More Posts by turnerm
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Marlin
I'm out of town or I would've posted a video by now. I'll have one on Tuesday night and hope for a Wednesday maiden.
turnerm is offline Find More Posts by turnerm
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1176 Mar 18, 2016 07:37 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 07:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 08:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 06:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 02:22 AM
