Old Nov 19, 2012, 06:26 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
Originally Posted by erkq View Post
Well, you could save me digging around and tell me what battery connectors it uses. JST's? Or did HH put EC-3's on it? Surprisingly there's no mention made on HH's site. I guess EC-3's would be rather huge...
Its a red JST connector, like the ones that thunderpower uses. Saw one at a hobby shop, looks great! All the design details in this airplane makes it stand out!
Cheese5 is offline Find More Posts by Cheese5
Old Nov 19, 2012, 06:50 PM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
A BIG +1 on that!!!
Airman74 is offline Find More Posts by Airman74
Old Nov 19, 2012, 07:07 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Originally Posted by Airman74 View Post
Ok,,,, got a break in the weather yesterday ,, flew the crap out of the edge!!!!
Here are my thoughts and experiences,,,, this gona be loooong!! Sorry!!
So the short review : WOW , WOW and WOW!!!!!! First the good: excellent slow speed handling , very good float,,, good power , not fantastic but good, superior handling, very precise and very neutral,, the negatives : could use just a bit more power and speed in my opinion, doesn't handle the wind as well as Sbach V2. I hooked up ailerons on separate channels, set up radio for flapperons. Read about a 3d flapperon function that I wanted to try,, mixed flapperons with elevator so that with up elevator I got ailerons both going up reflexed used a 60% mix,, what this seemed to do at least from what I could tell was give the plane more stability in slow high alpha maneuvers,, found it especially helpful on landings in windy turbulent conditions , enabled me to very easily settle her in extremely smoothly without much effort,, slows her down and allows you to hold nose up without floating in ground effect,, just settles right in, kills glide angle too works great!!
I found my knife edges very very easy to hold, even high apha knife edges and knife edge loops weren't a problem,, I found hovering very easy with this plane. I'm using Zippy compacts 500mah 35c ( 48g) right at front wall gave me CG at 43mm back seemed about right. Flew the edge and SBach side by side one after another,, Sbach on 3S faster and more vertical power than edge,, radar clocked both : edge about 40mph, Sbach on 3s about 47 ,,, but,,, edge definately more floaty better at slow speed, more crisp and precise,, edge has waaaaaaay more visibility and presence in the air. As a side note my 300 powered e flite zero on 3s was radar clocked at 57mph upwind and 64mph downwind,, but it has a 7x6 prop, higher aspect ratio wing, thinner airfoil, and no landing gear. But I LOVE the edge overall,, think it'll be a GREAT 3D trainer for me,, very easy to fly but has great aerobatic capability ( more than I'm capable of currently ) think HH has hit a BIG home run here!!
My one tiny wish would be for just a little more oomph in vertical,,,although its not tooooo bad stock. Maybe a little bigger prop???
What can I say???
Motor/ESC & 4S!!!!
Mine was shipped today.
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Nov 19, 2012, 07:10 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Originally Posted by RCBABBEL View Post
What can I say???
Motor/ESC & 4S!!!!
rc
Let us know how it goes on 4S
Old Nov 19, 2012, 07:11 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
What can I say???
Motor/ESC & 4S!!!!
rc
Castle is having a big sale, CC 19Amp ESC for $25! Might try this and a bigger prop.
-Brian
kalmon is offline Find More Posts by kalmon
Old Nov 19, 2012, 07:18 PM
slo-fly is offline
Find More Posts by slo-fly
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
Here's some weight measurements I thought should be posted, thunder power 3s 45c 325mah weighs 34g, stock prop 2.9g, apc 7x4E 8.4g, apc 7x3.8 slow fly 6.9g and a 2mm adapter 5.4g. I will have the watt test results from the apc props in a few minutes.
slo-fly is offline Find More Posts by slo-fly
Old Nov 19, 2012, 08:23 PM
flyrtim is offline
Find More Posts by flyrtim
United States, NM, Santa Fe
Joined Aug 2011
thanks for info, very curious how the props wil work out.
GWS has some rubber prop adapters that go in thier props that weigh next to nothing--how well they work I shall find out.
flyrtim is offline Find More Posts by flyrtim
Old Nov 19, 2012, 08:32 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
What can I say???
Motor/ESC & 4S!!!!
rc
Are you planning on swapping out to bigger motor on 4S or just a bigger ESC, or both?? Someone earlier tested stock set up at 9.9 amps , and someone else mentioned they had burned out a 280 on 4S, and in the Eflite zero thread some have mentioned that they smoked the 300 motor on 4S as well. I'm guessing with stock prop it should pull somewhere around 180 watts on 4S,,, YIKES!!! That's about 340watts/lb,, an insane amount of power!! Could be fun. :-)
I'm just wondering though, if just a bigger higher pitched prop might not be a little easier though
Old Nov 19, 2012, 08:37 PM
RCBABBEL is offline
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
I'm going to test a bunch of 3S batts in her first.
New motor & esc before I go to 4S land.
Does the airframe look strong enough to you for 'insane'??
rc
Old Nov 19, 2012, 08:44 PM
Fish99 is offline
Find More Posts by Fish99
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
Away for a bit, did I miss them or has there only been 1 flight video posted by new owners of this plane? (A good video though!)
Just looking to see more of us mere mortals flying this plane. (Probably an academic point, as I am almost 100% certain I am buying it as soon as it arrives here in the LHS!)
Marlin
Fish99 is offline Find More Posts by Fish99
Old Nov 19, 2012, 08:47 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Or maybe this motor
http://www.e-fliterc.com/Products/De...rodID=EFLM1155
Old Nov 19, 2012, 08:48 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
rc
Yes I believe it could handle it
Old Nov 19, 2012, 08:53 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Marlin
I'm not a great pilot and I can fly it pretty easily!!! Don't wait on this one!! Just DO it!!! You won't regret it!!
If your not quite sure flying it at first, start on low rates,, it IS extremely responsive
Jerry
Old Nov 19, 2012, 08:54 PM
Fish99 is offline
Fish99's Avatar
Joined Jun 2010
Jerry
Think I am all in on this one ... though I will definately blame you when I am explaining it to my wife Jerry!
Marlin
Old Nov 19, 2012, 09:02 PM
Drewkc is offline
Find More Posts by Drewkc
United States, VA, Stafford
Joined Jul 2011
Can anybody give me there low rates and expo aswell as how they programmed there edge 540 for flaporons with the ailerons on seperate channels flying with a dx6i never had to program a plane for ailerons on a single channel before. Want to fly conservatively not a crazy 3d flyer yet thanks. DrewC, I know everybody is having a blast and thinking 4s and different props can anybody throw out some advice on my above question thanks.
Drewkc is offline Find More Posts by Drewkc
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1176 Mar 18, 2016 07:37 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 07:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 08:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 06:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 02:22 AM
