Espritmodel.com Heli Air
Old Oct 26, 2012, 10:10 AM
United States, NM, Santa Fe
Joined Aug 2011
whattaya think about this GWS prop EP7035 7x3.5 ?
stock is 6.8x3
might be what I need for high altitude flying
flyrtim is offline Find More Posts by flyrtim
Old Oct 26, 2012, 10:17 AM
Joined Dec 2007
Originally Posted by 3D-Seth View Post
Hope this helps.
Seth Arnold
Horizon Hobby.
Seth, do you have any word about a PnP or an ARTF version coming up in the future? The €160 price tag for the BnF basic is a bit steep up front cost for many..
McMoron is offline Find More Posts by McMoron
Old Oct 26, 2012, 10:47 AM
Way to many airplanes!
Canada, QC
Joined Oct 2009
I'm way more interested by any clues into what Seth is currently working on! This is a nice 3d airplane, but you need a very large indoor venue if you want to fly it indoor. So Seth, are you working on something to replace the Extra 300 3D or not, we need it NOW! C'mon, spill the beans!
RealGambler is offline Find More Posts by RealGambler
Old Oct 26, 2012, 11:11 AM
Joined Dec 2007
QQ presenting the plane:
HorizonHobby.com On the Horizon 10-25-12 (19 min 38 sec)
You can jump directly to QQ here:
http://www.youtube.com/watch?feature...TjNZ-IjU#t=67s
Old Oct 26, 2012, 11:17 AM
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
a bit big for my taste
chulian1819 is offline Find More Posts by chulian1819
Old Oct 26, 2012, 11:23 AM
MultiCopterPilot & Film Maker
crazyj's Avatar
United States, CA, San Ramon
Joined Oct 2002
Subbed!
Any word on the release date? I thought I saw a Nov date, but don't see anything now.
crazyj is online now Find More Posts by crazyj
7rider's Avatar
USA, CA, Mountain View
Joined Dec 2007
This looks like the perfect baseball/soccer field aerobatic plane! The 3S power will rock for a plane this size.
7rider is offline Find More Posts by 7rider
Old Oct 26, 2012, 11:38 AM
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
Differential is very important for aerobatic airplanes. Some need it, others don't. Differential simply means that you have less aileron travel in one direction than in the other. This helps make the model roll more axial. The model should roll around an imaginary string through the fuselage and out the spinner. If the model looks as though it rolls around the canopy, or rolls around the landing gear, its likely that you have a differential problem. Many times, it is that you have differential, and don't need it, but there are a few cases where you do need to add some differential. Edges generally need a little to make it roll the straightest. If you don't think this is a big deal to you, the airplane will fly fine without it. Just flies a bit better with it.
Hope this helps.
Seth Arnold
Horizon Hobby.
Thank you Seth for the reply. I have the sbach and various other planes and never noticed the behaviour of off rolls that differential helps. Never used it. I guess when I fly my V1 sbach I will pay attention and see if I would use it.
J
jabsten is offline Find More Posts by jabsten
Old Oct 26, 2012, 11:42 AM
Joined Dec 2007
It sits perfectly between the Sbach and the PZ Extra300. Looking at the video and the presentation, if you are willing to sacrifice some top speed and flight time, you might be able to push the AUW down under 200g, that would probably make it fairly floaty.
Old Oct 26, 2012, 11:52 AM
USA, CA, Chico
Joined Feb 2011
I have and flown the E flite 300 size Zero,, its almost exactly same size and weight as this one,, except it flys on 2S not 3S ,, I can tell you on 2S it flys pretty good, about 1:1 power to weight ratio,,, so on 3S should have plenty of power,, and as to wind,,, I've flown it and V2 Sbach with ASX side by side ,,, in a 10 mph wind they both do about the same IMHO,, and in a 15-20mph wind the Sbach with ASX does a little better of course. But ,,,,, it maybe just my imagination,, but I think the Zero feels just a tiny bit smoother on the controls than the Sbach ,,, but maybe that's just it's higher Wingloading . But bottom line is based on my experience with the zero on 2S ,, which is same size and weight as this one and with same receiver and servos as this one, and considering this edge will prob have slightly more wing area and less drag than zero ,, AND edge is running on 3S instead of 2S this edge should be a winner!!! I've radar clocked my Zero at 45mph on 2S,,, so this edge should be even faster!!! NICE!!
Airman74 is offline Find More Posts by Airman74
Old Oct 26, 2012, 11:57 AM
From a Different Planet!
edge_pilot's Avatar
Lagrange, Ohio
Joined Jun 2005
it even has a wing tube and a 2 pc. wing! That is just to cool. I wonder if it comes with wing bags?
edge_pilot is offline Find More Posts by edge_pilot
Latest blog entry: Atomik MM450 Dirtbike
Old Oct 26, 2012, 11:58 AM
USA, CA, Chico
Joined Feb 2011
Originally Posted by brushless55 View Post
I don't care for the 25c Nano packs
these look good!
http://www.hobbyking.com/hobbyking/s...dProduct=25505
I've never used the Zippys before,,, do you think they hold up as well as the nano techs??? And do you think the slightly higher C rating will make that much of a difference???? I don't have enough experience with these little batteries to know
Old Oct 26, 2012, 12:01 PM
USA, CA, Chico
Joined Feb 2011
We could always make some. :-),,,,,,,,, imagine how funny it'd look,,,, I show up at the field where all the guys fly the big wood 3D planes,,,, then I pull out of the car the tiny wing bags and assemble the little foam edge. :-)
Old Oct 26, 2012, 12:10 PM
Gone Huckin'
turnerm's Avatar
Charlotte, NC
Joined Jan 2011
Bwahahahahaha!!! That would be classic!!
turnerm is online now Find More Posts by turnerm
Old Oct 26, 2012, 12:11 PM
Sonic Rainbooms for all
airpower's Avatar
Joined May 2007
Seth, i stand corrected
airpower is offline Find More Posts by airpower
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 619 May 03, 2013 01:53 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes 4 Sep 14, 2012 07:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 08:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 06:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro RTF 2 Feb 03, 2012 02:22 AM
